Old 05-12-2009, 09:00 PM   #1 (permalink)
07cajuntitan's Avatar
Grinding the coil bucket lip question
Does grinding down the coil bucket lip to get UCA clearance when using spacers affect the integrity or strength of the bucket? Anyone ever have a coil bucket fail or crater after taking the lip off? Thanks.
2007 Titan SE KC 4x4 Granite --- Geaux Tigers!!!
07cajuntitan is offline   Reply With Quote
Old 05-12-2009, 09:01 PM   #2 (permalink)
Blackbeauty's Avatar
Re: Grinding the coil bucket lip question
It's not a good idea... Some have done it... But it's NOT a good idea....
Old 05-12-2009, 09:07 PM   #3 (permalink)
twistedfreedom's Avatar
Send a message via AIM to twistedfreedom
only one member that I know of has had the coil bucket fail and he runs his truck off road pretty hard. I ground the lip off of my coil buckets and ahven;t had any problems
Then again my truck doesn't go off road
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts
Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub
Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit.
Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
twistedfreedom is offline   Reply With Quote
Old 05-13-2009, 02:03 PM   #4 (permalink)
I don't get it. Y wld taking off the lip make the coilbucket fail.
2008 2wd cc red brawn
-Mods-
Injen cold air intake.
4" spindle
Extended length Saws
Deaver c-30 pack
Prg upper control arms
CST carrier bearing drop bracket
Prg off-road traction bars
bilsteins in the rear
35" toyo m/t's
20" boss 309
Cdt components
Sundown 100.4
Box from tech with two 10" kickers
Pioneer 2000w mono amp.
dazedasp is offline   Reply With Quote
Old 05-13-2009, 03:41 PM   #5 (permalink)
if you take material off it weakens the structure
overview
Sound
Performance
Coming soon
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
Old 05-13-2009, 04:51 PM   #6 (permalink)
It's rolled for strength. Take away the roll, overall, it will weaken the assembly. You may get lucky. You may not. It's only mechanics and metallurgy.....
Old 05-13-2009, 07:34 PM   #7 (permalink)
The lip exists primarily because it's a stamped part.
Grinding it a bit for UCA clearance won't make any perceptible difference in strength.
2008.5 Red Alert Pro-4X King Cab FFV
S&B CAI, JBA EVOL Cat Back, TB Bypass, 1.5" Leveling kit, Superchips Flashpaq, Moto Metal 951s, Rough Country UCAs, Bilstein 5100s at all 4 corners.
LoveHammer is offline   Reply With Quote
Old 05-13-2009, 08:11 PM   #8 (permalink)
Just-in's Avatar
Thats a good arguement.
I'd be scared to do it though I just deal with the banging till I get The money for UCA's At most I'd notch them where the UCA meets the KFC Buckets.
Old 05-13-2009, 08:21 PM   #9 (permalink)
you can always get a new lip welded to the inside of the coil bucket
overview
Sound
Performance
Coming soon
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
Old 05-14-2009, 01:48 AM   #10 (permalink)
well i already purchased the prg upper control arms and i would like to add a spacer ontop of my coilovers which would definatly make me need to grind down my coilbuckets. after looking at the coilbucket it just doesn't seem like grinding the lip off will really cause the whole thing to fail.
-Mods-
4" spindle
Deaver c-30 pack
35" toyo m/t's
20" boss 309
Cdt components
Sundown 100.4
Old 05-14-2009, 01:57 AM   #11 (permalink)
Send a message via AIM to galaxycrew
+1 for thinking that it is rolled for strength...
i dont think the coilbucket will fail EASILY without the lip...but i definitely think it adds strength, almost how dimple die/flaring works...
thats how i see it anyway
galaxycrew is offline   Reply With Quote
Old 05-14-2009, 11:15 AM   #12 (permalink)
Thanks for the insight guys. I take it only twistedfreedom knows someone who has had a failure....?
2" spacer, uca's & coil bucket question 07cajuntitan Titan Suspension 4 08-30-2008 05:30 PM
PRG lift, UCA's hitting coil bucket??? KILLswitch Titan Suspension 36 08-07-2008 12:46 PM
Banging coil bucket issue gone!!!!!!!!!!! EVO8 Titan Suspension 2 11-29-2007 06:40 AM
A arm coil bucket connection BlingAlong06 Titan General Discussion 0 10-19-2006 06:16 PM
Help, Upper A-arm is hitting coil bucket... K-MU Titan Suspension 10 09-03-2005 10:54 AM
