Old 06-14-2009, 10:36 PM   #16 (permalink)
Darkside's Avatar
Re: Guess what I'll be doing this weekend... *Teaser*
Well guys, I ran into some major technical issues while installing the MT kit. I started off with the right front. Took all the existing hardware from the prg uca I already had and put it on the MT uca like I was told. Went to put it back on and it was a no go. With the spacers in it wasn't going to fit. I didn't feel comfortable trying to force it in to slide the bolt thru. My guess is that the spacers from the old prg uca are not the correct one's I should be using for the MT uca???? I'm kinda upset because I was forced to put the old stuff back on. Anyone using the MT kit run into this issue? Should I have gotten different spacers for the MT uca?
Mods:PRG Mid Travel Kit * SAW Coilovers custom valved by PRG * Glassworks Unlimited Fenders * C-30 Deaver Pack * Rear: Fox Shocks * PRG HD Shackles * Mag-Hytec Diff. Cover * Powerslot (Slotted) Rotors * Xenon HID Low Beams * 35" Kumho Road Venture M/T's * Custom Front Prerunner Bumper by Pirate Labs * 7" HID O/R Lights
Darkside is offline   Reply With Quote
Old 06-14-2009, 11:15 PM   #17 (permalink)
loufish's Avatar
Are you saying you used the rod ends from the old PRG arm and installed them onto the new MT arms?
Or did you just try to use the rod end spacers from the old arms?
Didn't the new arms come with all the hardware you would need?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-14-2009, 11:28 PM   #18 (permalink)
Darkside's Avatar
Greg told me I use the existing hardware from the old prg uca on the new MT uca. I had no problem popping out the uniball and dropping it in the MT uca. But when I went to bolt it back on with everything else on the uca it wouldn't fit. At first I thought the jig on the MT uca was off and not wide enough, but it didn't look too off. So that is why I think the rod end spacers are different. Like I said I didn't want to force it but still nevertheless upset.
Old 06-15-2009, 08:14 AM   #19 (permalink)
loufish's Avatar
If you took one of the rod ends that normally gets threaded into the upper arm off the arm, will it along with the spacers fit into the the upper arm frame mount?
I'm trying to see if it's just the spacer, or did the arm "move" sometime during fabrication...
Born 9/2004
2002 Honda XR650R
Old 06-15-2009, 10:01 AM   #20 (permalink)
Lurchdubious's Avatar
Send a message via AIM to Lurchdubious
Sweeeet! Nice job.
2004 LE.CC.OR.BT~4x4 (Silver)~6" PC Lift~Deaver C-30+1.5" block~Bilstein 5125's~CST sway bar endlinks~DriveShaft Spacer~ProComp 8128 wheels~35" Nitto Mud Grapplers~PWM~Braided Brake lines~Tech12volt's CDT/Boston/Kenwood Audio~Dynomax "Race Magnum" Bullet Muff~Airbox Mod w/K&N~2+ Timing Advance~Bakflip Tonneau~Titanium pedals/Shifter~Chrome door pillars~20% tint~PRG Offroad Traction Bars
VA Chapter Director
Lurchdubious is offline   Reply With Quote
Old 06-15-2009, 02:18 PM   #21 (permalink)
Darkside's Avatar
I tried taking all the hardware off the rod ends and the uca still looks like its a tight fit. Although it might work with thinner spacers??? Tried to call PRG today, no answer...guess i gotta wait and see....
Old 06-15-2009, 03:01 PM   #22 (permalink)
loufish's Avatar
How tight?....You might need to spread the frame ears just a bit to get the rod end & spacers in...They may have crushed a bit the first time....
Born 9/2004
2002 Honda XR650R
Old 06-15-2009, 03:08 PM   #23 (permalink)
albonismo's Avatar
saweeeet mercy!
'06 Smoke XE CC FFV
Mods: AEM Bruteforce Intake, Stillen Dual Rear Exhaust, 2° Timing Advance, 8k HIDs, ReadyLift 2" Leveling, Deaver C-30 pack, Rear Bilsteins, PRG DCBB, LE rims, BFG AT KO 305/65r18, StreetScene One Piece Custom Grill powder-coated black, Color-Matched rear bumper, VHT NightShade painted tail lights, Debadged
Future Mods: UpRev, Nismo headers, Detroit TruTrac, SAWs in front I need new pictures
albonismo is offline   Reply With Quote
Old 06-15-2009, 06:55 PM   #24 (permalink)
Darkside's Avatar
The frame ears didn't look bent or anything and I didn't want to force it. It was either spread the frame ears, take a chance on forcing it in a spreading the uca or seeing if different spacers would do the trick. I'm getting more and more bummed out. At first I was pissed, now I'm bummed. Can't really do anything until Greg calls me back.
Old 06-15-2009, 07:08 PM   #25 (permalink)
RyBo's Avatar
Send a message via AIM to RyBo
Sorry buddy *pats back*
Bumpin' That Cali Love =)
BlondeTitanWhore™
RyBo is offline   Reply With Quote
Old 06-15-2009, 07:47 PM   #26 (permalink)
loufish's Avatar
Did you throw a set of calipers on the new & old rod ends to check their width?
The upper arms came with new rod ends on them but no spacers?....BTW your lack of photos is alarming...
Born 9/2004
2002 Honda XR650R
Old 06-15-2009, 09:41 PM   #27 (permalink)
motorvisions's Avatar
ok, my MT arms came with the uniballs, rod ends and spacers. although i had someone install the kit for me, i was told he had to spread the arm apart to get it in position. he put one side in and used a prybar to force it open a bit. said it was a real pain in the butt though. hope this helps
motorvisions is offline   Reply With Quote
The Following User Says Thank You to motorvisions For This Useful Post:
Darkside (06-16-2009)
Old 06-16-2009, 12:18 AM   #28 (permalink)
Darkside's Avatar
Thank you for the helpful info! I'm gonna take the high road on this one and just take it somewhere to have it installed.
Old 06-16-2009, 05:37 AM   #29 (permalink)
hope it works for you, get some pics!
Old 06-22-2009, 09:42 PM   #30 (permalink)
CL 8 2WD's Avatar
Check this out......
You get your $hit installed yet where are the pics
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Teaser... undy Titan Pictures & Media Post 6 05-15-2009 07:48 PM
Turbo teaser Mychael101 Titan Performance Modifications 23 03-06-2009 06:43 AM
Teaser Pics... Pops Titan Pictures & Media Post 38 02-02-2009 08:47 AM
Brain Teaser 54warrior Off-Topic Discussion 16 08-22-2008 08:52 PM
Just a teaser... rjspitz Titan Interior Discussion 8 04-24-2005 02:33 PM
