Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Need help w/ electrical & towing - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 10-04-2004, 06:34 AM   #1
terryu1
terryu1's Avatar
I was closing my camper for winter and brought it from storage to my home. I left it hooked up while cleaning etc. What I noticed was I had no power from the Titan to the camper. I usually do not rough camp and this year I didnt even put the camper battery in. With my F150 I had power direct from the battery to the camper via the connector. I assumed the prewired Titan would be the same. I haven't had time to start research on this but I thought I would take the lazy man approach and tap into the vast knowledge of this site. Anyone know if and what I need to get power from Titan to Camper?? Thanks in advance.
'04 Titan LE Crew Cab - Born on 4/30/04
terryu1 is offline   Reply With Quote
Old 10-04-2004, 07:11 AM   #2
Hawkeye
I was wondering the same thing, only with a boat trailer. My lights worked fine when I towed it with my xterra. The only difference was I had to use an adapter to go from 7-4 pin on the X, but now with a 7-7 connection I don't get any power to the trailer. Is there something that has to get plugged in for the tow package connector to work?
Hawkeye is offline   Reply With Quote
Old 10-04-2004, 07:51 AM   #3
lsutyger
Send a message via AIM to lsutyger
Exclamation Is there something to plug in?
Yes there are two relays under the hood that supply power to the connector in the back: Click Here
LSUTYGER
His - '04 Red Brawn SE
Hers - '03 Sonoma Sunset 2.5S Altima
lsutyger is offline   Reply With Quote
Old 10-04-2004, 08:14 AM   #4
terryu1
terryu1's Avatar
I know of the relays. I have the tow package and my lights, electric brakes etc all work. The 7 pin connectors usually have a power wire running from the battery through a resetting breaker back to connector which provides power to the electric converter on the trailer which powers all interior lights, radio etc. This is what my question concerns. Thanks again.
Old 10-04-2004, 08:21 AM   #5
Hawkeye
So, even with the big tow pakage, you still have to supply your own relays? Sorry I didn't mention that earlier.
Old 10-04-2004, 10:00 AM   #6
bestatchess
No, you get the relays with Big Tow.
Old 10-04-2004, 10:45 AM   #7
QWIKWHIP
QWIKWHIP's Avatar
You should have constant 12v to the trailer. Mine works fine and I just have the dealer installed hitch, not the tow package.
Old 10-04-2004, 12:07 PM   #8
bestatchess
On mine, the pin assignments on the trailer electrical connector are inscribed on the plastic connector cap. You might try testing the one identified as the 12V hot lead with a volt meter.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
