At wits end - Nissan Titan Forum
Old 08-25-2009, 06:31 AM   #1 (permalink)
Steelyeyedone's Avatar
iTrader Score: 10 reviews
At wits end
Need some advice. I would ask Greg, but I know he's a busy SOB with his move right now.
My rear springs squeak like no-ones busniess. I get under there every week and blast them with a pressure washer to clean them and shut them up for a week. But that’s getting old. I cant pinpoint the location of the squeak, but I assume its where the overload spring connects to the leaf. Has anyone had this issue, and swapped out the overload with the PRG Deaver C-10 or C-30 pack? Did this resolve your issue?
I know lots of folks have the squeaky issues back there, has anyone pinpointed the location, and found a permanent fix for it? I’ve searched the threads, have seen "loosen the shackle", "grease between the leafs", replace the shackle" but just can’t find a permanent fix. I don’t want to lube it, as it will attract more dirt and grime, and do more harm then good.
Any permanent fixes? Let me know.
Thanks.
2008 Nissan Titan LE CC 4x4 LWB
Mods
Steelyeyedone is offline   Reply With Quote
Advertisement
Old 08-25-2009, 06:40 AM   #2 (permalink)
Blackbeauty's Avatar
iTrader Score: 12 reviews
Re: At wits end
Wit's end? It might help if you didn't start out with half the wits of the average Wal*Mart greeter.....
Seriously, though... I've heard your springs, man... That's got to be the absolute worst case I've ever heard... and not just on this truck... on ANY vehicle.
Have you tried talking to anyone at your dealership? This might be an OEM replacement issue... Mine squeak once in a while and only under certain conditions... Yours are really bad, man. I feel for ya. It would drive me insane too, if my vehicle were so new and this was that bad.
Blackbeauty is online now   Reply With Quote
Old 08-25-2009, 06:53 AM   #3 (permalink)
beason's Avatar
iTrader Score: 9 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
Re: At wits end
what about a dry spray lubricant like dry ice spray or something. it doesnt attract dirt but should shut it up.
Ever growing mod list here
WhinyWhore™
Originally Posted by The Urinator™
before flapping your feed trap use your think blob
beason is offline   Reply With Quote
Old 08-25-2009, 07:07 AM   #4 (permalink)
Re: At wits end
I’m dropping it off at the dealership tomorrow. I’m hoping they don’t go the "Its your lift kit causing it" deal. I know some have received new springs under warranty because they were not coated properly, hopefully I will have the same luck.
While Im there Im going to ***** some more about the brakes. They wont shut up either. Rotors have been turned once, and had them look at the brakes on 2 other occasions. The rotors are glazed big time. Again. Need to get this resolved as well. Squeaks and squeals make not a good sounding truck!
As for the dry stuff, yes that will shut them up for a bit, but Im looking for a permanent fix to the issue. Perfection baby!!
Mods
Old 08-25-2009, 07:24 AM   #5 (permalink)
pipho's Avatar
iTrader Score: 8 reviews
Re: At wits end
On my F150 I had the same exact problem, cleaned them out every week and had to lube them EVERY week just to quiet them for the a little bit. I ended up buying whole new leaf packs and it fixed it for maybe 3 weeks then it was back. I got so fed up with it after that that I traded it in on my altima. All I can figure is I had bent the frame and it was tweaking the leafs just right to cause them to rub all the time. That truck had seen some air and a bent frame is all I could think of after a whole new pack was put on. Post up what the dealer says!
pipho is offline   Reply With Quote
Old 08-25-2009, 08:50 AM   #6 (permalink)
dc_909's Avatar
iTrader Score: 4 reviews
Re: At wits end
In my opinion its the shims between the leafs, it is why most say to lube it up, for most of the time its an easy fix, but not a cure all one.
I think there was a few people that took their trucks in for the dealer to replace the shims, and it solved it for them, myself I have not had this issue yet.
Good luck getting this fixed though!
2008 Blizzard SE KC - OEM 20's - Banks Catback - Bully Dog Reg. Tune +2* - DDM 6k HID's Upper-Lower - Bilstein 5100's Front and Back
dc_909 is offline   Reply With Quote
Old 08-26-2009, 07:50 AM   #7 (permalink)
Re: At wits end
Took it to the dealership, and it seems everything associated with the springs are borked. The shims, brackets, shackles... everything.
They ordered me a complete new set and new hardware to mount it.
YAY Warranty’s!!
As for the brakes, the rear pads have an unknown issue. Even with 28k miles on them, they are replacing them under warranty as well.
This is the first dealership I can honestly say, I like to do business with.
Mods
Old 08-26-2009, 08:05 AM   #8 (permalink)
Kronos1965's Avatar
iTrader Score: 0 reviews
Re: At wits end
Glad to read it's being fixed.
I have the squeaks as well but I'm out of warranty.
Grease, shims, and perhaps better shackles for me!
HippieWhore™
Be the kind of person your dog thinks you are.
Kronos1965 is offline   Reply With Quote
Old 09-01-2009, 05:17 AM   #9 (permalink)
Re: At wits end
Got the new spring pack in and installed. Shes finally quite in that department.
Finally.
Any Georgia or Alabama folks having issues with their dealership, I suggest Rob Doll in Columbus, Ga. They do great work, don't try to hose ya over, and will give you the benefit of the doubt when working with things you have modded.
Mods
Old 09-18-2009, 04:24 AM   #10 (permalink)
Re: At wits end
have the same thing. with all the dirt and crap that's in there, i just turn the radio up
me->
'05 4x4 SE KC
35" terra grapplers
leveling kit
an a whole lot of mud
mad8vskillz is offline   Reply With Quote
Old 09-18-2009, 05:01 AM   #11 (permalink)
54warrior's Avatar
iTrader Score: 1 reviews
Re: At wits end
I have not had any issues since spraying mine awhile back with Dupont® Teflon© Dry-Film Lubricant™ from Lowes®. I used a ton of it in between each layer.
Truck: 05 CC SE 4x4
Performance/Drivetrain: Stock w/ 2* Advance, PRG Driveshaft Spacer, PRG Street Traction Bars
Suspension: PC 6", SAW Coils, Bilstein 5125's, Total Chaos Shackles, removed anti-sway bar
Wheels/Tires: Kumho MT KL71 35x12.50-18, KMC XD Addict's (Machined)
Brakes: Stock w/ PRG Stainless Lines (Front)
Lighting: (3) Hella 500 Driving Lights
Misc: Husky Liners, Bug Shield, Tonneau, Bed Liner'ed Rockers, Home-Made© Skid Plates, Vent Visors
Advertisement
At wits end with front suspension noise....HELP ANYONE!! MIAPLAYA Titan Suspension 16 07-15-2009 12:11 PM
what will i end up with kingpintitan Titan Performance Modifications 12 04-22-2009 03:14 PM
I am at wits end... ALtitan Titan Wheels, Tires & Brakes 6 04-15-2009 08:14 PM
WTT chrome front end for black front end billaj Buy/Sell 3 06-21-2008 08:07 PM
Please never end up like this... Joshj84 Titan General Discussion 3 01-16-2007 10:40 AM
SEO by vBSEO 3.3.2
