Old 03-23-2009, 06:30 PM   #1 (permalink)
lift Questions
Just want some input on some of these lifts that are out there. I have an 04 kc 4x4. Its my main tranportation i do quite a bit of driving, last year i put on 15k. Im always off road after work somewhere my stock suspension needs to go!!! I wanna find a lift that I can still drive down the road nicely but can with stand constant abuse I have pro comp 6'' stage 2 in mind and pgr!! What kind of pgr setup would be best. I need it to be level and be able to haul a car trailer once in a while without saging. Proly gonna go with 35's. Will my stock brakes hold up?????? Do i need new gears ?????Any help is great thanks
Titan ARMY is offline   Reply With Quote
Old 03-23-2009, 06:32 PM   #2 (permalink)
Banned
Tmoses's Avatar
Re: lift Questions
the procomp lift with some aftermarket coilovers and uca's !
and a deaver pack for the rear to stiffin it up for towing
Tmoses is offline   Reply With Quote
Old 03-23-2009, 06:39 PM   #3 (permalink)
Nismo4life's Avatar
Re: lift Questions
do you mean PRG? i would get the PRG Pro Comp performance package, UCAs, C-30 deaver pack and shackles. your brakes should be fine just get new pads if your worried about it
2007 Galaxy Black, CC, 4x4, Big Tow, Off Road.
Custom Dual FM 40 Series Exhaust, AEM Brute Force CAI, 2* Timing Advance, 2 JL Audio W3 10" Subs, De-Badged, Bedliner Front and Rear Rumpers, Smoked Tails, Foglight Mod, De-Chromed, Pro- Comp 6" Lift, Radflo Coilovers, 20x10 KMC D-Backs, Nitto Terra Grapplers 305/55/20
PREZ.
MacAndCheeseWhore™
PlayByPlayWhore™
Nismo4life is offline   Reply With Quote
The Following User Says Thank You to Nismo4life For This Useful Post:
Tmoses (03-23-2009)
Old 03-23-2009, 07:13 PM   #4 (permalink)
54warrior's Avatar
Re: lift Questions
Don't buy the Stage 2 ProComp kit. Get the Stage 1 and upgrade to SAW Coils in the front and Bilstein/Saw Shocks in the rear when you have the fundage. I also recommend the Deaver C-30 Leaf Spring Pack (also from PRG). You can't go wrong with the PRG traction bars as well (I recommend the less expensive, yet fully functional, street version). Some like to keep their front sway bar in tact and simply use the endlinks which are included with the ProComp kit. A nice upgrade is the CST endlinks (again, available from PRG). OR, you can be like the rest of us and simply remove the sway bar and endlinks (better for offroading, but since you're towing, I"d leave the swaybar on there).
Any other questions, just fire away!
2005 Nissan Titan CC SE 4x4
The Following User Says Thank You to 54warrior For This Useful Post:
Nismo4life (03-24-2009)
Old 03-23-2009, 07:46 PM   #5 (permalink)
Re: lift Questions
i pretty much agree with 54warrior but with a few things to keep in mind. first, figure out just how much you want to spend. 2nd, determine how much lift you want. if you want a full 6" or more than go with what 54warrior said. if your really just wanting better suspension and not a whole lot of lift then coilovers, rear shocks, UCA's, and a c-30 deaver pack, all via PRG, should be all you need. but all the advice given so far is good advice.
Current mods: JBA cat-back w/ Magnaflow 14" muffler swap, K&N cai, Doug Thorley headers, UpRev, 6" Pro Comp lift, external reservoir Radflo coilovers and SAW rear piggybacks, 35" Nittos on 20x10 KMCs.
Near Future Mods: Ionic Dynamics front fenders, rear bedsides, custom front and rear bumpers, and basically blacking out the Titan!
CaTaDoN50 is offline   Reply With Quote
Old 03-23-2009, 08:10 PM   #6 (permalink)
Re: lift Questions
Now im headed in the right direction!! thanks fellas
Old 03-23-2009, 08:37 PM   #7 (permalink)
Pops's Avatar
Re: lift Questions
x2 on getting the ProComp Stage 1 and upgrade to SAW Coilovers in the front.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
planned 2wd PRG lift - few questions / pics of old lift for entertainment ;) FaintReality Titan Suspension 13 11-16-2008 08:57 AM
Lift questions v. new owner.. CessnaSovereign Titan Suspension 13 05-14-2008 05:52 PM
Lift Questions. KTMHLR Titan Parts & Accessories 2 02-10-2007 11:55 AM
Lift questions jserman Titan Suspension 4 12-22-2005 12:35 PM
new, questions for lift kits, Please help WhiteTT4X4 Titan Suspension 4 04-16-2005 10:32 AM
