Old 06-30-2009, 06:34 PM   #1 (permalink)
Good lift set up
I am new with trucks and wanted to know if this would be a good lift set up to get and if anyone has it.
Pro Comp 6" lift kit stage 1
CST Titan Sway Bar End Links
SAW Coilovers
Bilstein Rear 5125 Series Titan Rear Shocks
PRG Deaver Titan C-30 3-Leaf Spring Pack
PRG Titan Street Traction Bars
I am thinking about getting the Pro comp 6001 wheels size 18x9.5
but don't know what tires to get I have to see what thet have at the dealership since I have to buy them there.
Any help would be great.
Cmaynard is offline   Reply With Quote
Old 06-30-2009, 06:42 PM   #2 (permalink)
Re: Good lift set up
Get in touch with Greg from PRG he will give you a set-up to match what you want. IMO I would go with a stage 2 lift get rid of that spacer. Go with 35" Toyo M/Ts.
06' Titan SE KC debadged, Procomp, Rockstars, Toyo M/T, FM40 , S&B, True-Trac, Bully Dog, RBP Step Bars, Mag-Hytec Diff Cover, DIY Grill
mcclelland21 is offline   Reply With Quote
Old 06-30-2009, 07:09 PM   #3 (permalink)
DRTYAZN's Avatar
you'll be fine with the stage 1 and SAW 2.5 coilovers, the coilovers will illiminate the need for the spacer... in fact, that's pretty much my setup after I PRG'd my PC stage 1 lift... get in touch with PRG and get the PRG upper A arms too...
Radiant Silver '06 Titan SE CC 4X4 w/BT&OR w/ ATS Fender Flares
PC 6" lift w/ PRG A arms & traction bars, SAW's front/rear combo & Deaver pack
35" PC Xtreme Mud Terrains on 17" Helo Maxx 6's
Volant CAI, PowerAid TBS, Flowmaster 50
DECEPTICON center grill, SS Hood Deflector & Chrome Truck Nutz
DRTYAZN is offline   Reply With Quote
Old 06-30-2009, 07:25 PM   #4 (permalink)
yamatitan's Avatar
the saw coilovers listed get rid of the spacer and are better then the ones in the procomp stage 2.
That is a very good setup the op has listed.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 06-30-2009, 07:35 PM   #5 (permalink)
TecheTitan's Avatar
Yep, you are on the right track for sure! The stage 1 eleminates the need for any Procomp spacers or coilovers (with the stage 2) which would be sub-standard to the SAWS in the first place. The CST swaybar endlinks are better than what comes with the Procomp kit. The Bilstein rears are also an improvement over the Procomp rears that come with the kit.
Now, if you need the rear pack that is a great setup, better than factory for sure and the trac bars would be icing on the cake!
That sounds like a really good setup to me, like mentioned before, call Greg at PRG if you haven't done so already...but it sounds like you have or have been paying very close attention to everyone else on here who is very satisfied with their setup.....good luck and you will like it if you decide to go that route!
06 Smoke SE CC 4X4
Bug Shield, in channel vent visors, 22% front window tint, Pro Comp stage1 w/ SAW coilovers and 2" rear block w/ 305/65/18 BFG AT KO's on 18X9 KMC Monsters, JBA cat-back, 2* advance, AEM intake, BD Power Pup
TecheTitan is offline   Reply With Quote
Old 06-30-2009, 07:53 PM   #6 (permalink)
54warrior's Avatar
I have everything you mentioned...except the Deaver Pack and CST endlinks (I removed my swaybar tho).
Love the setup. Want to get the Deaver C-30 pack next.
2005 Nissan Titan CC SE 4x4
Old 06-30-2009, 09:56 PM   #7 (permalink)
THANKS YOU ALL now all I need to do is get some money LOL
Old 07-01-2009, 03:13 AM   #8 (permalink)
My bad, I ment to say go with the SAW's or Radflo's and not the PROCOMP coilovers, yes they are substandard to either of them.
Old 07-01-2009, 08:12 PM   #9 (permalink)
Thanks for all the advice. But I wanted to know will I really need all of this is I am not planning on doing alot if any off roading. I just want it for show and am trying to cut back on some money since I am a broke college kid LOL
Old 07-01-2009, 09:43 PM   #10 (permalink)
slickproof's Avatar
What kind of gas mileage would you get raising it from stock up to 6"?
06 K/C LE 4X4 - NISMO Cold Air Intake, Off-Road, Big Tow.
PURE BEEF!
slickproof is offline   Reply With Quote
Old 07-02-2009, 07:20 PM   #11 (permalink)
I talked to Greg and he told me all I would need is:
SAW Coilovers
upgrading to the Sway-A-Way 2.25 piggyback reservoir shocks
Old 07-02-2009, 07:50 PM   #12 (permalink)
JLG_Engineer's Avatar
SAW Coilovers
That sounds like a great setup. I would jump on that setup myself if the price was right.
Quick question: If I get the Traction Bars and weld them in. Could I ever go back to the stock height when I decide to trade in?
JLG_Engineer is offline   Reply With Quote
Old 07-02-2009, 08:02 PM   #13 (permalink)
TecheTitan's Avatar
Yes you could, however you would still have the bracket welded to the frame, but that could be easily removed as well.
06 Smoke SE CC 4X4
I need some help!!! is this a good set up BigBlue08 Titan General Discussion 11 06-26-2009 05:32 AM
Good set of HIDs CO-Titan11 Titan Parts & Accessories 23 02-26-2009 03:06 PM
WTB-good set of hid ballasts hitecredneck Buy/Sell 1 02-11-2008 09:18 AM
Need A Good Set Of Tires 2004 Titan Le mrcountry Buy/Sell 0 01-24-2008 09:38 AM
Ebay Brake.Rotor Set Any good?? smoketitan Titan General Discussion 0 03-03-2005 01:05 PM
