Just thought I would share my comparison here of my previous tow vehicle, a 1997 Toyota Land Cruiser and the Titan. You can tell the boat is back there, no getting around that. The Titan handled "the boat" a little better then the Cruiser did, not so much power, just didn't bounce quite as much. I am sure if I did use the weight distribution hitch that my bouncing would probably go away. I towed with tow mode on and in 4th gear. The tranny temp never got past half way. My round trip was around 60+ miles.
Yomama -
2005 4x4 Canteen Crewcab SE with BT, OR, Utiltrak and Popular Package.
Ziebart rust proofing
A.R.E. Z series topper
Myron and Davis DVD for the kiddies, DDX7015 for me Kenwood amp and lightning amp on 8" polk sub. Audiovox remote starter (with satellite link)
Zoomers (No Drone) exhaust
AEM intake
Stillen Headers
2002 Hyundai Santa FE (The wifes)
2001 Polaris 700 Twin ATV
1996 28' Bayliner Cierra Sun
If it's bouncing, you may need to adjust the tongue weight.
Wouldn't I do that by using a weight distribution hitch? Funny thing is that it doesn't sag the Titan down much at all. I am not sure what the tongue weight is. It only bounces after going over some dips in the roads. I do feel better driving this then the shorter wheel base Cruiser.
Yomama -
AEM intake
Stillen Headers
You can also have problems with too little weight on the tongue. I believe the general rule is that the tongue should have about 10% of the weight of the entire trailer weight. Therefore, if your boat+trailer is 6,000 pounds, the weight on the tongue should be about 600 pounds.
If you say it doesn't sag the Titan rear end much at all, I'd bet there's too little weight on the tongue. You might need to adjust the trailer so the boat is moved a little more forward.
It is generally believed on the boating websites that I visit that a boat trailer is to be set up for 6-8% tongue weight as opposed to a travel trailer which is supposed to be 10-12%. I don't understand why there is a difference, but it is unanimously believed on those boards.
'04 Titan SE King Cab 2WD Deep Water
Popular Pkg w/ Captains, Big Tow
Added: OEM step rails & splash guards, leaf spring helpers, Line-X, TruXedo LoPro tonneau, Wade In-channel window visors
Born 6/3/04, Bought 7/5/04
A weight distribution hitch is just for equalizing the load between the front and rear axles of the tow vehicle. Has very little to do with tongue weight. Tongue weight on a trailer is adjusted by repositioning the boat on the trailer my moving the bow stop forward or back, or moving the axle locations.
I think that the bouncing problem may be exaggerated by the distance between the back of the truck and the trailer tires. That's looks like a long ways in the picture. There may be no solution to that if the weight is set up right. It's just a big boat and trailer. Be careful out there. I feel like I'm pushing the limit when towing my 24' Bayliner Ciera, your boat's little sister.
I have found with my travel trailer that it will make a big difference in bounce if you max out your tire pressure (44psi). It makes a difference but part of it is the titans suspension. If you read the posts, everyone has this problem to some extent. The stock tires are not for towing. Most LT tires for towing will max at 60psi or more.
Nice boat!! I wanna see some pics of it in the water!!!
I can't walk out on water to take a pic. LOL. If an opportunity comes up, I'll get one.
Yomama -
AEM intake
Stillen Headers
wow thats alot of boat , by chance how much does it weigh
Not exactely sure, but the boat dry is suppose to be 5800 something, 70 gallons of fuel is about 400 lbs and 20 gallons of water another 100 or so, then add the trailer weight which I assume has to be at least 1000+, plus gear....I am guessing.....It has to be close to 8k. If I get a chance to get it on a scale I'll give you the exact weight, of course that might make me afraid to pull it then. To think I used to pull this with my Land Cruiser rated to tow 5k, of course it was no ordinary Land Cruiser.... Suspension, bumpers, lockers and turbo charger.
Yomama -
AEM intake
Stillen Headers
