Old 04-25-2005, 09:38 PM   #1 (permalink)
Exclamation Towing question - Help is appreciated
Hello all -
Just a quick question. Looking at towing a fully loaded Chevy Tahoe with a Uhaul auto transport(dual axle trailer). Is this possible? I've got a KC 4x4 with Big Tow. I'm new to the towing game and looking to transport the Tahoe over 1500 miles. What are my limitations concerning this type of towing? Any help and/or suggestions are appreciated. Thanks.
texag is offline   Reply With Quote
Old 04-25-2005, 11:04 PM   #2 (permalink)
loufish's Avatar
Need to know how much the trailer weighs with it's load, and the tongue weight(loaded)...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-26-2005, 05:39 AM   #3 (permalink)
I towed a '56 Chevy about 200 miles on a Uhaul transport using my Crew Cab about two months ago and couldn't tell I was even towing anything. Click on the link below for more information.
http://www.uhaul.com/guide/?equipment=autotransport
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 04-26-2005, 03:49 PM   #4 (permalink)
U-Haul won't rent you a trailer to tow a Tahoe, it's too heavy for their trailers. The Titan would pull it no problem, but I'd be concerned about the trailer, it would be way overloaded. Sure you could tell them you are pulling something else, but you would be screwed if anything happened.
Jason K.
Titan Power is offline   Reply With Quote
Old 04-26-2005, 04:22 PM   #5 (permalink)
Jason K.
Thanks for pointing that out for texag. The Uhaul link I posted states the trailer limit as 4,000 lbs. I looked at a Tahoe site and most of them weigh 6,000 lbs or more.
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
Old 04-26-2005, 11:50 PM   #6 (permalink)
Thanks to those who helped out - I appreciate the info and decided to go against using the uhaul trailer. Thanks again.
Old 04-27-2005, 04:12 AM   #7 (permalink)
hkusp45's Avatar
U-haul traiers will tow alot more then 4000k. They just dont want an trouble from the lawyers.....
hkusp45 is offline   Reply With Quote
Old 04-27-2005, 05:12 AM   #8 (permalink)
Hey texag,
I just noticed you are a neighbor.
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
Old 04-27-2005, 05:37 AM   #9 (permalink)
Bama334's Avatar
Sharp truck!!
2004 Titan LE CC 4X4 Offroad Blizzard
PRG Performance Package
PRG Rear Shackles- PRG Sway Bar End links
True Trac
315 BFG's on factory 17" OR Wheels
Bama334 is offline   Reply With Quote
