Solid Axle?? - Nissan Titan Forum
post #1 of 22 (permalink) Old 03-31-2009, 01:53 PM Thread Starter
iTrader Score: 2 reviews
Solid Axle??
I have been contenplaiting what I want to do with the Titan. I was thinking on trading it in for a 09 Pro-4x but mine is paid off and they wanted 21k on top of my titan. So I have decided to keep it. I visited an Off Road performance shop today and they said they could make my 2WD Titan a 4WD with a Solid Axle, change the gearing, and lift it however high I want it for 5800 out the door. I would have to drop it off for three weeks. Just wanted a little advice and if it is even worth it
a_cent11 is offline
Advertisement
post #2 of 22 (permalink) Old 03-31-2009, 02:09 PM
Yellomantis's Avatar
iTrader Score: 8 reviews
Re: Solid Axle??
That sounds way on the low side... What axle are they going to use? What transfer case are they getting? Are they going to be able to keep the tone rings on the front so the ABS doesn't go crazy?
2010 Dodge Ram Power Wagon
ICON sponsored, going to SEMA 2011, lots of mods
2011 Dodge Ram Quad Cab Sport
Ground Force 2/3 drop, 24" BOSS 330's, true dual exhaust with 11" Magnaflow muffler and x pipe, Volant intake
2007 Nissan Xterra Off Road
PRG Mini Lift
JBA Cat Back
K&N Drop In
CB Radio
Before you criticize someone, walk a mile in their shoes.
That way, when you do criticize them, you're a mile away, and you have their shoes.
Yellomantis is offline
post #3 of 22 (permalink) Old 03-31-2009, 02:13 PM Thread Starter
Re: Solid Axle??
I guess those are questions I need to ask, he told me the axle I just dont remember, I will give them a call and ask. Is there anymore questions I should ask besides these
a_cent11 is offline
post #4 of 22 (permalink) Old 03-31-2009, 02:19 PM Thread Starter
Re: Solid Axle??
the axle is a dana44, the transfer case is a MP203 and he said he was going to eliminated ABS the correct way whatever that means? Does that sound right?
a_cent11 is offline
post #5 of 22 (permalink) Old 03-31-2009, 02:36 PM
Re: Solid Axle??
I'd like to see him mate an NP203 to the Titan trans. Custom mounting plate perhaps? Eliminating the ABS, there is no right way to do this as of yet. It's not as simple as splising the wires to the rear tone rings. The Titan BCM has pre set voltage drops calculated into the reads from all the sensors. When they are off, even a little bit, everything goes haywire. You will have a christmas tree in your dash and will not be able to go any faster than 30mph without the truck shutting off on you.
Depending on what tire you are planning on running, a D44 might be ok. Just don't push it too hard.
PRG Mini Lift
JBA Cat Back
K&N Drop In
CB Radio
post #6 of 22 (permalink) Old 03-31-2009, 02:41 PM
Megw3788's Avatar
iTrader Score: 0 reviews
Re: Solid Axle??
That would be an alright setup depending on what size tires you're planning on running and what you're going to do with it. I'd say a D44 and an Np(not MP)203 are good unless you plan on going crazy big. What do you plan on doing with the truck, just keeping it on the street or going out and beating on it pretty hard all the time?
Megw3788 is offline
post #7 of 22 (permalink) Old 03-31-2009, 02:50 PM Thread Starter
Re: Solid Axle??
I plan on keeping it street an occasional off road meet, it is my only vehicle right now, he wants to go big w/ 37's, I told him the highest I want to go is 9" on 35's..thats what I mentioned to him, if he can accomplish this without making my dashboard a christmas tree I think I will do it...He just finished 3 late model tacomas swaping out EFS for a solid axle and the owners seemed pleased
a_cent11 is offline
post #8 of 22 (permalink) Old 03-31-2009, 03:28 PM
d0va's Avatar
iTrader Score: 3 reviews
Re: Solid Axle??
wow that sounds good post some info on the shop or pictures of their Frankenstein work... and keep us updated...
2006 4x4 Nissan Titan Texas Edition
ProComp 6" Stg1, 35x12.5x17 BFGMudterrains, 17x8.5 MBWheel, AEM Intake, Helix TBS, Thrush Glasspack, HIDextra lights, OFFROAD READY traction bars, Bushwacker Flares, BDGT, Armorlid Bed Cover
www.discounttiredirect.com
d0va is offline
post #9 of 22 (permalink) Old 03-31-2009, 03:30 PM Thread Starter
Re: Solid Axle??
The Off Road Supremacy 4x4
this is the site of the shop, they said they would cover it online as they do it over the three week long process
a_cent11 is offline
post #10 of 22 (permalink) Old 03-31-2009, 04:29 PM
Re: Solid Axle??
I say do it, but I would go with a D60. Just to play it safe. Let them know if they can duplicate it in a "kit" form, there are more buyers out there. But it must retain the OEM tone rings.
PRG Mini Lift
JBA Cat Back
K&N Drop In
CB Radio
post #11 of 22 (permalink) Old 03-31-2009, 04:43 PM
yamatitan's Avatar
Re: Solid Axle??
If they can do that for 5800 with no dash lights and my truck running fine with a working speedo,rpm, etc.. then im there.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Money wasted so far=$11745.00
yamatitan is offline
post #12 of 22 (permalink) Old 03-31-2009, 04:56 PM
iTrader Score: 4 reviews
Re: Solid Axle??
If you do that, you are going to want gears for the rear (which nobody makes) so might as well get D60s front & rear and throw in a couple of lockers.
bestatchess is offline
post #13 of 22 (permalink) Old 03-31-2009, 06:45 PM
Megw3788's Avatar
Re: Solid Axle??
You don't need a D60 for 37"s. A D44 will hold up just fine, especially if you're not going to be taking it out beating on it every day. Not to mention you can buy (5) D44s for the price of (1) D60. I'd do it if the guy guarantee's you won't have any dash lights or anything, that seems like a pretty fair price if he's using quality stuff. Also, I would make sure he was going through the front axle for that price and putting new bearing's, seals and brakes on it. And while the truck is in the shop you could probably send the rear diff off to Hooper's to get gears put in, then just have the guy doing the install put the gears in the front axle.
Megw3788 is offline
post #14 of 22 (permalink) Old 04-02-2009, 09:32 PM
Hawaiianbasshead's Avatar
iTrader Score: 9 reviews
Re: Solid Axle??
huh, D60... don't the dodge 2500+ come with that stock? what do they come with in front stock?
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 33x15.5 Swamper TSL/Sx on 16.5x14" Weld mountain crushers polished, ventshades, 5% tint all around, n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, sundown NSv1, 2.6 cubes @ 38hz single 6" psp port, 1ohm on a single saz-2000d, hoping to change the box to something a little larger and maybe do a kerf port with about 45in^2
Hawaiianbasshead is offline
post #15 of 22 (permalink) Old 04-02-2009, 10:11 PM
Re: Solid Axle??
Dynatrac makes a D60 with a little more ground clearance.
Dynatrac
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
solid axle titan pics {done} solidaxlenissan Titan Pictures & Media Post 92 09-22-2007 03:09 PM
solid axle nissan titan in the works solidaxlenissan Titan Pictures & Media Post 33 07-19-2006 06:18 PM
Solid Axle Titan For Sale solidaxlenissan Buy/Sell 24 03-07-2006 09:49 PM
solid axle titan solidaxlenissan Titan Pictures & Media Post 5 05-12-2005 09:52 AM
You may post new threads
You may post replies
