Old 10-11-2009, 12:21 PM   #1 (permalink)
blk04titan's Avatar
Need some help with spindles...
has anyone ever heard of using a cst 4" lift spindle with a heim?????
is it even possible or does a fab shop need to do it??
....A bunch of stuff..... And lots more to come
blk04titan is offline   Reply With Quote
Old 10-11-2009, 08:16 PM   #2 (permalink)
loufish's Avatar
Re: Need some help with spindles...
...Where?...Are you talking about the lower pivot, steering?....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-11-2009, 08:31 PM   #3 (permalink)
blk04titan's Avatar
nope, im talking about putting a heim to the uca....
I got an offer from some1 to but my front diff/housing, extended cv's and spindles...
Old 10-11-2009, 08:37 PM   #4 (permalink)
CL 8 2WD's Avatar
You mean to install a heim on a CST 4" lift spindle to work with your NC D UCA I think it should work.
Instead of the uniball misalignment spacer the heim would mount right on top to accept the NCD UCA
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 10-11-2009, 08:43 PM   #5 (permalink)
loufish's Avatar
OK...You're taliking about going to a verticle uni-ball, correct?...
I would think the CST upright would lend itself to verticle ball with the correct "adapter"....
Born 9/2004
2002 Honda XR650R
Old 10-11-2009, 08:57 PM   #6 (permalink)
blk04titan's Avatar
sweet, im gonna call and see how much they can give me one for... so you guys are for sure that it will fit onto this with the right adapter?...
Old 10-12-2009, 09:00 AM   #7 (permalink)
loufish's Avatar
Now I see....you want to drill and tap for a rod end....That's going to be a big drill/tap!....
You would want to pull off the spindle and set it up in a mill/lathe to get it drilled/tapped nice and square...
Born 9/2004
2002 Honda XR650R
Old 10-12-2009, 06:49 PM   #8 (permalink)
blk04titan's Avatar
that doesnt sound fun...
Old 10-12-2009, 09:59 PM   #9 (permalink)
CL 8 2WD's Avatar
Couldn't you just stick it through the top, thread the nut on and tighten just like it was on the stock spindle.
Old 10-13-2009, 04:23 AM   #10 (permalink)
loufish's Avatar
In theroy, yes, but I think the OP needs to run a much bigger rod end then that....The taper adapter runs a 5/8" bolt, correct?....I would think that the rod end would be 3/4" - 7/8"....
I just took another look at one of the pics with a rod end thru a stock spindle....you might be right, maybe it will just bolt straight in...
Born 9/2004
2002 Honda XR650R
Old 10-13-2009, 04:39 PM   #11 (permalink)
blk04titan's Avatar
well i talked to cst and here is what they said...
If you drill out the tapers, that would be the only way.
-----Original Message-----
Sent: Monday, October 12, 2009 10:02 PM
To: CST
Subject: Information Request
Customer Information Request
devin vanasse
none
drowin1@yahoo.com
715-271-1816
hey, I have a nissan titan with the ncd long travel kit (unfortunately) and
I was wondering if your 4\" spindle lift would work with a hiem???
thank you
so I guess id have to drill it, but their cost is 900+ shipping and I talked to our guy from fontana nissan about the camburg spindles and it would cost 1200 for it!!!!!
so if push comes to shove im going to try and get more for my front diff/housing etc. and get the camburg ones!!!!
Old 10-15-2009, 10:22 PM   #12 (permalink)
blk04titan's Avatar
well it looks like the camburg one may not fit and is super expensive...I think im gonna do the cst one..... SO ANYBODY OUT THERE SELLING THEM???????????
Old 10-15-2009, 11:16 PM   #13 (permalink)
loufish's Avatar
What size rod end are you looking for?
They're sized by "Bore" and "Thread"....Many are same bore as thread...3/4" by 3/4".....and others are 7/8" by 3/4" and all the threads are fine pitch....
Born 9/2004
2002 Honda XR650R
Old 10-15-2009, 11:56 PM   #14 (permalink)
blk04titan's Avatar
Im not 100% sure but I think they are both 3/4" and Ill find out for sure tomorrow, im going to camburg after school tomorrow to see if they will fit and to see if I can get a deal on them most likely not though... sooo CST hare I come lol...
darn I wanted a big as camburg sticker to put on top of my front windshield!!!!
Old 11-11-2009, 03:28 AM   #15 (permalink)
blk04titan's Avatar
k, just got my spindles today..... sooo now i need to get the right bung to have welded up on top... im gonna have the top one cut off along with about 2" and then im gonna have the right size bung welded on and im gonna get it guesseted and have the top plated up around the whole for the nut to go in...
sooo where do i get bungs at??? and should I just go to a fabrication shop or somewhere else? like j&s gear where im getting my axle done at???
Spindles blk04titan Titan Suspension 74 09-01-2009 06:35 AM
spindles williamseng1 Titan Suspension 6 02-05-2009 10:07 PM
stock spindles Dimkatitan Buy/Sell 0 11-21-2008 04:50 PM
Just Spindles? nor cal titan Titan Suspension 2 08-13-2007 05:09 AM
Just spindles? nor cal titan Prerunners.com - Titan Leveling Kits 1 08-11-2007 07:17 AM
