trailer wiring - Nissan Titan Forum
post #1 of 30 (permalink) Old 11-14-2012, 09:10 AM Thread Starter
Tights24's Avatar
iTrader Score: 2 reviews
trailer wiring
So, just check my connections and wires on my hitch. My lights work, and left turn signal/brake light. The right side turn signal does not work. I unplugged from the harness back by the hitch and I have nothing at that connection point either. So, something is not working pretty much between the back of the truck up to the fuse box. I looked in the relay spot under the hood. I have a trailer tow #1 with nothing in it, Trailer tow #2 with the relay, and that's it. There's an open spot next to the trailer 2 relay where a relay could go, but nothing there. The rest don't even have provisions for a relay to plug into it.
Any thoughts?
2005 LE CC 4wd - sadly she's gone
Magnaflow Catback
Best 1/4 mile time so far - 15.10 @ 88.86 (Second track appearance)
New ride - 2007 GMC Yukon SLT Black on black fully loaded and bone stock. 15.9 @89mph w/2.54 60ft.
Tights24 is offline
Advertisement
post #2 of 30 (permalink) Old 11-14-2012, 09:17 AM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
Re: trailer wiring
You should have a relay in both tow spots.
My truck didn't come with big tow so I bought the relays and now all my lights and signals work.
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
The Following User Says Thank You to DeadRiver For This Useful Post:
Tights24 (11-14-2012)
post #3 of 30 (permalink) Old 11-14-2012, 10:05 AM
mjw357's Avatar
Re: trailer wiring
Relays have nothing to do with the turn signal/brake lights. Check for the BCM harness mod where there may be a fuse blown.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
mjw357 is offline
The Following 2 Users Say Thank You to mjw357 For This Useful Post:
baseballfanz (11-14-2012), Tights24 (11-14-2012)
post #4 of 30 (permalink) Old 11-14-2012, 10:24 AM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: trailer wiring
Like mjw357 stated, if you have had the tow harness TSB done, there should be two additional fuse for the left/right trailer turn signal.
Under the hood you should have a blue and brown relay but you can do WITHOUT the brown relay if you don't need 12V power to
the trailer (ie for charging a battery source on the trailer).
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
The Following User Says Thank You to baseballfanz For This Useful Post:
post #5 of 30 (permalink) Old 11-14-2012, 10:31 AM Thread Starter
Tights24's Avatar
Re: trailer wiring
Hmmm, I think I'll have to take a picture and post what I'm looking at. I wasn't aware of a TSB for anything and I do not have the BT package. I'll take a pic in a minute so you guys can educate me.
Magnaflow Catback
Tights24 is offline
post #6 of 30 (permalink) Old 11-14-2012, 10:37 AM Thread Starter
Tights24's Avatar
Re: trailer wiring
So, the left turn does work, just not the right. Are there two different fuses or one that controls both? If it's one, then I have a wire issue somewhere.
Magnaflow Catback
Tights24 is offline
post #7 of 30 (permalink) Old 11-14-2012, 10:51 AM
mjw357's Avatar
Re: trailer wiring
Two seperate wires. The one for the right will be yellow/black.
mjw357 is offline
post #8 of 30 (permalink) Old 11-14-2012, 10:57 AM Thread Starter
Tights24's Avatar
Re: trailer wiring
Picture of my relay box.
Magnaflow Catback
Tights24 is offline
post #9 of 30 (permalink) Old 11-14-2012, 11:01 AM Thread Starter
Tights24's Avatar
Re: trailer wiring
So, I understand it's two wires but is it two fuses as well? Thanks again for everyone's help.
Magnaflow Catback
Tights24 is offline
post #10 of 30 (permalink) Old 11-14-2012, 11:04 AM
mjw357's Avatar
Re: trailer wiring
That is correct, one fuse per circuit.
mjw357 is offline
post #11 of 30 (permalink) Old 11-14-2012, 11:30 AM Thread Starter
Tights24's Avatar
Re: trailer wiring
Ok, last ignorant question. Where are these fuses? Under the hood with the relay box I only see one fuse as pictures above.
Or are we talking the fuse panel on the passenger side?
Magnaflow Catback
Tights24 is offline
post #12 of 30 (permalink) Old 11-14-2012, 01:15 PM
Re: trailer wiring
You're missing BOTH tow relays.
post #13 of 30 (permalink) Old 11-15-2012, 04:30 AM
mjw357's Avatar
Re: trailer wiring
Look at this thread, post #21 has a pic.
Trailer Lights and Wiring Harness
mjw357 is offline
post #14 of 30 (permalink) Old 11-15-2012, 09:33 AM
iTrader Score: 0 reviews
Re: trailer wiring
I just went thru all of this...turned out to be a corroded harness...clean your harness!
The best way to find the fuses other than that great pic that was on that other post is to look under the steering column, to the right side look for two little white caps...inside there is a 10A fuse each...one for the right turn and one for the left turn. Thanks to some other members on here I learned that the brake and turn signals come from the BCM...the relay just controls the running lights..which is nice to have too if it gets dark lol.
Jhall530 is offline
post #15 of 30 (permalink) Old 11-15-2012, 09:34 AM
Re: trailer wiring
There is one 10A fuse for towing up in the fuse box behind the relay box also...see the link to the pic that was posted on the other thread to find the fuses under the steering column
Jhall530 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
OEM Trailer Wiring Harness gentle_ben Titan Towing & Hauling 1 06-20-2011 02:37 PM
Another Trailer Wiring Problem Lefty441 Titan Towing & Hauling 2 12-01-2010 04:47 AM
Please Help with my Trailer Brake Wiring ucf_motorcycle Titan Towing & Hauling 11 03-22-2007 06:36 PM
Trailer Wiring KYDeepwater Titan General Discussion 3 05-27-2005 12:59 PM
Where's the trailer brake pre-wiring? Mike Up Titan Towing & Hauling 10 12-07-2004 06:18 PM
You may post new threads
You may post replies
