Old 06-26-2009, 08:02 AM   #1 (permalink)
Peytons_Titan08's Avatar
Safest way to remove the lip on the coil bucket?
I need to do this asap so whats the safest way to do it?
TRUCK IF FOREVER CHANGING! check back
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
Old 06-26-2009, 08:05 AM   #2 (permalink)
twistedfreedom's Avatar
Send a message via AIM to twistedfreedom
Re: Safest way to remove the lip on the coil bucket?
get a grinder and grind the lip down. I had to do it on my coil buckets with just a leveling kit. Just be careful not to tag a brake line or the ABS sensor wire while doing this
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts
Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub
Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit.
Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
twistedfreedom is offline   Reply With Quote
The Following User Says Thank You to twistedfreedom For This Useful Post:
Peytons_Titan08 (06-26-2009)
Old 06-26-2009, 08:24 AM   #3 (permalink)
CL 8 2WD's Avatar
I have a grinder like this, but I removed the guard and the handle.
Makes it easier to use and work different angles.
Buy the thin composite metal cutting discs and cut through the metal with the edge of the disc.
After you have cut off what you need , grind smooth.
Oh the real answer to your question, be very careful or pay a shop to do it
Small pneumatic grinders are very nice if you have access to one.
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
The Following User Says Thank You to CL 8 2WD For This Useful Post:
Old 06-27-2009, 10:11 PM   #4 (permalink)
Just-in's Avatar
grinding the buckets doesn't make them weak?
Old 06-28-2009, 03:01 PM   #5 (permalink)
vilim12's Avatar
No if you just grind the lip, then you should be fine
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 06-29-2009, 11:27 AM   #6 (permalink)
pipho's Avatar
I took mine down with a cut off wheel, easy and a clean cut
pipho is offline   Reply With Quote
Grinding the coil bucket lip question 07cajuntitan Titan Suspension 11 05-14-2009 11:15 AM
PRG lift, UCA's hitting coil bucket??? KILLswitch Titan Suspension 36 08-07-2008 12:46 PM
Banging coil bucket issue gone!!!!!!!!!!! EVO8 Titan Suspension 2 11-29-2007 06:40 AM
A arm coil bucket connection BlingAlong06 Titan General Discussion 0 10-19-2006 06:16 PM
Help, Upper A-arm is hitting coil bucket... K-MU Titan Suspension 10 09-03-2005 10:54 AM
