Old 06-30-2009, 10:18 PM   #1 (permalink)
TitanOn40's's Avatar
making my 2wd into a pro-4x
yes it is true i want to attempt it if anyone already has please give me your imput. im looking to make my 08 2wd into a 4wd but finding all the parts is tedious so any help would be greatly appriceated...(dont think i spelled that right btw)
TitanOn40's is offline   Reply With Quote
Old 06-30-2009, 10:39 PM   #2 (permalink)
MikeSublime's Avatar
Re: making my 2wd into a pro-4x
Man this should be one expensive mod
2008 CC Galaxy Black
Engine Mods
- Bully Dog
- Banks Monster exhaust
- AEM BF CAI
Soon to come: Nismo headers and UpRev
Interior Mods
- 2 RE Audio SR10's with 1000d Amp
- Kenwood DNX5120
Soon to come: front and rear componets
MikeSublime is offline   Reply With Quote
Old 06-30-2009, 11:32 PM   #3 (permalink)
Irish125's Avatar
I think it may have been attempted before. Try searching around on here and see if you can find it. Not undoable but it will be quite a project for sure.
'08.5 SE KC
MODS
Irish125 is offline   Reply With Quote
Old 06-30-2009, 11:34 PM   #4 (permalink)
vilim12's Avatar
Lots of things youll need, new ECU, all the diffs and axle, transfer case, the cool sticker and plenty of other things. I think RTC(forget the rest of his name) had a thread about this.
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 06-30-2009, 11:38 PM   #5 (permalink)
Jiro's Avatar
Not trying to be a smart@ss but it would be a lot easier and probably less expensive to trade for a 4x. But if you want to just take on the project then good luck man! Your truck will be one of a kind. I would love to see a SAS titan!
2008 blizzard Pro-4x cc swb
Jiro is offline   Reply With Quote
Old 06-30-2009, 11:42 PM   #6 (permalink)
BuckeyeTitan's Avatar
Like this???
Cnallick's SAS Conversion
and I agree that a trade in would be a lot easier. But then again you might lose money on the trade so you might be able to do a sas and still be better off. Good luck man. Pics as it progresses please.
IRC VK56 Member
2005 Nissan Titan King Cab Se
Mods: Extang Fulltilt tonneau, AEM Brute Force CAI, Superchips Cortex 87 octane tune, Toyo A/T's, Next generation JBA exhaust
Fastest time ever at a track on ice in a 2wd Titan as far as I know: 60 ft 4.86 1/4 ET 22.17
Times on 5/9/09 - R/T .064, 1/4 14.849, 1/4 mph 91.62
Voted 2009 High School Nationals Best Import Truck
College beater:
2004 Dodge Dakota 4x4 extended cab
Mods: line-x, 10% tint rears 35% tint front, Extang Fulltilt tonneau, Sony head unit, alpine speakers all around, Rancho RSX shocks
Times on 6/3/09 - 1/4 17.275, 1/4 mph 79.29
BuckeyeTitan is offline   Reply With Quote
Old 06-30-2009, 11:43 PM   #7 (permalink)
vilim12's Avatar
We got atleast 3 on the forum, the most recent I think was this one
Read up my friend, Cnallick's SAS Conversion
Crew Cab Long Bed
Old 06-30-2009, 11:43 PM   #8 (permalink)
vilim12's Avatar
Yo you suck buckeye
Crew Cab Long Bed
Old 06-30-2009, 11:45 PM   #9 (permalink)
Originally Posted by vilim12 View Post
Yo you suck buckeye
Nope. I'm just that good lol
IRC VK56 Member
College beater:
Old 07-01-2009, 01:34 AM   #10 (permalink)
Jiro's Avatar
Nice!!! Thanks for the links guys!
Old 07-01-2009, 02:58 PM   #11 (permalink)
yamatitan's Avatar
Yea if your going to turn your truck into a 4x4 dont waste your time with the factory ifs. Get a straight axle and donts waste your time with the stock transfer case either go ahead and get a atlas case. You could probably get away without getting a new ECU if you run manual controls for the transfer case.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 07-01-2009, 04:18 PM   #12 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
the op can. i have done a butt load of research on the 2wd to 4wd w/out sas. if you go 4wd and want to run ifs it isnt that bad if you have a lift already installed. kinda a pita if you are still stock. all the ecu, tcu, and swithches are plug and play. the cut out is already in the dash and the lights are already wired up. if you dont want the stock transfer case get an atlas like yamatitan said. i think it is the 3202 or something like that. it will bolt up with and adapter plate and you can use tin snips and cut the floor board out for the selector knob. any questions ask away.
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 07-01-2009, 05:22 PM   #13 (permalink)
yamatitan's Avatar
Its going to be a lot more expensive to do a ifs then it will be to do SAS.
Old 07-01-2009, 07:19 PM   #14 (permalink)
thanks alot for all the suggestions its gonna be awhile to do all this because im going to be ballin on a budget but i'll be sure to keep everyone posted for sure.
Old 07-01-2009, 07:27 PM   #15 (permalink)
Just-in's Avatar
I'd go with the atlas transfer case... It's expensive but If you have a bench seat It'd be sicker than **** IMO to have a manual shift transfer case.
The TCU isn't plug and play you'll have to swap the wiring harness out. I spoke with another member, the same guy who bypassed the e-locker in 4lo about wiring the transfer case seperate from everything and shifting it with a set of switches. He beleives it's possible, a elec guru buddy of mine feels it's possible also but no t-case in my garage as of yet so...
Everything else bolts right up but without a bracket lift you'll need to either fabricate on your own or order from a dealer tabs to mount the front diff carrier assembly. I spoke with an e-bay seller and he was willing to cut me a package deal for everything even the ECU and order the tabs from the stealership for me I shut him down though before he made the effort to total it all up because I simply dont have the $ I was just trying to get some info out of him about some parts he had listed and mentioned what I was up too lol.
my .02
pro comp lift making noise helix139 Titan Suspension 18 07-23-2008 06:35 PM
fs 2wd fabtech lift with pro rims and pro comp extreme all terrains timlloyd951 Buy/Sell 8 07-07-2008 06:17 PM
Pro Comp 6" lift on 2wd ipolito Titan Suspension 8 01-10-2008 08:45 PM
6" pro comp lifted titan 2wd betterview Titan Performance Modifications 16 07-22-2005 11:55 AM
