SAW Top Hat "Clank" - Nissan Titan Forum
Old 09-24-2009, 03:31 PM   #1 (permalink)
Pops's Avatar
iTrader Score: 1 reviews
Thumbs up SAW Top Hat "Clank" - FIXED
I was getting a very slight clank tapping sound as the truck's weight shifted while articulating. I figured it might be the SAW Tophat problem that's been posted on here numerous times so I tightened the bolts down, still clanking, tightened some more and quickly snapped one in half. So yea,the bolts were plenty tight enough.
Soooo, I went down to ACE hardware to pick up a replacement Grade 8 bolt and went ahead and got some split washers to try out too. Being that the backside bolts are so dadgumned hard to get to, I only put the split washers on the two easily accessible bolts on both sides for now.
Lo & behold, the friggin' sound is GONE!!!! No more noises at all..... I hopped over a 1.5' tall parking lot curb last night just to make sure and sure enough, not a single peep.
So I called Greg earlier today to let him know and he said he's gonna start including them with the SAW orders for good measure. So for you guys getting the SAW Tophat clank, pick up some of these to put on the bolt side and see if they fix the problem for you too.
This fixed mine:
2005 Armada LE 4x4
The Following 2 Users Say Thank You to Pops For This Useful Post:
themaildude (09-24-2009), vilim12 (09-24-2009)
Advertisement
Old 09-24-2009, 06:04 PM   #2 (permalink)
AZPRO4X's Avatar
iTrader Score: 7 reviews
Re: SAW Top Hat "Clank"
good catch pops....
08 Pro-4x moonroof,Tow,DVD,SWB,BullyDog Pup,Banks Monster Exahust, Brute Force intake, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,325/65R18 Goodyear Duratracs,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline   Reply With Quote
Old 09-24-2009, 06:18 PM   #3 (permalink)
themaildude's Avatar
iTrader Score: 4 reviews
Thanks Pops. Don't have the problem but good to know if it develops.
IRC CREW MEMBER
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 09-24-2009, 07:17 PM   #4 (permalink)
yamatitan's Avatar
iTrader Score: 0 reviews
My saw's came with those? Guess I got lucky......
EDIT: or maybe it had something to do with my aluminum top hat instead of the steel one.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Money wasted so far=$11745.00
Old 09-24-2009, 07:57 PM   #5 (permalink)
WhiteTitanSe's Avatar
iTrader Score: 3 reviews
yeah all the saws Ive intstalled came with those as well..... either way good catch pops!
2004 Nissan Titan
14" BulletProof Lift
3" Perfromance Acessories Body Lift
Radflo Coilovers
Fox coils, Intake
FlowMasters
2* Timing Adv
NFab Trac Bars
Devion 2*Pinion Shims
4" Blocks
10" Atlas Sring Pack
Bushwacker Pocket Flares
BHLM 12k HID's 3,5k Fog Lights
2 10" Diamond Audio subs
Pioneer Avic D3
Stillen Diff cover
20X14 Fuel Hostages w\ 2.0" wheel spacers
40X15.50X20 Toyo Mts
Awaiting.... QX front end swap, Borla Headers, Amp steps... I quit...
WhiteTitanSe is offline   Reply With Quote
Old 09-24-2009, 08:00 PM   #6 (permalink)
Pops's Avatar
Maybe I'm wrong but from the replies, does it sound like maybe that might explain why some have the clank and others don't??
2005 Armada LE 4x4
Old 09-25-2009, 03:59 AM   #7 (permalink)
54warrior's Avatar
Haven't had any issues with any clanking. Not sure if mine had the lock washers or not, it's been so long.
Truck: 05 CC SE 4x4
Performance/Drivetrain: Stock w/ 2* Advance, PRG Driveshaft Spacer, PRG Street Traction Bars
Suspension: PC 6", SAW Coils, Bilstein 5125's, Total Chaos Shackles, removed anti-sway bar
Wheels/Tires: Kumho MT KL71 35x12.50-18, KMC XD Addict's (Machined)
Brakes: Stock w/ PRG Stainless Lines (Front)
Lighting: (3) Hella 500 Driving Lights
Misc: Husky Liners, Bug Shield, Tonneau, Bed Liner'ed Rockers, Home-MadeŠ Skid Plates, Vent Visors
Old 09-25-2009, 05:22 AM   #8 (permalink)
Juday's Avatar
Did the clank happen when the shock was being compressed, or on the rebound?
2012 RAM Power Wagon
285/75R17 BF Goodrich T/A KM2s | Carli Front Differential Cover | Aluminess Front Bumper | Aluminess Rock Sliders | PIAA 540 Fog Lights
Old 09-25-2009, 06:40 AM   #9 (permalink)
Pops's Avatar
Neither / Both..... It was more like it was sliding over when moving onto a sideways hill then if I went onto an opposite angled hill, it sounded like it was shifting to the other side of the coil bucket. It sounded like an aluminum tapping / tinging. At first I thought a drop bracket bolt might be loose and the drop bracket was shifting so I rechecked them all. Then it dawned on me that the coilbuckets are thin steel and make that same exact sound. Then I remembered the bolts are significantly smaller than the bolt holes so I went to tighten them more.
2005 Armada LE 4x4
Advertisement
Soft Camper Top "SuperTop" k5goose Titan Parts & Accessories 21 02-19-2011 09:38 AM
F/s: Kmc "diesel" Wheels Cheap!, *****Brand New 18"x10" Chrome***** WICKEDOWESIX Buy/Sell 39 10-18-2009 09:20 AM
Changed front and back emblems from "Nissan" to "Titan" FLfinfan Titan General Discussion 13 07-24-2009 01:08 PM
6" procomp lift and loud clank!!! Duprizee16 Titan Suspension 10 04-16-2009 11:47 AM
2" spacer on top of coilover Taylor Titan General Discussion 4 12-30-2006 07:11 PM
SEO by vBSEO 3.3.2
