Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Stupid question about brake controllers - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 08-30-2004, 08:25 AM   #1
Bayou Titan
I am going to pull a covered trailer with electric brakes to Florida to haul stuff to help with hurricane Charley cleanup. I haven't seen the trailer yet but the guy said that the brake controller for the trailer is on the tongue of the trailer. Do I need to buy a brake controller and connect it to the dash? What about the pigtail thingy that came with the tow package? do I need to install it? Sorry for all the questions but I know very little about electric brake stuff and I didn't see anything about a trailer mounted controller on previous posts.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 08-30-2004, 08:43 AM   #2
adjmcloon
adjmcloon's Avatar
You'll need a trailer brake controller assuming it has standard trailer brakes (and not surge brakes). On my Armada the wiring harness is tucked under the dash and clearly labeled. Just plug in a controller (Get the Tekonsha Prodigy if you want to buy it once), mount it, adjust and go. No sweat.
I imagine you've got the wiring harness from the trailer and that will plug into your 7 way connector on your bumper. The trailer might have a breakaway switch installed on or near the trailer hitch, but you won't worry about that unless something bad happens. Essentially it will apply the trailer brakes if the trailer pops off your truck.
That is, unless for some weird reason, the guy has a controller mounted on the trailer itself as your post says. I've never heard of anyone doing this myself, as usually the controller is inside the vehicle so you can adjust the sensitivity of it.
adjmcloon is offline   Reply With Quote
Old 08-30-2004, 10:01 AM   #3
titanjbc
titanjbc's Avatar
My guess is that the trailer has surge brakes, where the brake force is determined by the force of the trailer against the hitch. When you stop, the trailer pushes against the hitch, engaging the brakes. You should definitely confirm what types of brakes, electric or surge. If the trailer has surge brakes, chances are it has a 4 pin wiring harness for lights. If so, you can buy a 7 pin (what's on the truck) to 4 pin adapter for $10-15 at UHaul or Walmart. I hope that helps...
Titan SE CC 2WD
Smoke / Graphite
Pop. Pkg. w/Capt., Big Tow, Util. Bed Pckg.,
Splash, Mats, Fog Light Kit, Step Rails
Leer 100R Cap
Hornet Lite 24RS Travel Trailer
Reese Straight-Line Hitch (WD System with
Dual Cam Sway Control) Prodigy Brake Controller
titanjbc is offline   Reply With Quote
Old 08-30-2004, 10:08 AM   #4
IMADOGMAN
IMADOGMAN's Avatar
From the comment your friend made, I would bet that it has surge brakes...
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-30-2004, 10:59 AM   #5
Bayou Titan
Thanks guys! So, if the trailer has surge brakes I don't need a brake controller?
Old 08-30-2004, 11:11 AM   #6
dooboy2112
dooboy2112's Avatar
That would be correct.
Titan page
04 Smoke KC SE 4x4
Offroad package
Big Tow
Utility Bed
K&N Aircharger
dooboy2112 is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
