Old 04-20-2005, 07:46 AM   #1 (permalink)
trailer tow relay
Still cant wait to drive my truck this morning. Anyway, I purchased the trailer tow no.1 relay because my trailer running lights were not working. The blinkers, hazzards, and brake work fine. On the fuse box lid the position for the no.1 isnt wired in the box. Though I do have the no.2 relay already. Is there a diagram for wireing this or greenbacks for the dealer? Is it correct the no.1 is for running lights and no.2 for trailer brakes? Thanks.
bellpac is offline   Reply With Quote
Old 04-20-2005, 09:57 AM   #2 (permalink)
I have an SE. It was prewired. XE must not be prewired. Maybe some other with an XE can confirm this. The relay should be blue. Make sure you are looking at the lid right. Relay goes just to the right of the light brown one.
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 04-22-2005, 12:01 AM   #3 (permalink)
I have a 2004 XE. The relays are prewired. The hard part of the job is wiring a brake controller (if needed) under the dash. See this thread for more info.
brake controller w/o big tow?
rbccxe is offline   Reply With Quote
