View Poll Results: best company that has or does make a kit for our t's
CST 1 6.25%
NCD 0 0%
PRG 10 62.50%
CAMBURG 5 31.25%
Voters: 16. You may not vote on this poll
Old 10-05-2009, 10:14 PM   #16 (permalink)
bradbury's Avatar
Re: long travel or mod travel anyone?
Well i bought the shocks myself and yes they are 10'' saw. I also cut part of the inner fender out right above the shock mount to get more room.
Ride baby ride.
bradbury is offline   Reply With Quote
Old 10-05-2009, 10:19 PM   #17 (permalink)
rynomx785's Avatar
The reason I ask is I had horrible time getting my 10" coilover in there. I had to have the shock hoops done twice. Mine are just about touching the fender well. When they were lower than that I wasnt getting all my bump travel that I could. Even when the coilover was fully compressed it was too long. Like I said Im not doubting you Im just curious.
rynomx785 is online now   Reply With Quote
Old 10-05-2009, 10:27 PM   #18 (permalink)
CL 8 2WD's Avatar
Can we please get a bigger pic
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 10-05-2009, 10:29 PM   #19 (permalink)
bradbury's Avatar
Ya this was my second time also the first time i had 8'' saw and i wasnt getting the full potential so i got 10'' and it was alot harder to mount them and i do my own shock hoops so it has been alot of work.
Ride baby ride.
Old 10-05-2009, 10:35 PM   #20 (permalink)
CL 8 2WD's Avatar
So give us a BIG pic so we can see your handy work
Old 10-06-2009, 11:23 AM   #21 (permalink)
rynomx785's Avatar
Originally Posted by pgthe1 View Post
CST LT kit... Strapped at 17" a new UCA will get me another 2" before the lower will bind... but I'm good @ 17" for now. Using 10" shocks. If the Burg kit was out at the time I got this 1... it would have been burg for me.
Are you running the that little SAW helper spring? What is the purpose of that? I was messing with one a few weeks ago. You can compress it completely with your hands.
Old 10-06-2009, 11:31 AM   #22 (permalink)
pipho's Avatar
Its to keep tension on the main spring at full droop without messing with the over all spring rate, its for shorter springs on long shocks
08 Pro4X PRG front n rear
pipho is offline   Reply With Quote
Old 10-06-2009, 11:33 AM   #23 (permalink)
rynomx785's Avatar
I'm suprised that it keeps enough tension on the main spring. Those things are super soft.
Old 10-06-2009, 11:34 AM   #24 (permalink)
pipho's Avatar
just enough so the coil isnt slapping around at full droop
Old 10-06-2009, 11:38 AM   #25 (permalink)
rynomx785's Avatar
What would be the benefit of that as opposed to running the nut all the way down the main spring?
Old 10-06-2009, 11:50 AM   #26 (permalink)
pipho's Avatar
[quote=rynomx785;1875858]What would be the benefit of that as opposed to running the nut all the way down the main spring?[/QUOTE
its hard to explain I would need to show you but it has to do with using all the shocks travel with a shorter spring. Im not real good with this Im still learning too correct me if im wrong but say your springs short(theres reasons for a short springs too) if you thread the adjuster down so at droop the spring is still tight, then at ride height most of the shocks droop is already used, using a helper spring allows you to set your ride height right in the middle of the shock stroke with out the shorter spring becoming loose and flop at full droop, yet its light enough it doesnt mess with your overall spring rate. Next class we will learn about setting up dual rate stoppers, haha not really Im still trying to figure those out.
Also threading the adjuster down so the spring is tight at full droop would make a super tall ride height
Old 10-06-2009, 05:06 PM   #27 (permalink)
CL 8 2WD's Avatar
Pete runs the shorter spring so he can get a lower ride height.
And as said, the small spring keeps the main spring from moving around during suspension articulation
CST long travel.... gilroyboy Titan Pictures & Media Post 40 10-14-2009 10:25 PM
?????Do you want a LONG TRAVEL kit????? A.I.I.Raciing Titan Suspension 36 10-04-2009 03:35 PM
Long Travel Done!!!!!!!!!!!! cst silver Titan General Discussion 208 03-31-2009 07:44 PM
long travel????? cst silver Titan General Discussion 70 03-01-2008 11:04 PM
PRG Long Travel TheHammer Titan Suspension 5 12-06-2006 12:03 PM
