Titan Talk Site PollsThis section contains site related polls or polls related to the Nissan Titan. Only administrators may start topics in this section.
View Poll Results: NEW ''front to back'' final brake fix feedback... check ALL boxes that apply!
Satisfied/0 problems with new brake fix
300
63.16%
Dissatisfied/problems with new brake fix
26
5.47%
New brake fix stops BETTER than original
180
37.89%
New brake fix stops WORSE than original
18
3.79%
New brake fix now generates LESS brake dust
228
48.00%
New brake fix now generates MORE brake dust
7
1.47%
New brake fix with OVER 10,000 miles so far
63
13.26%
New brake fix with UNDER 10,000 miles so far
214
45.05%
I plan on upgrading to aftermarket brakes
24
5.05%
I don't plan on upgrading to aftermarket brakes
169
35.58%
Nissan has solved my Titan’s brake concerns
213
44.84%
Nissan has not solved my Titan's brake concerns
39
8.21%
I've never had a brake concern
76
16.00%
Multiple Choice Poll. Voters: 475. You may not vote on this poll
THE FINAL TITAN BRAKE FIX and the RESULTS - being discussed at Nissan Titan Forums in the Titan Talk Site Polls section.
Is everyone following proper break in procedure for their brakes? I ask this as I see many people who get a new car or recently replace their brakes start to use them full bore.
I may be speaking too soon as my vehicle does not have the upgraded brakes but I am confident that if the problem should arise, it will be many miles away. But with nearly 30 years of driving and number of vehicles I have owned, I have yet to run into a brake judder problem on my cars/trucks even when installing lower quality economy rotors on some of my winter beater vehicles.
In the first week of driving my new Titan I was very light on the brakes. I applied just enough pressure to lightly slow down the vehicle and made sure that when stopped that I allowed the truck to roll forward so as not to deposit brake material onto the rotor and kept the pressure light enough so as just to keep the truck from rolling forward.
I have yet to run into brake judder with the Titan after nearly 1000 miles of towing and 4000 miles on the original brakes with a proper break in. In fact, with the amount of towing I have done with long downhill stops and stop and go traffic, the brakes are performing quite well except for wheel dust.
Stop Tech site talks about brake judder, causes and prevention and is a good overview.
Other reading that might be interesting, while focused on brake squeal, this thesis from Mikael Eriksson does a nice job of illustrating the thermodynamic properties associated with braking systems.
I feel a little patience and care after a new set of pads and rotors are installed go a long way to prevent brake judder and prolong the life of your brakes.
I think that there are "big brake" kits from Stop Tech and from Stillen. I think (not sure) that these require 20 inch wheels.
I have OEM size cross-drilled rotors and metal matrix pads from Stillen. The rotors seem much harder than OEM and the pads produce much less dust. I also have SS brake lines, Dot 4 fluid, and speed bleeders.
Originally Posted by tortuga
PrerunnerGreg has the same rotors and pads from stillen and his still produced judder... go figure!?!!
Thanks for the info. best and tort on the aftermarket options.
I would like to see others that installed aftermarket brakes and components chime in on this thread with their equipment, mileage and results so far.
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow and E-loc Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Hellwig Anti-Sway Bar, PRG: Bilstein 5100 shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Bilstein Front Shocks, In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod., NISSAN I-POD adapter, Bosch Icon blades. 6 x 10' low bed/rails trailer with E-brakes.
108 year old rebuilt 4,000 lb. road roller/packer.
Amsoil Testing: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Series 2000 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter
60 MPH/20.50 MPG ***New Record-23.01 MPG*** "We have the Capability &Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07: http://www.youtube.com/watch?v=Heku9oTLysg
Finally got my brake judder fix from the dealership yesterday. So far its so much smoother and easier to apply pressure on the brake and no more judder!
__________________ Daves 2005 Titan LE 2WD - (click here for pics)
Deep Water Blue <!> OEM Navigation v6.3 ---- Accessories Added ----
20% Window Tint <!> Fram RG-508 Locking Gas Cap
OEM Vent Visors <!> Lund Interceptor Bug Shield
Chrome Billet Grill <!> Chrome Tailgate Trim
Chrome Tail Light Bezels <!> Armada Air Dam
Bushwacker Fender Flairs <!> Power Tailgate Lock ---- Performance Mods ----
K&N Gen 2 FIPK Intake <!> Banks Monster Exhaust
Active Tuning Grounding Kit <!> PRG Leveling Kit ---- Tires and Wheels ----
17'' Mb Motoring Razor - Chrome
295/70/17 Nitto Terra Grappler A/T
Two owners brake upgrade warranty invoice docs ....
Originally Posted by pmj
what parts are replaced when they do the "final" brake fix???
pmj
04 titan 4000k
no prev problems
Here's a thread on TT that lists the parts from Tortuga: http://www.titantalk.com/forums/show...hlight=Tortuga
and:
Here's what Jackalope posted on another forum:
My Truck was in today for the "Judder" problem the bill under warranty (going to Nissan) was $853.36.
I only have 4,000 miles on my truck and I felt the problem coming on around 3,200 miles mostly because there is a steep grade that I drive every day.
Hmmm I just had my brakes done and there was also a mention of a torque clip (i'm pretty sure that's it, I'll check my invoice later). Fronts were replaced completely and the rears were turned and new pads installed. SO far the pedal feel s is better and they are more linear feeling. The original brakes were a bit grabby right off the lot.
It's my limited understanding that the original problem with the rotors was related to size. However, even after the size increase, adequate ventilation was still a problem. Supposedly, both problems have been addressed with the latest fix. All I can say is...."we'll see...".
[COLOR=Red[/color]guy's did the final fix increase the brake rotor diameter?? and or thickness for improved cooling???
pmj
Thicker diameter rotor......not much though......
Smaller cooling fins.......not sure if there are more??...can anyone confirm this????
So far it's working well in the mountains.
at 8500 miles I am still waiting for the judder to show up so I can get new brakes. However so far I have had no problem with the exception of the NAV computer going out on my 04 kc.
After I had the break fix done there seems to be too much "play" in the brake pedal. The brakes aren't applied until I've pushed it down almost half way. Does this sound like a brake bleeding issue to you all? Does the final fix require bleeding the brakes?
Thanks,
AD
2005 CC 4x4 SE,
Click Here for some useless Titan information from some idiot.
Adam AKA GoogleWhore™ Old people don't need companionship. They need to be isolated and studied so it can be determined what nutrients they have that might be extracted for our personal use.
Facts are meaningless. You could use facts to prove anything that's even remotely true! -Homer Simpson
The only reason you'd need to bleed brakes for a brake job with the mileage involved here would be if one or more lines were disconnected or they drained the resevoir. The TSB is for shudder not excessive brake wear or leakages.
