Old 10-07-2009, 09:48 PM   #16 (permalink)
Re: Just Ordered Lift Kit!!!!
where can i get this drive shaft spacer from?
2006 Nissan Titan SE 4x4
ProComp 6" Lift, 20" American Racing Teflon Punishers, 35" Trail Grapplers,Volant CAI, 2xKicker Solarbarics, Sony X-Plode 1200 watt
a_cent11 is offline   Reply With Quote
Old 10-09-2009, 06:21 PM   #17 (permalink)
yamatitan's Avatar
You have to call prg its not on the site.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 10-13-2009, 06:10 AM   #18 (permalink)
Got it installed with a buddy yesterday!! I'll clean it up and take more pics when I get the wheels and tires on
Old 10-13-2009, 10:06 AM   #19 (permalink)
Send a message via AIM to Alwaysbeingdumb
Looks good man.
"Your Not Lost ....Your Just Off Roading."
Mods:
130 Watt KC Day Lighters, Dual Magnaflow Exhuast, Burn Out Mod,10000k 55 Watt HIDS, Fujita F5 Intake, 2* Advance, 4" CST Spindles, DR Coilovers, 2.5" Deaver pack, 3" blocks, Pro-Comp rear shocks, Pro Comp 10" Subs (BLOWEN Kenwood Amp), 6X8 Infinty Speakers, Sony Ipod Ready HU, Flat Black OEM Rims.
I NEED CHROME BT!!
Alwaysbeingdumb is offline   Reply With Quote
Old 10-13-2009, 10:21 AM   #20 (permalink)
grnTitan04's Avatar
Some day I'm gonna a start a thread with this title.
Some day...
Oh yeah, your truck looks good man.
Improvements:
NCD Level Kit|K&N Drop In|Magnaflow muffler|Step Tubes|Reese Hitch|Husky Liners
Nitto Terra Grapplers 285/70/17|Extang RT Tonneau|RadFlo Remote Res Rears
OEM Hood Deflector|Hayden 405 Transmission Cooler
Air Box mod|Improved Fog Light Mod|dba 4000 series rotors, Akebono ProACT pads
Axle Vent Mod
Fluids, Etc.:
Engine: Penzzoil Platinum 5W-30, K&N HP1010 Oil Filter, K&N 33-2286 Air Filter
Differentials: (F)Royal Purple 75W-140, (R)AMSOil 75W-140
Transmission: Castrol Multi-Vehicle Import
Wish List:
Air Horn, RadFlo 2.0 Coilovers, AEM Brute Force CAI, TruTrac, Bass boat...
Donations graciously accepted.
grnTitan04 is offline   Reply With Quote
Old 10-13-2009, 10:24 AM   #21 (permalink)
Looks really sharp!! I get mine this week hopefully. If not, then the week after. So did you end up using the spacer for the drive shaft??? Is that factory tires on the picture? Im actually going to leave my tires on till I have to replace them. it looks good with the factory tires!!! Let me know about the spacer. BTW the truck looks level did you have to put anything else on the back to level it or the lift does it all?
mingosuzuki is offline   Reply With Quote
Old 10-13-2009, 11:51 AM   #22 (permalink)
No its just the basic procomp, I eventually want to get coilovers and deavers in the back. I called PRG and Greg said to install the kit as is, ride around for a while and then decide what I want to do. But as of now I am satisfied and it sits pretty level. with the procomp if you have an 07-present titan than you are going to sit a little higher in the front like the case with my friend who has the LWB titan. I think I'll get the spacer when I get the rest of the stuff and go a little higher in the rear. Those arnt fatory tires but they are pretty close to factory size only slightly bigger
Old 10-13-2009, 02:13 PM   #23 (permalink)
T-Dog23's Avatar
looks like the same packaging I got!!!!! You must be excited!!!! I know i WAS!!! Eventually.... I recommend getting the coil-overs.
2008 Titan 4x4 SE, 6" procomp stage 2 lift (coil-overs and MX6 ajustable shocks), 35" Procomp xtreme M/T tires, 20x10 Black Rockstars, volant cool air intake, blacked out.
T-Dog23 is offline   Reply With Quote
ordered the prg mini lift kit dkeenum2 Titan Performance Modifications 1 08-31-2008 09:31 PM
Ordered my PRG kit TitanZX Titan Suspension 5 10-12-2006 03:57 PM
Finally ordered the Mini-Lift Kit!!!! rsaylor2682 Titan Suspension 11 12-03-2005 08:54 PM
Another PRG kit ordered, with one ??? t22a80 Titan Suspension 6 12-02-2005 12:00 PM
Just ordered my PRG kit!!! antwon412 Titan Visual & Audio Discussion 5 06-20-2005 08:35 PM
