Old 10-12-2009, 02:20 PM   #16 (permalink)
Re: Are Rubber Bump Stops Allways compress?
Originally Posted by Pops View Post
Top Gun Customz is also a site sponsor on here.
Top Gun Customz - Nissan Titan Forum
Your engine problem sounds like it's going into "Limp Mode". I had an O2 sensor go bad on wifey's Murano that caused it to do that. A bad MAF sensor can also cause it and if your Engine Temp Guage is showing Hot, then I'd change the thermostat and flush the radiator for new Antifreeze/Coolant. You might wanna also look at your throttle body to see if it needs to be cleaned up.
I dint know that about top gun customz. what is a maf sensor? temperature shows normal... never showing over 1/2 wouldnt the o2 sensor show a code? Thanks for the tips.
mingosuzuki is offline   Reply With Quote
Old 10-12-2009, 05:47 PM   #17 (permalink)
4mula1fan's Avatar
Yep, those are the Timbrens I spoke of...they work like a charm for what they are designed for. They make the plow trucks very stable...
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up.
Grumpy Old Man Club
http://s3.bite-fight.us/c.php?uid=214743
4mula1fan is online now   Reply With Quote
Bump Stops MXtitan24 Titan Suspension 18 10-11-2009 04:33 PM
Bump Stops? chunko Titan General Discussion 15 12-07-2008 11:09 PM
bump stops please albonismo Titan Suspension 6 02-03-2008 08:45 PM
Bump stops Double Trouble nm Titan Parts & Accessories 3 01-06-2008 09:49 AM
Bump stops? EVO8 Prerunners.com - Titan Leveling Kits 11 05-30-2007 08:26 AM
