Old 07-01-2009, 12:08 PM   #1 (permalink)
Long term front end problems
Has anyone had any long term front end problems (like u-joint replacement) after installing a lift and 35" tires?
TimberlineTitan is offline   Reply With Quote
Old 07-01-2009, 12:28 PM   #2 (permalink)
54warrior's Avatar
Re: Long term front end problems
I have had my lift/tires installed for 50,000 miles and haven't replaced any components on the front end yet. knock on wood
EDIT: I take that back... right after install, the RF wheel bearing/hub assembly was replaced under warranty. Everything has been fine since.
Haven't heard of many having problems with U-Joints or CV Joints either.
The biggest issue with the 6" lifts, is the transmission mount, nearly everyone who has lifted with a 6" kit has replaced theirs by now. The PRG traction bars will eliminate that though. Good thing is, that the t-mount is a very easy part to install, and about $80.
2005 Nissan Titan CC SE 4x4
Old 07-01-2009, 03:01 PM   #3 (permalink)
yamatitan's Avatar
no problems when I put my PRG UCA's my ball joints in the stockers were still good. My lift has been on for 18,000 miles.....
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 07-01-2009, 10:03 PM   #4 (permalink)
Thanks guys. I am installing the lift soon and wanted to know what to look out for.
Tags
front end problems
Rode Around With Parking Brake? Any Long Term Problems? CFDE2 Titan General Discussion 24 02-23-2006 09:32 AM
Front-end alignment problems with the 2.5" leveling kit... miketan Titan General Discussion 6 02-04-2006 10:48 AM
Front End Alignment PROBLEMS ! dizzyswimmer Titan General Discussion 11 12-02-2005 01:38 PM
Front End Alignment PROBLEMS ! dizzyswimmer Titan Problems & Dealer Service 2 12-01-2005 08:04 PM
