Old 08-10-2009, 08:44 PM   #1 (permalink)
obviously the wrong leveling kit... ;(
Well, just bought my first Titan on Friday. a new 2009 XE crew 4x4. absolutely love it! put a 1" rear block in and a front strut extender.... obviously the wrong size. The spacer itself measured 1.5" thick. My upper control arm sits on the coilbucket... doesn't make for the best ride... I have read on here to trim back (grind down) the lip on the coilbucket. Might try that. PRG list UCA for $600. Don't know if I can swing that at this point. Maybe my best bet is to remove the spacer and start over again with a shorter one....
Any ideas would be greatly appreciated on how I should move forward. thanks!!
spikeyhaired1 is offline   Reply With Quote
Old 08-10-2009, 08:57 PM   #2 (permalink)
Just-in's Avatar
Re: obviously the wrong leveling kit... ;(
Have a machinist turn down the spacer a bit for you on the lathe or grind that KFC bucket.
I've done neither to my truck, just deal with the banging so far. Maybe when it bangs enough both parts will dent up and it will mate smoothly and quetly
you may have the right spacer a 1.5 spacer I believe is what you run on the new 4x's
Just-in is online now   Reply With Quote
Old 08-10-2009, 09:00 PM   #3 (permalink)
albonismo's Avatar
that can't be right....a 1.5" spacer is supposed to work on a 4x4
'06 Smoke XE CC FFV
Mods: AEM Bruteforce Intake, Stillen Dual Rear Exhaust, 2° Timing Advance, 8k HIDs, ReadyLift 2" Leveling, Deaver C-30 pack, Rear Bilsteins, PRG DCBB, LE rims, BFG AT KO 305/65r18, StreetScene One Piece Custom Grill powder-coated black, Color-Matched rear bumper, VHT NightShade painted tail lights, Debadged
Future Mods: UpRev, Nismo headers, Detroit TruTrac, SAWs in front I need new pictures
albonismo is offline   Reply With Quote
Old 08-10-2009, 09:03 PM   #4 (permalink)
BuckeyeTitan's Avatar
Yeah but if it's 1 1/2" thick thats too much. I forget the leverage ratio thing but that spacer is for 2+ inches of lift which is too much for the new more level from the factory 4x4s
IRC VK56 Member
2005 Nissan Titan King Cab Se
Mods: Extang Fulltilt tonneau, AEM Brute Force CAI, Superchips Cortex 87 octane tune, Toyo A/T's, Next generation JBA exhaust
Fastest time ever at a track on ice in a 2wd Titan as far as I know: 60 ft 4.86 1/4 ET 22.17
Times on 5/9/09 - R/T .064, 1/4 14.849, 1/4 mph 91.62
Voted 2009 High School Nationals Best Import Truck
College beater:
2004 Dodge Dakota 4x4 extended cab
Mods: line-x, 10% tint rears 35% tint front, Extang Fulltilt tonneau, Sony head unit, alpine speakers all around, Rancho RSX shocks
Times on 6/3/09 - 1/4 17.275, 1/4 mph 79.29
BuckeyeTitan is offline   Reply With Quote
Old 08-10-2009, 09:58 PM   #5 (permalink)
HRTKD's Avatar
I think the spacer for an '08+ 4x4 is supposed to be smaller. The '08+ is already slightly level. At least compared to my '07 it is.
About the only downside to the PRG UCA is that they make a lot of noise. Frequent lubrication reduces this. Otherwise they are a perfectly functional suspension upgrade that I am quite pleased with.
Jim
Old 08-10-2009, 10:28 PM   #6 (permalink)
WhiteTitanSe's Avatar
If the actual spacer measures 1.5" thats too much for an 08' 2wd or 4wd. Thats a 2.5" lift and I think the spacer you need should measure 1" or less since 1.5" is max on an 08' 4x4 before the cb will hit.
04 TiTan Se 4x4
Intake
FlowMasters
2*Timing adv.
9" Pro comp
7" Rear Block + Deavers
20x10 XD RockStars
38x15.50 Kumho Mts
12000k Headlight H.I.D
3500k Fog H.I.D
2 10" Diamond Audio subs with custom box
1200.2 Infinity Amp
Stillen diff cover
OR Skid Plate
Bushwacker Pocket Flares Pain Matched
Matched Handles and rear bumper
NFabWorks Traction Bars
WhiteTitanSe is offline   Reply With Quote
The Following User Says Thank You to WhiteTitanSe For This Useful Post:
54warrior (08-11-2009)
Old 08-11-2009, 06:37 AM   #7 (permalink)
loufish's Avatar
My 04' 2wd spacer was 1.600" tall, with motion ratio yes it worked out to 2.5" of actual lift...
