Trailer light wiring diagram - Nissan Titan Forum
post #1 of 13 (permalink) Old 04-23-2010, 05:59 AM Thread Starter
iTrader Score: 0 reviews
Can anyone tell me where I can get a wiring diagram for a 2007 titan for the trailer light hook up???Especialy for where the relays are for the trailer running lights.
I had a tail light short out and now I dont have any running lights on my trailer. I replaced the tail lights checked all the fuses and replaced the relay labeled L turn/ R turn under the hood but still no running lights....
Thanks
Tooly is offline
Advertisement
post #2 of 13 (permalink) Old 04-23-2010, 05:33 PM
mjw357's Avatar
iTrader Score: 4 reviews
Re: Trailer light wiring diagram
Check fuse #32, under the hood in the same box as the relays, unless you've already done that. Not very likely that the relays are bad.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
mjw357 is offline
post #3 of 13 (permalink) Old 04-26-2010, 06:12 AM Thread Starter
I checked both fuses under the hood and every fuse in the fuse block and they are all good. I also replaced the relay that the dealer said controlled the running lights. I was wondering if there are any inline fuses or maybe another relay in the same circuit.
Thanks
Tooly is offline
post #4 of 13 (permalink) Old 04-26-2010, 06:33 AM
baseballfanz's Avatar
iTrader Score: 1 reviews
Fuse #37 under the hood is ok?
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #5 of 13 (permalink) Old 04-26-2010, 07:07 AM
mjw357's Avatar
Only other thing i can think of are the BCM harness fuses, if he has those.
mjw357 is offline
post #6 of 13 (permalink) Old 04-26-2010, 08:37 AM Thread Starter
I only have two fuses in the same box as the relays and they are both good, not sure what numbers they are(how do I find this out?).
Also where would the BCM harness fuses be located....
Tooly is offline
post #7 of 13 (permalink) Old 04-29-2010, 08:28 AM Thread Starter
Problem fixed..I located a wiring diagram, found fuse #32 and it was blown... Everything works good now...
Thanks guys I appreciate the help...
Tooly is offline
post #8 of 13 (permalink) Old 04-30-2010, 10:51 AM
where is fuse 32 loacated? i have the same problem with my trailer lights
TiTilliDie is offline
post #9 of 13 (permalink) Old 04-30-2010, 11:05 AM
Under the hood
Inside the IPDM box
Trailer light wiring diagram-capture2.jpg   Trailer light wiring diagram-capture.jpg
The Following User Says Thank You to baseballfanz For This Useful Post:
nic6 (12-24-2011)
post #10 of 13 (permalink) Old 06-24-2010, 10:03 AM
-pru-'s Avatar
Re: Trailer light wiring diagram - 2010 Model?
Did the layout of the 2010 IPDM change? For the life of me, I cannot reference the above diagram against my new truck. That is, I cannot find fuse #32 within the 2010 IPDM box. Driving me nuts...
-pru-
10 Titan SE CC 4x4
05 Titan SE KC 4x4
-pru- is offline
post #11 of 13 (permalink) Old 06-25-2010, 08:29 PM
-pru-'s Avatar
Re: 2010 Trailer Running Light Fuse #4
Answered my own question; 2010 Trailer Running Lights is Fuse #4.
Tip on changing; the main 2010 IPDM fuse panel is nearly vertical (~75 degrees). The #4 fuse is on the lower portion of the panel which makes it nearly impossible to reach when the panel is in place. The panel has lock tabs on the left/right side which when released allow you to lift up the assembly enough to access the lower fuses for checking/changing.
-pru-
10 Titan SE CC 4x4
05 Titan SE KC 4x4
-pru- is offline
post #12 of 13 (permalink) Old 08-01-2010, 09:34 AM
I have used the above information to hopefully find the fuse for both of my turn signals on my trailer. I have an '09 Titan SE and my running lights work as well as my electric brakes for my trailer. I need to know what fuse is for my turn signals on my trailer. I can't see any numbers on the fuses so perhaps a discription of where it is would help me out a ton. Thanks for all your help!!
booker06dg
booker06dg is offline
post #13 of 13 (permalink) Old 08-01-2010, 02:11 PM
booker06dg
Did your SE come with the tow package?
Do you have all the relays installed?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Need wiring diagram for 05 KC conseit68 Titan Interior Discussion 10 04-01-2010 04:53 PM
Installing Hitch and Wiring Trailer Brake Light Plug pilot4net Titan Towing & Hauling 11 01-24-2009 05:55 AM
Trailer plug wiring diagram robscar Titan Towing & Hauling 8 08-04-2007 03:19 AM
wiring diagram for fog light on titan cc xe titanic_081806 Titan Parts & Accessories 5 09-22-2006 08:38 AM
Wiring Diagram acontisr Titan FAQ & How to Area 3 07-16-2004 08:38 PM
You may post new threads
You may post replies
