Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Tow Hitch - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-13-2005, 12:03 PM   #1
atlasot
Tow Hitch
I recently installed a factory hitch and cannot seem to get my lights on the trailer to work. I followed the instructions that came with the hitch. The only thing i did not do is the connection underneath the dash above the foot pedals, becasue it looked like it was already done.
Any help would be appreciated.
atlasot is offline   Reply With Quote
Old 03-13-2005, 12:31 PM   #2
rdfeatherstone
Tow Hitch
Atlasot
As I understand it, the connector up under the dash is for the braking controller. Perhaps, it has an effect on the lights, I don't know.
Have you tried using a voltage tester to check if voltage is at the plug by the hitch when lights, brakes, etc. are applied?
Ralph Featherstone
'05 Titan SE KC 4X2
rdfeatherstone is offline   Reply With Quote
Old 03-13-2005, 12:34 PM   #3
cttitan
cttitan's Avatar
Did you install the relays and check the fuses??
Check this thread for info on where the fuse and relays are.
Tow relays
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
cttitan is offline   Reply With Quote
Old 03-13-2005, 12:44 PM   #4
AR Titan
AR Titan's Avatar
You need the blue relay installed for trailer lights. You can pick one up at the stealership or online from one of the site sponsors.
However, if you bought the factory/oem hitch it is suppose to come with both relays. You only need the blue one (4 poll) for trailer lights. Also make sure your trailer lights are grounded or they will not work. Good luck! I spent over a week trying to get my trailer lights to work, changing wiring harnesses and even re-wiring the trailer, before I realized the trailer was not grounded.
2004 LE KC 4x4 GalaxyBlack
AR Titan is offline   Reply With Quote
Old 03-13-2005, 01:05 PM   #5
atlasot
The relay is installed. I think it may be the ground issue!!
Old 03-13-2005, 01:37 PM   #6
aero320
Get a volt meter and check for voltage at the receptacle by the hitch. If you are not getting a signal at the receptacle, check for a blown fuse.
aero320 is offline   Reply With Quote
Old 03-13-2005, 02:46 PM   #7
atlasot
I am not getting any power to the hitch or 12v outlet in the Bed. I checked the fuse labeled TOW1, which is bottom left on the 2nd row.
Old 03-13-2005, 03:27 PM   #8
cttitan
cttitan's Avatar
If you are good at reading schematics I can send you the wiring diagrams for what you are looking at if that would help.
Check fuses #32 (probably the one you already checked) and #37. Fuse #28 is for the rear power socket, but I don't see any connection to the other problem except for possibly a ground issue.
Old 03-13-2005, 03:30 PM   #9
atlasot
I can read the diagram on the inside of the fuse box!
Old 11-04-2007, 07:49 PM   #10
Terry
please help Tow Hitchwiring
I really need help figuring out the wiring on the towing package for the 2005 Nisson Titan. I took it to the dealer and paid 300.00 and assuming they knew what they were doing, it was a while until I hooked up to a trailer that I knew was working on other vehicles. All I get are tail lights. does anyone know the color sequence of what the wiring is? schematic ? I have tailights butno turn, brake , ect.... I have put a voltage meter to it but even that is wrong. I really appreciate your help as you can imagine this is getting frustrating. You can contact me at werhotcpl@yahoo.com
And again thanks to anyone who can help me on this.
Terry is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
