Old 05-20-2009, 06:02 PM   #16 (permalink)
mjw357's Avatar
Re: Trailer Lights and Wiring Harness
Originally Posted by moondawg View Post
Any one know were to get adapter from truck to 6 prong trailer? Bought one at the store and center prong is for backup lights and not for brakes. Any help anyone?
Not sure what you are asking? Try HERE for wiring diagrams.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 05-20-2009, 06:06 PM   #17 (permalink)
loufish's Avatar
Old school....Change the 6 pin on the trailer to a new style 7 pin...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 05-21-2009, 01:36 AM   #18 (permalink)
Post Re: Trailer Lights and Wiring Harness
Originally Posted by loufish View Post
To the OP:
Turn/brake signals come from the BCM and a very popular TSB as already posted adds 2 "hidden" fuses in a BCM harness adapter.
These 2 extra fuses are pretty much unknown to Nissan techs & service writers, they are also NOT included on wiring diagrams...
2005 Titan KC - wiring harness problems!!!
Okay, here is the thing.. I have a wiring harness problem.. A tree branch dislodged the trailer adapter (which is a 7-way and 4-way flat that has a 5-way spliced into the adapter) from the bumper of my 2005 Titan KC during a hurricane. However, the trailer adapter was still connected to the OEM plug on the truck. When I hooked up the boat trailer, none of the lights were working. U-Haul installed the hitch and trailer adaptors, so I took it to them. The tech checked the fuse, which was blown, and after replacing the fuse, only the right side lights were working. He replaced the relays, but still no lights on the left side. The tech could not find the problem after spending half a day working on it, so I went to another hitch installer, and they recommended I go to the dealership, because he suspects it could have something to do with the BCM.
I went to All About Nissan and cannot seem to find the TSB about the 2 hidden fuses in the BCM harness adapter... Any thoughts on locating this?
Also, I am taking the truck to the dealership tomorrow, but want to ask if the service techs know about the 2 hidden fuses in the BCM harness adaptor you speak of? Or should I mention this to them?
Thanks,
cvaldejo
cvaldejo is offline   Reply With Quote
Old 05-21-2009, 06:49 AM   #19 (permalink)
loufish's Avatar
The BCM runs the rt/lt brake and turn signals. The TSB added a small sub-harness right off the BCM, located right around the steering column above the brake pedal area. The sub-harness is usually white in color...
I'd look for this myself before paying someone at Nissan to be stumped because very few techs know anything about this...By all means, let the Nissan guys know that's there's a "hidden" harness off the BCM that contains 2 fuses...
Print this and bring it with you....
Born 9/2004
2002 Honda XR650R
Old 05-31-2009, 08:52 PM   #20 (permalink)
Okay I am really going to have to look at this too!!
I just rented a trailer and the left trailer lights...brake and turn were not working...used a test light and checked all fuses and tried to trace the wiring but I will looking at this one tomorrow, because I couldn't find anything wrong but I wasn't getting a signal to the trailer!!!
If I find these fuses I will take pictures for you all!!
SweetRide is offline   Reply With Quote
Old 06-01-2009, 10:32 AM   #21 (permalink)
Okay thank you guys for the great info, thought I would post the pic to help share the wonderful knowledge!!! There are 2 fuses and the one on the right was out, works great now!!
In this picture are the fuses which you don't have to take off the knee bar to get to, I did to help with the picture and I also wanted to get my rear parking sensor zip tied back in per that TSB!!
I should also say that this is the drivers side, tucked up above the accelerator pedal!!!
Old 06-01-2009, 06:27 PM   #22 (permalink)
loufish's Avatar
Great photo...thanks for sharing
Born 9/2004
2002 Honda XR650R
Old 06-26-2009, 04:41 PM   #23 (permalink)
Smokinnitro's Avatar
WOW You guys rock I must have tore every connection that truck had to figure out why my trailer lights would not work. There is nothing in the owner manual telling you there are fuses under the dash. Thanks again
04 SE CC Titan Canteen Green
Smokinnitro is offline   Reply With Quote
Old 06-26-2009, 10:25 PM   #24 (permalink)
loufish's Avatar
Now you know more then most Nissan techs....
Born 9/2004
2002 Honda XR650R
Old 10-21-2009, 02:54 PM   #25 (permalink)
I was going crazy trying to figure out why my right side trailer lights didn't work.... Blown fuse!! Thanks for the pic.. helped out 1000%
PRG3216 is offline   Reply With Quote
Big Tow Trailer harness kartman Titan Towing & Hauling 11 09-15-2005 08:12 PM
trailer wiring harness question Franco Titan Towing & Hauling 1 06-26-2005 08:10 PM
Wiring Harness - Non-Tow Package dd564 Titan General Discussion 14 12-26-2004 09:07 AM
Wiring Harness ttammunek04 Titan General Discussion 5 04-19-2004 01:22 PM