The Titans have some production tolerance issues when it comes to the UCA clearing the bucket...Some clear no problems and of course a few hit...
I also agree a slightly smaller spacer would help, and losing a 1/2" of lift is worth not having any suspension part contact...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
The Following User Says Thank You to loufish For This Useful Post:
Old 08-11-2009, 06:54 AM   #8 (permalink)
Could always get the rough country upper control arms. I think they are only around 190.00. Perfect for spacer lift clearance.
RU2112SH is offline   Reply With Quote
The Following User Says Thank You to RU2112SH For This Useful Post:
Old 08-11-2009, 07:14 AM   #9 (permalink)
54warrior's Avatar
What these guys have already said... u need a different spacer. If you got it from PRG... he may just swap it for you.
2005 Nissan Titan CC SE 4x4
Old 08-11-2009, 08:53 AM   #10 (permalink)
Thanks for all the info. I am going to look into the rough contry control arms first just for fun. Either way (going with the control arms or a different spacer) it looks like I am going to have to disassemble parts anyway.... I will keep you posted on how it goes.....
Old 08-11-2009, 02:14 PM   #11 (permalink)
I talked with rough country today and they do not sell the UCA's seperatly, they only sell them in the 3" leveling kit. It seems cheap so Im not sure about the quality. Im probably going to use the 3" kit along with my Bilstein 5100s and a block in the rear to make it about a 4-5" lift.
2004 Titan 4x2
MODS:
Flowmaster 40's
Bilstein 5100's
To-Do List:
Interco Vortrac
(35-12.5R18)
PRG Shackles
RC 3" Level w/UCA's
RC 1.5 R block
TruTrac? (alot of $$)
Mx851 is offline   Reply With Quote
Old 08-11-2009, 03:31 PM   #12 (permalink)
SATXTITAN's Avatar
Keep us updated on this setup. I've thought about going this route, instead of spending three times as much on the Rancho 4" lift that doesn't even come with shocks.
<a href=http://img21.imageshack.us/i/cimg2780b.jpg/ target=_blank><img src=http://img21.imageshack.us/img21/4859/cimg2780b.th.jpg border=0 alt= /></a>
SATXTITAN is offline   Reply With Quote
Old 08-11-2009, 10:43 PM   #13 (permalink)
I don't think that will work on an 08' 4x4. The .5"-1" that o8' come higher then previous years so I think you will have problems. I would just get a TopGunz 1.5" leveling kit for 80 bucks. Save up and get the Rc 6" or Pc 6" lift or 1.5" levelng kit and a 3" bodylift.
04 TiTan Se 4x4
Intake
FlowMasters
2*Timing adv.
9" Pro comp
20x10 XD RockStars
38x15.50 Kumho Mts
3500k Fog H.I.D
1200.2 Infinity Amp
Stillen diff cover
OR Skid Plate
Old 08-12-2009, 08:09 AM   #14 (permalink)
dc_909's Avatar
I use the 2.5" Mini Lift on my 08 4x2 and I don't have any Coil bucket issues, even at full droop.
2008 Blizzard SE KC - PRG 2.5 Mini Lift - XD Hoss w/ 325/60/18 Nitto TG's - Banks Catback - Bully Dog Reg. Tune +2* - DDM 6k HID's Upper-Lower - Bilstein 5100's
dc_909 is offline   Reply With Quote
Old 08-12-2009, 08:55 AM   #15 (permalink)
i really like the amount of lift the current spacer is giving me. I have the 1" block in the back so it sits really level right now. I don't want to lower the front from this stance. I ordered the Rough country componets to put on my Titan. I will let you know how the UCA are and how easy (or hard) they are to install. Everything should be here tomorrow.
WTB: PRG Titan Mini Lift Kit or Leveling Kit Ern3 Buy/Sell 7 03-24-2009 08:14 AM
talk about bein in the wrong place at the wrong time... giimmelub Off-Topic Discussion 6 12-20-2008 03:23 PM
mini lift kit Vs. leveling kit? mike-p Titan Parts & Accessories 12 10-17-2008 01:47 PM
Opinions on a drop kit or leveling kit MrJonMan Titan Suspension 2 12-09-2007 02:25 PM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 08:16 PM
