Old 10-04-2009, 03:35 PM   #1 (permalink)
TechTITAN08's Avatar
Want to lift my 08 4"
Wanting to lift my 08 2WD, but don't have enough to afford the 4" lift, so I'm curious, whats the most cost effective way to lift the truck about 4"? I only take this truck out off road during deer season and most of the trails are pretty tame.
Thanks guys
2008 Galactic Black Titan
Performance:
2* Timing Advance
Flowmaster Super 40
Flashpaq
Air Filter
Visual:
4" Dual Black Chrome Tips
Dyno #'s Before Tune
291.21 RWHP
333.79 lb/ft Torque
TechTITAN08 is offline   Reply With Quote
Old 10-04-2009, 09:45 PM   #2 (permalink)
Re: Want to lift my 08 4"
Bump for some info...
Tried searching and I know nothing about suspension so somebody help me out here!
Performance:
2* Timing Advance
Flowmaster Super 40
Flashpaq
Air Filter
Visual:
291.21 RWHP
333.79 lb/ft Torque
Old 10-04-2009, 09:54 PM   #3 (permalink)
rynomx785's Avatar
This is gonna be your best bet. PRG Products
Old 10-04-2009, 09:54 PM   #4 (permalink)
louie.medina3's Avatar
What are you a 2wd or 4wd, if you have a 2wd I would say a PRG mini lift. Not to sway of topic but every time I look at the mini lift it seems to go up in price it now at 1,200. When I first saw it it was priced at 899.
2005 Nissan Titan 4x2 CC
MODS
3" level, Bilstein Shocks, BFG KO 305/65/R18, Magnaflow Exhaust, Air Box Mod, Blacked out OEM 5 spoke rims, TB bypass,Headlight Mod, Smoked tail lights, Custom grille, Blacked out center console and Radio, rear fog lights
louie.medina3 is offline   Reply With Quote
Old 10-04-2009, 09:55 PM   #5 (permalink)
rynomx785's Avatar
It says 2wd in his first post.
Old 10-04-2009, 10:35 PM   #6 (permalink)
I have been looking at the PRG website and the minilift is only $250. The CST 4" spindle is at 899, and I guess what I'm asking is if there is way to achieve a 4" lift without shelling out near 1k.
Thanks for the input guys
Performance:
2* Timing Advance
Flowmaster Super 40
Flashpaq
Air Filter
Visual:
291.21 RWHP
333.79 lb/ft Torque
Old 10-05-2009, 12:19 AM   #7 (permalink)
Irish125's Avatar
You could probably go with a spacer on top of some bilstein 5100s? That would get you close but people have said the ride is quite harsh if you set them to sit at the higest lift.
'08.5 SE KC
Irish125 is offline   Reply With Quote
Old 10-05-2009, 12:31 AM   #8 (permalink)
Jiro's Avatar
Cheapest way would be mini-lift and body lift??? If not then I can't think of many other cost-effective options besides the spindle lift. If you can live with just a 3" lift though, check out the rough country 3" front lift. It comes with spacers and uca's for an unbeatable price of around $260 I believe and then get some 1" rear blocks. That might be your best bet
2008 blizzard Pro-4x cc swb
Jiro is offline   Reply With Quote
Old 10-05-2009, 01:15 AM   #9 (permalink)
Jiro's Avatar
Ok, techtitan08 here is the reason why the spindle lift is actually a good choice for what you want. When you add an excessive amount of space between your upper control arms and lower control arms, you will increase the angles of the arms. This WILL result in coil bucket contact (requires new uca's approx. $200-600) and may have issues with your sway bar endlinks being too short (longer ones are about $80). Also you can't just buy 4" spacers so you would need spacers + height adjustable shocks, or coilovers. That would more than likely harshen your ride and not be very cost-effective. Also, the spindle lift give you lots of options to go bigger. However, remember that these options will only raise your front and not the rear. Again, I would reccomend that rc 3" front lift for $260 and some rear 1" blocks which can be had for under $100. Also do not get bigger than 1" blocks if you plan on keeping the stock rear shocks. Hope that helps
The Following User Says Thank You to Jiro For This Useful Post:
TechTITAN08 (10-05-2009)
Old 10-05-2009, 08:49 AM   #10 (permalink)
Is rough country a decent brand? Just haven't heard the name around the forum as much as PRG. The 3" lift sounds good, but are you saying it will only lift the front? And if it does will the 1" block in the rear be enough to make it level?
Performance:
2* Timing Advance
Flowmaster Super 40
Flashpaq
Air Filter
Visual:
291.21 RWHP
333.79 lb/ft Torque
Old 10-05-2009, 09:31 AM   #11 (permalink)
adkl1's Avatar
Yes RC makes quality stuff for a descent price...
08 Pro-4x moonroof,Tow,DVD,SWB, Airbox mod, 3" RC Kit,35/12.50 Kumho KL71's ..melting in Chandler, Az
Installed 5100 Bilsteins in the rear & waiting for the fronts to come in !!
adkl1 is offline   Reply With Quote
Old 10-05-2009, 09:51 AM   #12 (permalink)
rynomx785's Avatar
3" in the front and 1" in the back should have you sitting just about level.
Old 10-05-2009, 07:30 PM   #13 (permalink)
Jiro's Avatar
Looks like rough country makes good quality stuff. Check out adkl1's thread. Lots of details and pics. Yes, btw both the rc 3" and the cst 4" are just for the front.
PRG "Mini Lift" or "Leveling Kit" oktex88 Titan Suspension 8 03-03-2009 09:15 AM
"PRICE REDUCTION"04 Nissan, Titan XE 4x4, ProComp 6" lift, 315/70/17 BFG/AT/KO, DR tillery444 Buy/Sell 2 06-13-2008 10:53 AM
WTB: 4" or 6" 2WD lift kit new/used, 35" tires and 18" wheels Geologist Buy/Sell 3 04-03-2008 06:50 PM
Difference between a 4" rancho lift and 6" procomp lift HDG Titan Suspension 16 02-06-2008 07:22 PM
4" CST lift pics? or any 4" inch lift TheTanMan Titan Suspension 15 01-30-2007 10:28 AM
