fuse location for trailer lights - Nissan Titan Forum
post #1 of 10 (permalink) Old 05-28-2012, 04:51 PM Thread Starter
oddjobbb's Avatar
iTrader Score: 0 reviews
last week i hooked up this trailer that i am going to be borrowing to check the lights and stuff just to be sure everything worked properly which it did. now i go and pick up the trailer and none of the lights work where are the fuses that i need to check and should i check relays also?
Correction the running lights are working just the brake and turn signals lights not working.
any ideas?
oddjobbb is offline
Advertisement
post #2 of 10 (permalink) Old 05-28-2012, 07:07 PM
Re: fuse location for trailer lights
They should be on the left side inside the engine compartment. There is
several fuse banks inside the box. Theres a diagram of the fuses on the lid.
Kinda tricky to get to them,
Mikes Titan is offline
post #3 of 10 (permalink) Old 05-29-2012, 06:40 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
Make sure the trailer is grounding to the truck. Sometimes the ground will be weak and cause problems with the lights.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #4 of 10 (permalink) Old 05-29-2012, 07:06 AM
That1Person's Avatar
iTrader Score: 3 reviews
Do you have the trailer light relays? Not all titans come with them
Sent from my DROID RAZR using AutoGuide.Com Free App
06' CC 2wd
Remote Start
Spider head+tail lights
Leer 700 Bed Cover
PD'd Wheels, Fender Flares, Nerf Bars, Front Bumper, Grille, Hood & Badges
K&N Drop In + AirBox Mod
Nismo headers
UpRev by Cajun
That1Person is offline
post #5 of 10 (permalink) Old 05-30-2012, 11:13 AM
baseballfanz's Avatar
iTrader Score: 1 reviews
What year is the Titan? The running lights should work regardless if you have the relays in place or not. If you have all relays ect... another thing to check if you have an 04-05 is two fuse by the BCM (assumming the tow harness TSB was done).
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
The Following User Says Thank You to baseballfanz For This Useful Post:
TitanBlue (06-28-2012)
post #6 of 10 (permalink) Old 06-28-2012, 05:08 PM
fdlock890's Avatar
What is the BCM and what does TSB stand for also.
Thanks, Lock
fdlock890 is offline
post #7 of 10 (permalink) Old 06-28-2012, 06:15 PM
TitanBlue's Avatar
Body Control Module (A computer that controls all the electric functions). It is located under the dash just to the right of the drivers knee if I recall correctly. The other main computers are the ECM Engine Control Module or Engine Control Unit (ECU) and the TCM Transmission Control Module.
Technical Service Bulletin, which is Mfg info of a problem and how to fix it, but not neccesarily a recall. Early Titans had some issue with Trailer lights, and an updated design harness was installed, later on the design was changed. But that harness has a coulle fuses, not listed in the book.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
post #8 of 10 (permalink) Old 06-28-2012, 08:41 PM
You should search but if you read this it should help, I posted a great picture
Trailer Lights and Wiring Harness
SweetRide is offline
The Following User Says Thank You to SweetRide For This Useful Post:
jtpIV (10-12-2012)
post #9 of 10 (permalink) Old 06-30-2012, 01:02 PM
Cramer05's Avatar
Garage
I'm guessing you probably have this figured out by now, but I had the same thing happen to me and had no idea that many Titans came without trailer light relays. I could have saved myself a lot of time and headache if I knew. I had to buy two blue ones and a brown one from the dealer to get all my lights working. Cost $100 bucks or so for all of them and the parts guy acted like I was the 5000th person to come in for them.
Cramer05 is offline
post #10 of 10 (permalink) Old 04-11-2017, 07:19 AM
I have a similar problem with my 2013 Titan. I can't find the trailer tow fuse. Running lights do not come on. All other lights do. I looked under the hood in the bigger fuse box behind the smaller one. Nissan thought it would be great idea to remove the labels for the fuses that were on the underside of lid on previous years and put them on the back of the box behind the wire harnesses inside the fuse box so they cant be read and identified as the label is obstructed from view by all the wires in the way. Can someone post a photo of the location of the correct fuse. I pulled all the 10amp fuses I could see and they were all good. Maybe it is a relay? But because I cant read the label I don't know which relay to check.
fasi_214 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Trailer running lights - which fuse? DeeDubya Titan General Discussion 10 03-21-2015 03:11 PM
10A fuse for the trailer running lights keeps blowing... trailer or truck issue? BCBowers Titan Towing & Hauling 20 04-18-2013 09:28 AM
Fuse Location Fog Lights RedAlert Titan General Discussion 3 05-23-2011 10:17 AM
Fuse for trailer lights DoyleOil Titan Towing & Hauling 6 11-01-2010 09:47 PM
trailer taillights fuse location k94max Titan Problems & Dealer Service 3 09-03-2008 04:33 PM
You may post new threads
You may post replies
