Old 10-06-2009, 09:29 AM   #1 (permalink)
rynomx785's Avatar
4wd guys with coilovers
Do any of you 4wd guys that are running coilovers know what spring rate you have?
Old 10-06-2009, 10:15 AM   #2 (permalink)
Pops's Avatar
Re: 4wd guys with coilovers
600-lbs..... You need to get the shocks valved properly to accommodate them or you could be in for a fairly rough ride.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-06-2009, 10:32 AM   #3 (permalink)
rynomx785's Avatar
How much preload are you running on them Pops? They are PRG Spec'd so valving is correct. Pipho has 2.5" of preload on his coilovers just to make the truck sit level. He is considering a heavier spring rate just for some extra ride height without all the preload.
Old 10-06-2009, 10:47 AM   #4 (permalink)
Pops's Avatar
I don't have any preload on them.... My Rear Suspension is maxed out while keeping comfort so I had to crank the SAW's all the way down to be level. The front still sits about 1/4" -1/2" higher than the rear.
2005 Armada LE 4x4
Old 10-06-2009, 10:52 AM   #5 (permalink)
rynomx785's Avatar
Hmm he might have to run a spacer if he wants to be level with out preload.
Old 10-06-2009, 10:58 AM   #6 (permalink)
pipho's Avatar
With the top hat thing that bolts over the coil bucket on the extended travel package I cant do a spacer, Ill just call greg and talk spring rates with him.
08 Pro4X PRG front n rear
pipho is offline   Reply With Quote
Old 10-06-2009, 11:00 AM   #7 (permalink)
Pops's Avatar
I know the Bracket Lift SAW's have an option to have Greg modify the internal spacer for another 1" above the 2" allowable pre-load for 3" total. I assume that the OEM height or Extended SAW's have the same option available.
2005 Armada LE 4x4
Old 10-06-2009, 11:07 AM   #8 (permalink)
54warrior's Avatar
Even with no preload on the shock, the bracket lift coils have about 2" of preload on them:
Originally Posted by PrerunnerGreg View Post
The proper way to measure "preload" is to extend the shock all the way (lift the tire off the ground) and measure the length of the spring in that position. The bracket lift coilovers use a 16" long spring and the non-bracket coilovers use a 14" spring. The BL units get more preload just to get the springs on the body. Typically you will have around 2" of preload...or 1400lbs of tension at droop. The spring actually compresses the same weather you have a lot or very little preload, the vehicle weight is what determines how far the spring will compress at ride height. The better ride comes from allowing the wheel to follow the road better with more droop or extension.
2005 Nissan Titan CC SE 4x4
The Following User Says Thank You to 54warrior For This Useful Post:
Pops (10-06-2009)
Old 10-06-2009, 11:36 AM   #9 (permalink)
pipho's Avatar
reached greg first try, going to run my coilover under the bucket and try it if not its on to a 700lbs spring.
How bad do the 4WD guys want gears front and rear? Yellomantis Titan Engine, Transmission & Drivetrain 34 04-21-2009 11:35 PM
new your guys' opinion on new coilovers... hearne06 Titan Suspension 17 01-03-2009 02:05 PM
08.5 Titan 4wd vs. 06 Ford F150 4wd bigboytitan Titan Towing & Hauling 12 05-16-2008 11:26 PM
Fabtech Dirt Logic front coilovers or Radflo 2.0 Coilovers NCOREY Titan Suspension 3 02-18-2007 10:56 PM
Fabtech coilovers new 4wd CDubya Buy/Sell 14 02-27-2006 07:43 PM
