Old 10-11-2009, 11:31 PM   #16 (permalink)
Colten K's Avatar
Re: HELP! pictures included.
since i put the lift in the steering it a litte tougher is this normal? nothing major just a little stiffer.
Colten K is online now   Reply With Quote
Old 10-12-2009, 05:45 AM   #17 (permalink)
CajunTitanMac's Avatar
Send a message via Yahoo to CajunTitanMac
Why did you remove the tie rod end, i don't know of a kit that requires this.... i know you should have to remove the swaybar end links, but never heard of removing the tie rods ends?... just my $.02....
Layne "MAC" McFarland
3rd Coast Titans
Louisiana Chapter & Crew President
ChickFlickWhore
click here for my mods list
CajunTitanMac is offline   Reply With Quote
Old 10-12-2009, 09:18 AM   #18 (permalink)
Colten K's Avatar
The kit i got Da*m Pro-Comp didnt have instructions so i was doing it by the internet and what looked i had to do. and since i dont have a coil compresser it was also harder to get the shock/coil out of the coil bucket! I got everything back together now and it rides perfect so, what i did seemed to work but probbally just took a bit longer,
Old 10-12-2009, 09:36 AM   #19 (permalink)
yeah... you don't need a coil compressor to get the strut out... just takes some persuasion... i got mine in and out with a little help from a few taps with a small mallet...
3rd Coast Titans
ChickFlickWhore
Old 10-12-2009, 09:38 AM   #20 (permalink)
Colten K's Avatar
Yup bassically what we did, but the compresser would have made it a lot easeier but it was fun hahah.
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
34" NItto Terra Graplers
BAck Flip box cover
LED light bar under tailgate
Custom hockey stick shifter
Old 10-12-2009, 01:48 PM   #21 (permalink)
Colten K's Avatar
so since i have 1.5'' in the back and 2.5'' in the front it sure looks like i can rin 35's can i?
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
BAck Flip box cover
Old 10-12-2009, 02:06 PM   #22 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
did you get your front end aligned yet?
you might want to do that......
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 10-12-2009, 02:36 PM   #23 (permalink)
Colten K's Avatar
i was going to do that when i get my new tires on, it doesnt really matter if its out a bit since my tires are shot anyways. I just have to pick a tire now, can i fit 35's??
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
BAck Flip box cover
Old 10-13-2009, 07:20 PM   #24 (permalink)
yamatitan's Avatar
If you keep them on stock rims and do the pinch weld mod you can get 35's under there.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
yamatitan is online now   Reply With Quote
Should I level or keep as is? Pics included. leonag123 Titan Pictures & Media Post 18 09-02-2009 08:17 PM
Help with grille choices (Pics Included).. $ickTitan Titan Parts & Accessories 30 08-14-2009 01:25 PM
What's included with cat-back systems? dank78 Titan Performance Modifications 4 04-10-2007 04:20 PM
What all is included in the 30k Maintenance and how much$ Navi Titan Engine, Transmission & Drivetrain 14 11-05-2006 12:00 PM
Is Ohio included in this forum? Paulphilly Mid West Forum 8 08-27-2005 06:03 PM
