Towing the Titan behind an RV? - Nissan Titan Forum
Old 03-23-2006, 11:35 AM   #1 (permalink)
tillery444's Avatar
iTrader Score: 1 reviews
Is it possible tow a Titan 4x4 behind a RV using a tow bar & not damage the truck mechanically? Mosty short trips under a few hundred miles.
Elz
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
tillery444 is offline   Reply With Quote
Advertisement
Old 03-23-2006, 11:49 AM   #2 (permalink)
iTrader Score: 0 reviews
Re: Towing the Titan behind an RV?
Not sure, but over the weekend in Orlando, we saw an RV pulling and H2 Hummer.
BullGatorTitan is offline   Reply With Quote
Old 03-23-2006, 11:56 AM   #3 (permalink)
Banned
TitanFan59's Avatar
This is a tough one. If there is a serious concern just disconnect your drive shaft and you'll be fine. Spinning the rear without drivetrain load might not be good for our weak link if you will.
TitanFan59 is offline   Reply With Quote
Old 03-23-2006, 11:59 AM   #4 (permalink)
sonnytimes's Avatar
It tells you in the owneres manual something about this. I think it said not to but I would check it out.
And the daily beatings will continue until morale improves.
Or until you figure out how to use their system against them.
04 LE 4X4 OR
05 and 06 Rear ends....
05 Bed, front seats, AC parts, brakes, window reg., .....
sonnytimes is offline   Reply With Quote
Old 03-23-2006, 12:04 PM   #5 (permalink)
tnbowhunter's Avatar
As far as I know NO vehicle with an automatic tranny should be towed.
I suppose you could disconect the drive shaft but in my opinion it would be more trouble than it is worth and you would still run the risk of damaging your driveline.
"It is not through knowledge, but through experience of the world that we are brought into relation with it."
__Albert Schweitzer
2011 Toyota Tacoma, Super white, access cab, TRD off road pkg., TRD performance exhaust. 20+MPG.
Old 03-23-2006, 12:06 PM   #6 (permalink)
Banned
Lowmpg's Avatar
Why not pull the RV with the Titan?
Lowmpg is offline   Reply With Quote
Old 03-23-2006, 12:21 PM   #7 (permalink)
tillery444's Avatar
I like to take short trips around SoCal & Baja for off-roading/beachgoing etc. I have a great RV thats perfect for the family, the only problem is the beast feels left out & I would like to take her along.
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
[/img]
-[/img]
Old 03-23-2006, 12:41 PM   #8 (permalink)
Steamguy's Avatar
There are very few auto trans vehicles that can be towed 4-down. This is because the internal lubrication of these transmissions is accomplished by a pump that runs off the input shaft, and the internals of the transmission also do not completely disconnect from the output shaft when in Neutral. So you have spinning objects, not lubricated. Which means if the vehicle is rolling without engine power, transmission damage can result.
You used to be able to get a 'disconnect kit' that would allow you to disconnect the driveshaft from the transmision with the pull of a lever, but this used to be thought of as a chancy mod for some 4WD vehicles because of the changed angles for the driveshafts, and the possibility of changing the final gearing in the rear axle only.
Hope this helps.
Steamguy
Deepwater Blue, when it's not Dirt Brown. Yes, this truck is used as a TRUCK. If I wanted something to sit in the driveway and look pretty, I'd have bought another motorcycle.
Trailer-puller, meadow work truck, thrill ride for a rescued Golden.
Old 03-23-2006, 12:44 PM   #9 (permalink)
Banned
TitanFan59's Avatar
I havne't checked the shaft on the Titan but It was pretty simple to do on other vehicles I've bar towed.
Old 03-23-2006, 01:02 PM   #10 (permalink)
tillery444's Avatar
I wonder if a tow dolly would work?
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
[/img]
-[/img]
Old 03-23-2006, 01:04 PM   #11 (permalink)
In a word, NO. Your options are:
Don't tow anything with the RV
Go through the trouble of disconnecting drive shaft every time
Get a trailer and tow the Titan
Tow a different (maybe a jeep if you want 4x4) vehicle 4 down
rtapia is offline   Reply With Quote
Old 03-23-2006, 01:15 PM   #12 (permalink)
nytitan1's Avatar
iTrader Score: 2 reviews
look in owners manual says absolutely not to tow 4x4 with all four wheels on ground must be towed on flatbed.
nytitan1 is offline   Reply With Quote
Old 03-23-2006, 01:16 PM   #13 (permalink)
iTrader Score: 7 reviews
No the only way to tow is with a flat bed trailer with your 4x4. You can get a transmission disconect but it is very pricey and not woth the $3500 to install but then you have to get brakes on the Titan that apply when you hit the brakes another $1400. Wit all that money you can easily by a flat bed and sell it when you are done to recoupe some of that $. If you put it in the truck you wont get your money back. What kind of RV do you have? If its a class C forget it. A super C with a Kodiak chassie will do it like and Endura. Some class A's wont even tow that kind of weight. After the trailer added in you are looking at somewhere around 7500 lbs. Then if you load your RV up alot you are way over and not worth the rick especially if you have kids!!! Hope this helps.
Old 03-23-2006, 03:41 PM   #14 (permalink)
HudsonValleyTitan's Avatar
Only safe way to tow it would be on a trailer with all 4 wheels off the ground. The front end can't be disconnected on Titans.
- Joe
NEW - 2008 Blizzard Titan Crew Cab PRO-4X OFF ROAD Long Bed w/TOW, 37 gal. fuel tank, Utility Bed & Rockford Fosgate pkgs w/XM Sat. & Bluetooth handsfree, BullyDog Power Pup Tuner, Nissan bug deflector, Under seat storage box, Nissan factory step rails, Volant LED taillights, Recon Line Of Fire LED Light Bar, Nissan chrome door handles & tow mirror covers, Nissan chrome Tailgate bib, Nissan polished stainless exhaust tip, Garmin Nuvi 1300 GPS, Extang Tuff Tonno Cover, 275/70/18 BFG All Terrain KOs.
Old 03-23-2006, 03:56 PM   #15 (permalink)
robertc's Avatar
LOL
The Titan has more Horsepower than my small block 6.0Liter that powers my Motorhome but of course not the towing capacity. The Chevy Engine in my Motorhome is 300 H.P.
2006 Nissan Titan SE KC 2WD
Smoke
Born 11-05
Popular Package w/power Captain
Rockford Fosgate 6 Disc MP3/WMA
Utili-trac Channel System
Bedside Lockbox
Rear Sonar System
Step Rails
Creative Zen Sleek MP3 Player (What's an
IPOD )
2007 Nissan Versa SL
Power Package
Convenience Package
Sunroof
5 Disc in dash CD/MP3 /Sirius Satellite
with 8 speakers and Rockford Fosgate Subwoofer
Intelligent Key keyless ignition and entry system
robertc is offline   Reply With Quote
Advertisement
Titan Towing TitanBill Titan Towing & Hauling 16 08-03-2010 08:46 PM
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 06:48 AM
Towing an RV with a Titan jcrow Titan Towing & Hauling 24 05-17-2006 07:21 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
Towing with New Titan Titantow4 Titan Towing & Hauling 5 03-14-2004 07:45 PM
SEO by vBSEO 3.3.2
