Leveling kit help! - Nissan Titan Forum
Old 09-15-2009, 09:29 PM   #1 (permalink)
Colten K's Avatar
iTrader Score: 1 reviews
Leveling kit help!
will the stock shocks work on a 2.5 inch front leveling kit? its on a 2005 4x4 OR. thanks guys. i dont have the time to search and get no where.
Colten K is offline   Reply With Quote
Advertisement
Old 09-15-2009, 09:45 PM   #2 (permalink)
salstats's Avatar
iTrader Score: 10 reviews
Re: Leveling kit help!
yes you can use the stock shocks...recommend to buy bilsteins later for a better ride quality
2008 SE 2WD: Maxtrac 4" Spindle Lift with 2" Block, PRG UCA, PRG Shackles. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. AirAid MXP CAI, Custom 3" Banks Catback Exhaust dumped, BullyDogGT Window Roll up Mod,
salstats is online now   Reply With Quote
Old 09-15-2009, 10:21 PM   #3 (permalink)
Colten K's Avatar
maybe in the future! but the stock ones will be long enough for a 2.5 level kit?
Old 09-15-2009, 10:29 PM   #4 (permalink)
salstats's Avatar
Talking Re: Leveling kit help!
yup they should maybe you will later wanna install PRG UCA's since if you hit a pretty steep lump you can get bucket contact..other then that have fun...
Old 09-15-2009, 10:37 PM   #5 (permalink)
NorCal 4x4's Avatar
iTrader Score: 4 reviews
The 2.5" kit is for a 2wd, so coil bucket to stock UCA contact is much more likely than if you buy the correct level kit for a 4x4, which is the PRG 2". For more apparent front lift you should consider the PRG shackles that can be set at 0, 1/2", or 1" rear drop.
And you will eliminate the chance of the stock leaf shackles unrolling at the crappy welds, and having your leaf spring tear up through your bed. The new Titan shackles are better than the old ones but won't adjust for drop.
Old 09-16-2009, 02:56 PM   #6 (permalink)
Colten K's Avatar
well i also got 1.5'' rear blocks.
Old 09-23-2009, 01:15 AM   #7 (permalink)
iTrader Score: 0 reviews
anyone know how to put the blocks on the rear? i ordered the kit from PRG but there was no instructions how to do the rear.
thepman is offline   Reply With Quote
Old 09-23-2009, 05:52 AM   #8 (permalink)
AZPRO4X's Avatar
iTrader Score: 7 reviews
Put something in front of the front tires so the truck doesn't roll then unbolt the bottom bolts on the shocks and then the U bolts, jack the back of the truck up ( I used the hitch as my jacking point ). You might have to hit the shackles with a hammer to get the axle to separate then put the blocks on. I had to put a few peaces of wood on my jack to get the back end to go high enough but that's it.
08 Pro-4x moonroof,Tow,DVD,SWB,BullyDog Pup,Banks Monster Exahust, Brute Force intake, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,325/65R18 Goodyear Duratracs,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline   Reply With Quote
Old 09-23-2009, 02:10 PM   #9 (permalink)
thank you very much!!!!!!!
Advertisement
WTB: PRG Titan Mini Lift Kit or Leveling Kit Ern3 Buy/Sell 7 03-24-2009 07:14 AM
mini lift kit Vs. leveling kit? mike-p Titan Parts & Accessories 12 10-17-2008 12:47 PM
Opinions on a drop kit or leveling kit MrJonMan Titan Suspension 2 12-09-2007 01:25 PM
Leveling kit with lift kit CV Titan Titan Suspension 6 03-24-2006 02:21 PM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 07:16 PM
SEO by vBSEO 3.3.2
