Old 10-13-2009, 07:14 PM   #1 (permalink)
need non prg sway links
I need a set of sway bar end links for a 3'' lift to eliminate sway bar roll over.Please no Prg I have had Issues with prg and will not do business with them.
kyle797 is offline   Reply With Quote
Old 10-13-2009, 07:30 PM   #2 (permalink)
yamatitan's Avatar
Re: need non prg sway links
I dont think anyone else makes them, you going to have to do something custom. Maybe call cst and ask for the bracket lift ones and cut them down? Not sure if that possible never seen them in person.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
yamatitan is online now   Reply With Quote
Old 10-13-2009, 07:47 PM   #3 (permalink)
pipho's Avatar
Make your own, other then that your out of luck the CST bracket lift ones wont work.
08 Pro4X PRG front n rear
pipho is online now   Reply With Quote
Old 10-13-2009, 08:05 PM   #4 (permalink)
adkl1's Avatar
used ones from a procomp lift is what im going with. I mocked them up tonight and i think they will work out good, if they end up being to long i will cut a inch off off the middle rod and weld them back with a sleeve..
I just need to cut off that end tab with the bolt...
Or you can just extend the factory one by a 1" the way i did. I drove 52 miles on a very rough dirt road this past weekend fully loaded and the welds held and no flipped swaybar...
08 Pro-4x moonroof,Tow,DVD,SWB, Airbox mod, 3" RC Kit,35/12.50 Kumho KL71's ..melting in Chandler, Az
Installed 5100 Bilsteins in the rear & waiting for the fronts to come in !!
adkl1 is online now   Reply With Quote
Old 10-14-2009, 05:22 PM   #5 (permalink)
mopar's Avatar
Send a message via AIM to mopar
I have some Procomp ones PM me if your interested.
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG OR Traction Bars--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
Detroit TrueTrac---Procomp 6" with Fabtech Coilovers
Soon to be installed Doug Thorely Headers
mopar is offline   Reply With Quote
anyone having problems with sway bar links?? Titster Titan Suspension 24 08-26-2009 11:52 PM
Need New Sway Bar Links ESPARZA4217 Texas Forum 4 03-20-2009 09:26 PM
In need of sway bar links!!! Titster Titan Suspension 1 07-02-2008 08:48 PM
sway bar end links TITANS04 Titan Suspension 1 04-28-2008 06:41 PM
sway bar end links jasonmotox Titan Suspension 6 10-30-2007 02:31 PM
