Old 10-07-2004, 08:35 PM   #1 (permalink)
Towing without Big Tow
I'm trying to figure out if I'm going to mess anything up towing about 7000 lbs without big tow in the mountains. What kind of strain will I be putting on the truck with out the lower final gears????? Or, can I overcome this by just shifting into a lower gear?
Markus is offline   Reply With Quote
Old 10-08-2004, 04:04 AM   #2 (permalink)
Nuckle's Avatar
You should be fine. I would just make sure the transmission is not shifting all the time. Be sure to watch your guages.
Nuck
Nuckle is offline   Reply With Quote
Old 10-08-2004, 06:45 AM   #3 (permalink)
I believe you still have use of a TOW/HAUL mode....right? As long as you don't go over the recommended tow rating, no worries!
TitanicSE is offline   Reply With Quote
