Go Back   Nissan Titan Forum > Nissan Titan News & Polls > Titan Talk Site Polls
Titan Talk Site Polls This section contains site related polls or polls related to the Nissan Titan. Only administrators may start topics in this section.
View Poll Results: What is the sound after you turn the ignition off?
CD player 12 9.02%
Seat returning to upright position 8 6.02%
Air vent closing 62 46.62%
Who knows? Who cares? 51 38.35%
Voters: 133. You may not vote on this poll
Old 10-29-2004, 08:43 AM   #16 (permalink)
37L1's Avatar
Originally Posted by sammy sandbag
Mine is still doing it immediately after startup, usually after the truck has sat off for a while. It's a strange, almost rattle coming from behind the dash, somewhere between the stereo and column.
Do you have the temp controls set on A/C or defrost at start up? Mine did that until I turned those things off before shutting down the engine. When those things were off I got no strange sound at start up.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 10-29-2004, 05:15 PM   #17 (permalink)
Sammy Sandbag's Avatar
I believe it has done it no matter what the HVAC settings are, I'll check in the morning to be sure. Either way, it doesn't sound like something that should be occuring, and I shouldn't have to adjust my settings to avoid it.
-Counsel Yourself
Old 11-01-2004, 03:32 PM   #18 (permalink)
Davink's Avatar
Hey all,
I checked with my Nissan Dealer, they said that the 6 disk in dash CD changer is basically an elevator inside, and what you hear after you turn off the car is the six different levels "parking" themselves. I am not saying this is gospel, but I used to be heavy into mobile audio, I had about $20,000 in equiptment in a 1994 Tbird as a sound show car,and to be honest it makes sence and that is where I hear the sound coming from on my Titan.
Davink is offline   Reply With Quote
Old 11-01-2004, 11:27 PM   #19 (permalink)
caltitan's Avatar
The only sound I hear is my brother's Silverado finally catching up to me.
2004 Titan SE KC 2WD
Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
caltitan is offline   Reply With Quote
Old 11-02-2004, 01:14 PM   #20 (permalink)
When the 350Z first came out a salesmen told me that the car was so air tight that there was a vent that opened so you could shut the doors easier. Maybe this is related to something like that. I hate to quote a saleman though. My Titan makes the noise too.
webslinger1977 is offline   Reply With Quote
Old 11-04-2004, 06:18 AM   #21 (permalink)
haffne's Avatar
Man the last thing i hear is my 305 HP motor shutting down.
On the other note it sounds like this noise is common among the titan's. This truck have more rattles and squeaks then any other truck that i have owned but it has alot of HP and it's huge inside the cab that is why i own this truck. If we wanted the quietest cab in there class the F150 was rated for that. and that truck is awful.
Crew Cab 4x4 LE Sliver 305x55x20; DDX-7015; KNA-DV3100 Navigation; Sirius Radio; Two 6.5 Power Acoustic headrest monitors; FIPK
Born on 2-14-04
Delivered on 6-18-04
haffne is offline   Reply With Quote
Old 11-04-2004, 12:58 PM   #22 (permalink)
comment on the noise after turning off your truck, depending on how your truck is set up (model) you are hearing the retained power relays turning off ex. after your key is turned off a timer starts you still have power to your windows and various other components until 1 you open the door or 2 the time runs out on the timer. when the time runs out on the timer the computer starts shutting things off and you hear the relays turning off. your dealer can adjust retained power settings by useing the consult scantool however this is limited usually to off or on depending on model. any ?'s you can shoot me an e-mail intruder8000@juno.com
RedBrawn Titan
CC LE 4X4
Big Tow
Born 3/04
wolfox2004 is offline   Reply With Quote
Old 11-30-2004, 04:54 PM   #23 (permalink)
Talking
I think it's the adjustable foot pedals retracting back to their default position.
dmatsuoka is offline   Reply With Quote
Old 11-30-2004, 04:58 PM   #24 (permalink)
robertsjbyrd's Avatar
Mine was doing it and then I got my vent actionator replaced and it has completely stopped.
Galaxy crew cab LE
dvd
4x4
big tow
K&n induction
fully loaded, no navigation
robertsjbyrd is offline   Reply With Quote
Old 12-01-2004, 09:00 PM   #25 (permalink)
My Nissan service center said they will replace the heater fan. The other noise is said to be from the evaperator vent valve which they say is normal (not). I do see the guages jump up for a second too after sitting in the truck for a few minutes after shut off! Strange stuff I will be writing the manufacturer about. If most do this, we can get a recall going to fix the problems.
tagstitan is offline   Reply With Quote
Old 01-11-2006, 11:24 AM   #26 (permalink)
GARRICK ANSON's Avatar
Send a message via AIM to GARRICK ANSON
Re: Sound after you turn the ignition off
I've been noticing this noise since i bought my truck new in '04.
With a base model, no power options KC XE, i will rule out just about every possibility on this forum for the noice except the 6 disk CD player, or the AC/ventalation noises.
All the other options listed I wouldnt hear, because i dont have them.
"Burn rubber, not your soul..."
2004 Nissan Titan XE King Cab
Sirius Starmate Replay
Flowmaster Dual Exhaust
Window Tint
Drop in toolbox
Tonneau cover
"Your gonna need a bigger Hemi.."
Visit my wbepage/Blog @web.mac.com/GarrickAnson
GARRICK ANSON is offline   Reply With Quote
Old 01-11-2006, 12:48 PM   #27 (permalink)
Banned
glowinstrat's Avatar
Send a message via AIM to glowinstrat Send a message via MSN to glowinstrat Send a message via Yahoo to glowinstrat
if you have a intake it could be that .because i have the AEM in take on my strat and when i rev it up then turn it off i have like a turbo effect.with a whoooooosh then a crackel, no cats.
glowinstrat is offline   Reply With Quote
