Old 10-14-2005, 12:42 AM   #1 (permalink)
Cali_Titan-SE's Avatar
Question Titans mods and towing question
Does anyone who has done mods to their Titan notice a difference, significant or otherwise , when towing a 6000+ load?
Does your mileage go up or down?
Thanks
Cali_Titan-SE is offline   Reply With Quote
Old 10-14-2005, 08:06 PM   #2 (permalink)
Vector's Avatar
Hard for me to tell, ever since I have done all of the mods to my truck, I cant seem to keep my foot out of the loud pedal. I always want to hear the K&N and Banks sing. My milage seems to be hanging around 14 mpg, but I am positive its because I have turned the gas pedal in to an ON/OFF Switch. I used to get 17 mpg, but I wasnt inspired to mash the gas pedal when it was in stock form. I am taking a road trip tomorrow, I should be able to let you know (if I can manage to keep my foot out of it).
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 10-14-2005, 08:48 PM   #3 (permalink)
mods/towing
I am pulling about 10,000lbs of boat. I have the mods done and truely believe they help with towing. I am at about 12-14 city and 17 give or take on the highway. Towing is about 6 -8.
samauri1 is offline   Reply With Quote
Old 10-15-2005, 08:01 AM   #4 (permalink)
loufish's Avatar
The only mod I've done is to switch to 35" tires, and so far my truck doesn't like it for towing...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-15-2005, 08:35 PM   #5 (permalink)
Vector's Avatar
Road Trip while towing
With 5000lbs of trailer and another 500lbs of gear in the truck + 400lbs of people, I averaged 13mpg keeping my foot out of it and setting the cruise at 75mph.
That was almost all highway driving. No city traffic. So not too bad if you dont try to pass people all the time while towing.
K&N Gen 2 FIPK
Nismo Pedals
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Old 10-17-2005, 01:02 PM   #6 (permalink)
Steamguy's Avatar
Positive difference
Thanks
Ours has a positive difference just from changing the exhaust. It's not so much the mileage but that the engine isn't working as hard. Temp gauge hardly moves out of the normal range, now.
We tow a 7000# travel trailer; if I was doing that more often, I might switch permanently to smaller wheels/shorter tires to lower the final drive ratio. The truck has the shorter tires on in the pic I've included here - these are the snow tires. Having the shorter tires on also makes the mileage go up a bit.
However we went from the low 9 MPG towing in our area to right at 10 MPG at 60 MPH average with the regular tires on. I've also changed back from the Airhog to the standard paper filter to get the mileage up a bit. Sort of an old mechanic's trick, but one that only works on fuel-managed vehicles. Did a couple of other things that help on a daily basis.
The way I make the mileage go down is to go and pass those guys with underpowered tow vehicles.
Steamguy
Finally found an appropriate sig pic. It's good at least through August...
Old 10-19-2005, 03:48 PM   #7 (permalink)
mlucero's Avatar
Thanks
No impact with mine mods, tow a 21 Cuddy cabin around 5.5k.
04 Radiant Silver SE KC 4X4, Big Tow, Utility Track
Air Box Mod w/ K&N High flow filter
Gibson Swept side Exhaust
Airaid TBS
TB coolant bypass
Royal Purple all around
Omega 8" Amplified Bandpass Tube
6 Kenwood KFC-P505ie 5-1/4" Midrange with 2 1" Tweeters
Planet Audio Amp
175W x 4
mlucero is offline   Reply With Quote
