What are you guys running for bump stops on your trucks? Hooli told me to run Timbren Bump Stops but I can not find them for a titan anywhere.. I was informed that PRG is a distributer but they are not on his page for some reason. What is everyone else running?
I have radflo bump stops in the back and they were like 170 each... and they had to be welded to the frame and made to hit a pad on the leaf spring right above the axle... Im going to be doing the front soon too, and I have the hydraulic ones...
The rubber ones like timbren are probably the way to go with a basic setup. No I dont have bumps in the front or rear. I hate to tell you this blk but you shouldnt have taken your truck to DMZ, they are way too expensive.
yes, they are way expensive, but im pretty sure they do some bomb *** work if they charge that much..... and im going to shop around before I do my bed cage...... where do you get ur stuff done and how much was your shock hoop ???
....A bunch of stuff..... And lots more to come
any idea where I could get some timbren ones? I have a basic set up nothing special so they will work just fine
Hey guys., new here. All the way From Canada!! Quick question. Im lifting my truck with procomp 6". Haven't order it but I found one on ebay for 1300. My question is... on a stock truck, does the front rubber bump stops allways touches between the controlarm and frame? Mine is allways touching. Just wondering if there should be a gap there when its not moving. Also the truck was used to plow snow.
I have a 2wd and they don't touch all the time. 4wd or OR package may be different.
2006 SE, CC, Big Tow, white
Born 5/06
