Re: What was your experience w/ aftermarket big tow mirrors?
I have had both aftermarket and OEM BT mirrors. I had the aftermarket mirrors on our Armada and I now have the OEM mirrors on my 2012 Titan...
In April of this yearI bought a set of aftermarket big tow mirrors for our Armada from AM-Autoparts. I bought them through Ebay and got the power, heat, memory, and chrome cap delivered for $188.00 shipped. I put them on and drove with them up until I sold the Armada in October 2012. My experiences were close to what BCBowers spoke about in his thread. The fit and finish was excellent. I used gaskets off the original mirrors. They are rubber as the other ones were a cheap pressed foam. You couldn't tell the difference between the OEM and the aftermarket mirrors by looking at them. The aftermarkets were very solid and well made. I was quite impressed. The power mirrors worked well. I didn't notice them being any faster or slower than OEM, but since my Armada was an '04, all electronics moved really slow. The memory and heat worked well too. As for the mirrors themselves, I had no complaints about the drivers side mirrors, the larger flat mirror was clear and straight, no waves or anything in them. The mirror did vibrate a little, but not enough for me to return them or get a headache. The lower convex mirror on both the drivers side and passenger side were clear, had no distortions, and did not vibrate at all. The passenger side larger mirror took a little more getting used to. It is hard to explain, but the mirror makes the objects look much closer and much larger than on the OEM BT or original mirrors. So essentially, I was able to see farther down the side of my 27t trailer clearer than I could with the OEM BT mirror. It was almost like looking through a magnifine glass, hence why it looked a little wavy. Since you are able to see farther behind you, the mirror didn't pick up anything closer than a car-lengh behind you in the next lane, but in this situation, you use the lower convex mirror anyways. Like I said, it is hard to explain (if anyone can explain better, please do), you must see it to understand what I'm talking about. Again, the passenger mirror did vibrate a little, but not enought for me to get irritated by them.
I have the OEM BT mirrors on my 2012 Titan now and once in a while, they vibrate depending upon the road and/or wind, but not as much as the aftermarkets. When I towed my trailer a few weeks back, I kind of missed the aftermarket passenger side mirror because I could see farther back along the trailer. But as with anything else, I am used to it.
In my honest opionion, I have no issues with the aftermarket mirrors. If I were to do it again, I would buy the aftermarkets, especially if money is a factor. Are the OEMs worth another ~$150.00, I would say no, but that is up to you. Good luck with your decision.
2012 Nissan Titan SL 4x4
Mods: Tint, WeatherTech Floormats, Bully Dog GT, AirRaid MXP Intake, LegitLED full interior and exterior LED packages, 275/60/20 Destination A/T's, Midland 75-822 CB w/ 4' Everhardt Antenna, Air Lift Airbags
