Old 02-09-2006, 06:14 AM   #16 (permalink)
PhatSami's Avatar
Re: Odd Things you've towed
Strangest thing I've towed - A 1978 F-350 long bed.
Wouldn't the tires insulate the truck and keep you from getting zapped?
"If I can touch it, I can destroy it". Greg Graffin - Bad Religion
PhatSami is offline   Reply With Quote
Old 02-09-2006, 07:40 AM   #17 (permalink)
phlydude's Avatar
man, you guys have me beat
The best I could come up with is a cement mixer with a hoop hitch sitting on a ball hitch where we had a Scottish plasterer named Hugo standing on the trailer arm to keep it from coming undone when we hit bumps while driving a mile or so to a work site from the rental house. But that was with a turd F-150 back 12-13 yrs ago...
I do Blu, do you?
phlydude is offline   Reply With Quote
Old 02-09-2006, 07:59 AM   #18 (permalink)
konigfritz's Avatar
I tried to yank a 2 foot daimeter oak tree trunk outta my yard with the titan. Broke the tow strap. So I rented and excavator. that thing rocked. If you ever get chance do the same. It will be the most fun you ever have with a 3 cylinder diesel!
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 02-09-2006, 08:33 AM   #19 (permalink)
helomech's Avatar
Towed a bunch of tree parts form hurricane katrina and rita, still not finished yet. And yes the tires should insulate the truck unless the amps are high enough for the spark to jump from the rim to the ground.
Old 02-09-2006, 09:41 AM   #20 (permalink)
Send a message via AIM to Timba24
I know the tires arent enough to insulate against lightning not sure about power wires
Timba24 is offline   Reply With Quote
Old 02-09-2006, 09:46 AM   #21 (permalink)
helomech's Avatar
Not sure either, but I don't want to find out.
Old 02-09-2006, 01:22 PM   #22 (permalink)
JAFCO's Avatar
Helped a buddy move his 14'x70' house trailer with a '79 Chevy 3/4 ton 4x4. Dropped the pindle hitch over his trailer ball and headed down the highway. could only do about 20mph since the front end was barely touching the road
06 KingCab LE - Sparkle Red
painted BushWacker flares
Lund Stainless Steel Bug Deflector
2.5" leveling kit
Reese 5th Wheel Hitch
Ride Rite Rear Air Helper Springs
SEC checker Plate alum toolbox c/w inside sprayed liner
Pulling a
2002 Keystone Sprinter 25' FW
JAFCO is offline   Reply With Quote
Old 02-09-2006, 01:29 PM   #23 (permalink)
There's an area on West Tawakoni Lake with a nice, long stretch of beach you can get a vehicle on. I've towed a couple buddies on ski's across there from the beach with my old 87 Nissan 4x4.
Oh, to be in my early 20's again and be stupid enough to get myself or my friends killed or seriously injured... LOL
Blackin is offline   Reply With Quote
Old 02-09-2006, 01:47 PM   #24 (permalink)
Blackbeauty's Avatar
Got one from a co-worker. This one is even more obvious than my "high wire act". He had a mailbox mounted on one of those big playground springs cast into a block of concrete. He lives where teenage boys with baseball bats go around and play target practice with mailboxes. He figured the spring would act to keep the mailbox from getting too beat up. So, somebody drove over it in a snowstorm and ripped the mailbox off. His wife told him to get rid of it. So he hooked it up to a chain to the back of his Bronco II and figured he'd just yank it out of the ground. (You can see it coming, can't you). Well, he didn't until the spring broke off just above the concrete and came through the rear window of his Bronco. He said he was sure glad he wasn't stupid enough to hook it up to the towhooks on the front!
Old 02-09-2006, 02:07 PM   #25 (permalink)
konigfritz's Avatar
I have had a similiar one to that. After Hurricane Floyd, we had lost 14 trees. Luckily only one was laying on the house. When friends have heavy equipment, stupidity rears its head. We took large backhoe to lift up the tree and then with me in a big ol' dump truck we tried to yank it off the house. The 10 ton tow strap snapped nearly missing the backhoe driver and went right through the siding on the house.
04' Galaxy CC/BT/OR
2* Timing Advance
Old 06-17-2006, 10:01 PM   #26 (permalink)
ripped a tree right out of the ground today. 4lo did the trick. pulled the stump right out.
desmon is offline   Reply With Quote
Old 06-18-2006, 11:34 AM   #27 (permalink)
redneckpapa1996's Avatar
I rented a 16ft. trailer from nations rent that ended up being a heavy-duty car trailer with ramps and a 2-5/16" hitch.. Guess i should have asked or they should have told me.. Anyway i needed it for a 44 square roof tear-off and had to make it work.. I got some 4x8 sheets of plywood and made side-boards to keep the shingles on the trailer..The boys at nations rent said that my `04 le cc 4x4 was not a 3/4 ton and would never tow it safley and made me sign a waiver in case i damaged my truck HAHAHAHA!! Once i had 44 sq. of shingles and other trash related to a roof tear-off loaded on the mighty titan i just had to go by the rental store to show those jerks a real truck.. The shingles alone weighed 9250lbs so the load was over 12000lbs and the titan never even strained on the 15 mile trip up and down the TN. hills to the dump site. This is one awsome truck!!!
redneckpapa1996 is offline   Reply With Quote
Old 06-18-2006, 02:44 PM   #28 (permalink)
I pulled this disk for about a mile. Should have used the tractor and lifted it off the ground.The Titan pulled the disk, but wasn't happy about it, especially going up hill.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Towed my first load. Did great. Colorado_Titan Titan Towing & Hauling 9 02-03-2006 01:24 PM
Towed 5000 miles floridatitankid Titan Towing & Hauling 5 10-31-2005 07:58 AM
Towed a Chevy today rizzo Titan General Discussion 0 02-20-2005 07:12 PM
What's the heaviest load you've towed... DaveS Titan Towing & Hauling 31 12-10-2004 11:33 AM
Towed A Forklift Out Of The Mud PanAm Ken Titan General Discussion 10 07-20-2004 02:39 AM
