Old 10-29-2009, 06:29 PM   #16 (permalink)
O-FiveCC's Avatar
Re: Bilstein 5100 on lowered titan
i am going to be getting rid of the 5100's and am going to use a Belltech adjustable strut to drop my front 2" and drop the back with leaf springs and add Belltech shocks. The 5100's are for stock or slightly lifted vehicles...In the rear they will actually raise you 1/4" stock.
Lowering & Lifting Struts by Belltech at StylinTrucks.com
Stylin' Trucks Truck Accessories -- pickup truck, SUV, and custom truck accessories
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
Old 10-30-2009, 03:00 PM   #17 (permalink)
If i get the Belltech adjustable struts for the front do you think I should put the stock spring back on or leave -2" mcgaughy's spring on? Also when lowered trucks "bottom out" does that mean hitting the bump stops or the the actual shock "bottoming out"?
silver08titan is offline   Reply With Quote
Old 10-30-2009, 03:12 PM   #18 (permalink)
O-FiveCC's Avatar
Personnaly, i would put the OEM spring back on...I'm 95% sure it means the bumpstops. I have heard several members mention cutting the bumpstops off or in half so they don't bottom out so easy
2005 XE Crew Cab
Bilstein 5100 vs. Bilstein HD PRJ Titan Suspension 20 12-06-2008 01:22 AM
bilstein 5100 shocks question wl07 Titan Suspension 13 10-13-2008 08:38 PM
Install help needed. Bilstein 5100 coolest dad Titan Suspension 7 09-03-2008 10:33 PM
Bilstein 5100 review username Titan Suspension 23 08-30-2008 07:12 PM
Bilstein 5100 install question dank78 Titan Suspension 10 04-22-2007 10:14 PM
