Old 10-01-2009, 09:34 PM   #1 (permalink)
05 4x lift
I have a 05 4x4 with bilstein 5100's in the front set to the lowest spring preload position with 08 pro x front springs. Any reason i can not use a rough country 3" front kit and a 1" rear block. Please no responses recomending a prg kit. I tried to order a prg kit 3 calls 3 messages with no return call .
kyle797 is offline   Reply With Quote
Old 10-02-2009, 02:17 PM   #2 (permalink)
ostafadobo's Avatar
Re: 05 4x lift
I say GO FOR IT! I thought about this setup too. I have a set of 5100s waiting for install but I can't decide what to do. Stacking the RC 3" kit on top of Bilstein 5100s set at 1" is a fairly new setup that peeps are starting to do so it's kind of in that trial and error phase ($icktitan was 1st IIRC). I think you'd be the first pre 08 4x4 w/ the 5100s set at 0 w/ 08 coils and the RC 3" kit... It'd be pretty cool if you were the guinea pig and reported back! From my "calculations" it'd be something like 3.25"-4" of lift w/ that setup.
Leveling a pre 08 4x4 w/ 5100s and 08+ coils is about 1.5" give or take
RC 3" kit gives you about 2.5" give or take
Now we have to wait and see how the RC UCA perform with the stacking. I want to know how they handle the 3"+ of lift (coil bucket contact, droop, travel, etc.). If the more expensive UCAs (PRG, Camburg, TC) handle this better I may go with a frankenstein setup. 5100s, 08+ coils, spacer & PRG UCA... or skip the coils and go w/ a taller spacer.
BTW sorry I didn't answer your ?
Follow this: Adjustable shocks
06 Granite SE KC 4x4 OR BT
Superchips
07 pipes w/ 18" Mag
CAI
Tints
D*ck Cepek Crushers 285/70/17
Tech12 goods
ostafadobo is offline   Reply With Quote
Old 10-02-2009, 02:30 PM   #3 (permalink)
Pops's Avatar
Re: 05 4x lift
PRG... PRG... PRG....
- hehe
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-03-2009, 01:42 PM   #4 (permalink)
Re: 05 4x lift
I called them three times and left 3 messages over the period of 1 week. I am all set with prg I went and ordered the rc arm kit
Old 10-04-2009, 12:30 AM   #5 (permalink)
ostafadobo's Avatar
Re: 05 4x lift
keep us posted on your setup... w/ pics
Superchips
07 pipes w/ 18" Mag
CAI
Tints
Tech12 goods
Old 10-05-2009, 01:41 PM   #6 (permalink)
Pops's Avatar
Re: 05 4x lift
hehe - I was just playin' with ya.... The RC kit looks pretty sweet from those who've installed it so far.
2005 Armada LE 4x4
Old 10-08-2009, 05:02 PM   #7 (permalink)
$ickTitan's Avatar
Re: 05 4x lift
I like the RC setup. I just ordered CST 4'' spindles and I'm going to keep my Rough Country UCA's and spacer but put the bilsteins back down to 0'' preload (~6.5-7'' of front lift). It rides great now, should be even better with no preload!
2006 Titan Crew Cab LE
Exterior: 20X10 Moto Metal 951's Black, 305/55/20 Nitto Terra Grapplers, RBP RX Series 3 Piece Grille, NFAB's, DDM 6000k HID kit.
Performance: Superchips Tune, S&B Cold Air Intake, Flo-Pro Max Muffler with Corsa Tip.
Audio/Interior: JVC KW-AVX810 Touchscreen DVD Player, Rockford Fosgate Power Series 6.5'' Components, Tech12Volt Enclosure with 2 10'' Boston G1 subs, Rockford Fosgate P200.2 Amp, Carbon Fiber Interior Kit.
Suspension: CST 4'' Spindles, SAW Coilovers, Deaver C30 (2.5'') mini pack, 2.5'' Block, Radflo remote reservoir rear shocks, PRG CBDB.
$ickTitan is offline   Reply With Quote
Old 10-08-2009, 07:58 PM   #8 (permalink)
adkl1's Avatar
Re: 05 4x lift
I like mine !!!
08 Pro-4x moonroof,Tow,DVD,SWB, Airbox mod, 3" RC Kit,35/12.50 Kumho KL71's ..melting in Chandler, Az
Installed 5100 Bilsteins in the rear & waiting for the fronts to come in !!
adkl1 is offline   Reply With Quote
Old 10-10-2009, 07:53 PM   #9 (permalink)
Re: 05 4x lift
looks like it won't work. I am in the middle of the install and there is severe contact with the coil bucket and not on the lip but the upper side of the bucket and the cross brace below the front mounting piviot. I suspect that the bilstein 5100 is a little bit longer than the stock shock i think i will need a shorter strut spacer the rc spcer is 1.5'' in lengti I bet i need a 1.00'' or 1.25'' spacer
Old 10-10-2009, 11:16 PM   #10 (permalink)
blk04titan's Avatar
Re: 05 4x lift
take that spacer out then
....A bunch of stuff..... And lots more to come
blk04titan is offline   Reply With Quote
updated pics:mini lift+body lift chieflikalotapus Titan Pictures & Media Post 62 01-09-2009 08:27 PM
planned 2wd PRG lift - few questions / pics of old lift for entertainment ;) FaintReality Titan Suspension 13 11-16-2008 09:57 AM
What body lift could I use with a pro comp 6" lift? texas t Titan Suspension 9 04-09-2008 04:49 PM
Pics of PRG 9" Lift and Fabtech Lift NCOREY Titan Suspension 15 03-16-2008 09:01 AM
which is the better lift the rancho 4inche or the fabtech 6inche lift titankid88 Titan Suspension 4 11-28-2007 09:15 PM
