Towing Capabilites of Titan SLE with towing package (5th Wheel) - Nissan Titan Forum
post #1 of 16 (permalink) Old 08-20-2011, 06:40 PM Thread Starter
iTrader Score: 0 reviews
My dealer says I have a 1/2 ton towing capacity. Does anyone know the maximum pin weight that a Titan will haul a 5th wheeler. Saleman says the Titan will tow as much as 1800# pin weight easy. I want to buy a 32.2' 5th wheel, but don't want the expense of the set up and the trailer if my truck is unable to haul it. I now pull a 30' travel trailer with no problem, but what I am looking at will be heavier.
Sonny
sonny594 is offline
Advertisement
post #2 of 16 (permalink) Old 08-20-2011, 06:47 PM
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: Towing Capabilites of Titan SLE with towing package (5th Wheel)
What year and what trim level are you? Hint: SLE is not a trim level offered.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
The Following User Says Thank You to Carbeaux For This Useful Post:
sonny594 (08-22-2011)
post #3 of 16 (permalink) Old 08-21-2011, 06:14 AM Thread Starter
Sorry Carbeaux, the trim level is a 5.6 SE. If that's what the trim level is on a Titan, I'm confused by the term. And it's a 2004.
Sonny
sonny594 is offline
post #4 of 16 (permalink) Old 08-21-2011, 08:13 AM
linycctitan's Avatar
iTrader Score: 4 reviews
Welcome Sonny, You may want to look at a newer model Titan if your main purpose is towing. The 04's had quite a few issues, as any first model run does, and most of these issues have been worked out over time. If, however, this is the only vehicle on your horizon, then I'd be sure to have the VIN checked through a local dealer to verify all recalls and campaigns have been updated on this particular truck. I'd also be sure it has the factory tow package and updated rear. If the truck has been well cared for and all the issues have been rectified, then it may be a worth while purchase for you. Just an additional point, the newer models handle towing and payload quite a bit better than the earlier models. Good luck and keep us posted.
If you can't stand behind our troops, feel free to stand in front of them
2006 Titan SE Crew Cab 4x4 Off-Road
Majestic Blue w/ Graphite & Gray Cloth
Utlity Bed Pkg, Big Tow Pkg
linycctitan is offline
The Following User Says Thank You to linycctitan For This Useful Post:
post #5 of 16 (permalink) Old 08-21-2011, 04:23 PM
Ron O`Malley's Avatar
HMM. seven years pulling the camper with my 04 guess I must be lucky.
2012 PRO-4X-smoke-Premium utility package-Truxedo Lo Profile tonneau cover-LEDs HIDs high low and fog line of fire tail lights thanks Randy axle vent mod, grounding kit thanks Marty, BlackWidow muffler, AIRAID MXP CAI - R.I.P 2004
Ron O`Malley is offline
The Following User Says Thank You to Ron O`Malley For This Useful Post:
post #6 of 16 (permalink) Old 08-21-2011, 04:45 PM
Carbeaux's Avatar
The salesman is wrong, sorta. The payload capacity on your truck is only about 1200 lbs. For the '08 and up it's more in the range of what the salesman told you.
Hook 'Em!
Carbeaux is offline
post #7 of 16 (permalink) Old 08-22-2011, 12:47 PM
Steamguy's Avatar
Garage
+1.
My rolling brick of a trailer weighs 7,000# on the wheels, 800# on the hitch.
No problems here. These early 04's must be lucky.
Steamguy
Deepwater Blue, when it's not Dirt Brown. Yes, this truck is used as a TRUCK. If I wanted something to sit in the driveway and look pretty, I'd have bought another motorcycle.
Trailer-puller, meadow work truck, thrill ride for a rescued Aussie.
Born 11/11/03, first one sold in the county, still the original owner.
Steamguy is offline
The Following User Says Thank You to Steamguy For This Useful Post:
sonny594 (09-10-2011)
post #8 of 16 (permalink) Old 08-23-2011, 03:35 PM Thread Starter
Ron, what type of trailer are you pulling, length, weight, pin weight?
sonny594 is offline
post #9 of 16 (permalink) Old 08-23-2011, 04:05 PM
It's a Rockwood ultralight, 6800 lite weight, 30' in lenght, don't remember pin weight.
sonny594 (08-24-2011)
post #10 of 16 (permalink) Old 08-23-2011, 05:43 PM
Aquaholic's Avatar
iTrader Score: 49 reviews
I'm going to guess you have a xcab. I would find the sticker on the rear axle that tells you the gears in it. If you have had it since new you would hopefully know without looking there if it came with the hitch and tow mirrors. 1425 lbs 2wd 1410 lbs 4wd with tow package. 1110 for 2wd and 4wd without tow package.
