Old 06-28-2009, 07:42 PM   #1 (permalink)
Jiro's Avatar
Leveling kit? Need one mounted above assy.
I am looking into who makes a leveling kit (1.5") that mounts above the strut assembly and not right above the spring itself. I've only seen 2" ones like the pro-comp and the one from 4wheelparts. Anyone know who makes one?
Jiro is offline   Reply With Quote
Old 06-28-2009, 07:48 PM   #2 (permalink)
4mula1fan's Avatar
Re: Leveling kit? Need one mounted above assy.
Prg..........
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up.
Grumpy Old Man Club
http://s3.bite-fight.us/c.php?uid=214743
4mula1fan is offline   Reply With Quote
Old 06-28-2009, 07:59 PM   #3 (permalink)
yamatitan's Avatar
yep prg
http://www.prgproducts.com/shop/prod..._leveling_kit/
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 06-29-2009, 08:48 AM   #4 (permalink)
Jiro's Avatar
You guys have pics of the prg installed?
Old 06-29-2009, 09:42 AM   #5 (permalink)
TecheTitan's Avatar
This is what mine looked like with the PRG leveling kit and 305/65/18 BFG on factory wheels.
06 Smoke SE CC 4X4
Bug Shield, in channel vent visors, 22% front window tint, Pro Comp stage1 w/ SAW coilovers and 2" rear block w/ 305/65/18 BFG AT KO's on 18X9 KMC Monsters, JBA cat-back, 2* advance, AEM intake, BD Power Pup
TecheTitan is offline   Reply With Quote
Old 06-29-2009, 03:12 PM   #6 (permalink)
Jiro's Avatar
Thanks, but I was actually looking for a pic of the suspension itself. I wanted to see where the kit mounts to
Old 06-29-2009, 04:21 PM   #7 (permalink)
orionS14's Avatar
It bolts on top of the coilover...you remove the whole front 'shock assembly'...and bolt the spacer onto the 3 studs.
Then you rotate the assembly 180-degrees, and bolt it back in place.
No disassembly of the strut/spring, they just bolt on top of the strut.
- Brian
'05 TITAN CC SE (2" level - Bilstein 5100's - 22" Magnaflow - K&N drop-in - 20" Weld wheels (forged) - 275/60-20 Dueler Revo's)
'96 240SX (turbo'd track car - 325rwhp / 2700lbs)
'07 VW GTI (4-door - DSG - wife's daily driver)
orionS14 is offline   Reply With Quote
Old 06-29-2009, 04:35 PM   #8 (permalink)
Jiro's Avatar
Thanks man. That's what I was looking for.
Old 06-29-2009, 04:36 PM   #9 (permalink)
yamatitan's Avatar
I dont know what kit this is \but anyway on the rancho shock you can see how the kit mounts. Prg kits mounts the same way is this kit.
Old 06-29-2009, 09:26 PM   #10 (permalink)
Jiro's Avatar
Thanks for the pic yamatitan
Old 06-29-2009, 10:21 PM   #11 (permalink)
Down South's Avatar
I have the ncd 2.5 and it is great. Don't spend the extra money on one with bump stops baecause the aren't really needed. I bought some seperate and took them back
06cc smoke, utilitrac, bt, off road, 2.5 ncd leveling kit, undercover, bfg at ko's, powder coated black billet upper grille inserts, hella blackmagic fogs in lower grille, AFE stage 2(dry flow), AFE silver bullet TBS, blacked out emblems and upper grille, black halo projection headlights....soon to come: iron bull rear bumper
Down South is offline   Reply With Quote
Old 06-30-2009, 02:45 AM   #12 (permalink)
Jiro's Avatar
Looks like Im going with the 1.5" prg kit, but the thing is that when I measure from the top of the tire to the fender, there is only a 1" height difference, (front is 6" and rear is 7"). I dont want the front to be higher than the rear
Old 06-30-2009, 05:33 AM   #13 (permalink)
Jellero's Avatar
If your Titan is an 08 or newer the 1.5 in PRG leveling kit is the one you want. This kit is made for these model Titans. After I installed mine it left me with about 1/2 inch of rake.
2008.5 Crew Cab 4x4
SE w Poplar Package
Red Brawn Big Tow
OEM Fogs
Spray in Bed Liner
PRG Leveling Kit
Go Rhino Dominator II's
Jellero is offline   Reply With Quote
Old 06-30-2009, 06:10 AM   #14 (permalink)
Down South's Avatar
I think 2wd and 4wd makes a difference also in the amount of factory drag, but don't quote me on that not 100% sure
Old 06-30-2009, 08:56 AM   #15 (permalink)
Jiro's Avatar
I have an 08 pro-4x but like I said, when I measured the difference was only an inch front/rear. Does it really add exactly 1.5"?
WTB: PRG Titan Mini Lift Kit or Leveling Kit Ern3 Buy/Sell 7 03-24-2009 08:14 AM
Opinions on a drop kit or leveling kit MrJonMan Titan Suspension 2 12-09-2007 02:25 PM
NEEDED Chrome bumper assy, stock ANYONE? 4x4SANDMAN Buy/Sell 1 11-09-2007 07:57 PM
Need smoke hid head lamp assy. KMEDLIN Titan General Discussion 1 02-09-2007 11:29 AM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 08:16 PM