2007 Blizzard with Charcoal/Titanium interior SE CC 4x4 with off road, tow, popular bench, and utility bed packages
Mods to date:
2.5" leveling kit, PRG endlinks, PRG UCA's, PRG motors & Trans mounts, PRG deavor HD AAL, PRG shackles, Ride-rite air bags, Bilstein 5100 shocks, Procomp M/T2 295/55/20s on Chrome Moto Metal 956, Amp Research Steps, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, Rubber bed mat, 2009 Chrome grille, UPREV, Air Aid MXP intake , JBA EVOL stainless cat-back, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Infinity Reference 6 1/2's in rear and 6x9's in front, Kenwood KAC-9105d mono amp, 2 12" Kenwood excelon subs in tech12 box, Prodigy brake controller, Ventshade door sill protectors, LEGIT Accessories L.E.D.s everywhere
Other rides:
2010 Nissan Maxima SV with sport pk
2011 Polaris Rzr4 800 Robby Gordon Tricked out
2012 Polaris Rzr4 800 EPS LE Robby Gordon
2005 Lightining 23xs- Mid cuddy with open bow, 350 mag, Bravo II outdrive, High Five stainless prop
2013 Eclipse Attitude 26FSG Toy Hauler
2013 Cougar 27RLSWE Travel Trailer
Past Nissans owned
1991 Harbody, 2004 Titan XE, 2005 sentra, 2009 Altima, 2011 sentra
Titan drivers in my family:Grandma 2004 CC XE, Great uncle 2004 KC LE, Dad 2008 CC SE, 2 Uncles with 2010 CC SE's, and I'm on my 2nd one.
Aquaholic is offline
The Following User Says Thank You to Aquaholic For This Useful Post:
post #11 of 16 (permalink) Old 09-08-2011, 03:34 PM
I have a 2004 Titan Crew Cab LE with Tow Package, Firestone AirBags & Pullrite Superglide. I pull a 22ft deck boat on the ball and a 27ft 5th wheel camper. I have'nt had any problems.
Dondo
Towing Capabilites of Titan SLE with towing package (5th Wheel)-img_0436.jpg
Dondo is offline
The Following User Says Thank You to Dondo For This Useful Post:
post #12 of 16 (permalink) Old 09-09-2011, 01:34 PM
Pulling a 29' JayFlight, 1400# pin weight, with no issues. I only have to run about 35# in the airbags to keep the bed level.
09 Titan XE 4x4 CC Long Bed, Utility and Tow pkg, Tekonsha Primus IQ, Bully Dog GT, PML pan, Ride Rite airbags, Reese 16k slider 5th wheel
Big_Iz is offline
The Following User Says Thank You to Big_Iz For This Useful Post:
post #13 of 16 (permalink) Old 09-10-2011, 12:54 PM Thread Starter
I need some help. Are airbags better than having an add-a-leaf? I'm not sure what the advantages may be and just what they do, plus how do you air them up? Ballpark, what is the cost, plus installation?
sonny594 is offline
post #14 of 16 (permalink) Old 09-11-2011, 05:05 AM
I don't remember exactly how much. I think I may have paid $350.00 for the firestone airbags and paid $200.00 to have them installed. The air valves are mounted on either side of the license plates. I think they are better than leafs. You can add air when you need it and bleed off the air when you don't. I usually put about 50 pounds of air in when I tow the 5th wheel. The truck doesn't drop at all and it has a sturdy ride.
Dondo is offline
post #15 of 16 (permalink) Old 09-12-2011, 08:12 AM
brodo420's Avatar
i have not had mine installed yet, but I plan to put in the Roadmaster Active Suspension, and if necessary (possible?) also add the Firestone Ride Rites with an Auto Levelin' compressor system.
Ride-Rite:
Amazon.com: Firestone W217602355 Ride-Rite Kit for Nissan Titan: Automotive Amazon.com: Firestone W217602355 Ride-Rite Kit for Nissan Titan: Automotive
Auto Level:
Amazon.com: AIR LIFT 25415 SmartAir Automatic Leveling System: Automotive Amazon.com: AIR LIFT 25415 SmartAir Automatic Leveling System: Automotive
Roadmaster: Roadmaster Active Suspension 4611 - Roadmaster Active Suspension Systems - Overview - SummitRacing.com
I read about the active suspension kit here and I'm sold:
02 Porsche 911 Turbo x50, ECU tune, Fab Speed exhaust, HF Cats, 034 Diverter Valves
11 Titan SV CC+ tow mirrrors, black steps, prodigy3, dvd/nav, RR bags, Auto Air Level kit
UpRev,Robello Racing Ported Valves & Milled heads (10.4:1), JWT Cams, DTLT, TruTrac, 3.73 gears, TransGo Shift Kit, Berk Cats, Stillen catback, Injen CAI, Stillen/CSF Rad, PML TP, PML DP
Stillen Front Sway, r1 slotted/drilled performance rotors
342rwhp . 385lbft
... constantly modding, will update on completion
brodo420 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
F/S: 2005 titan "red alert" se/4 wheel drive/off road and towing package transform Buy/Sell 1 05-30-2011 12:36 PM
Titan towing a 5th Wheel - Your Experiances HavasuMike Titan Towing & Hauling 23 11-09-2010 08:28 PM
fifth wheel hitch and towing with titan stl454 Titan Towing & Hauling 5 06-01-2010 10:33 AM
Towing a 5th wheel with a Titan Old Man Titan Towing & Hauling 41 04-13-2006 08:11 AM
Towing a 5th wheel with a Titan Old Man Titan Towing & Hauling 7 11-26-2005 06:58 PM
You may post new threads
You may post replies
