Old 01-07-2007, 10:59 AM   #16 (permalink)
Re: Welcome to the New Towing and Hauling Forum!
I am interested in buying a 5th wheel, but can not locate a 5th wheel hitch or any information that would assist me in deciding weight and length for a 5th wheel that would allow a Titan to pull a 5th wheel through Western State mountians.
Bob Smallback is offline   Reply With Quote
Old 01-07-2007, 11:20 AM   #17 (permalink)
Aquaholic's Avatar
Cool once I hit 1500 miles and can throw my trailer on the hitch. I'll have to chime in.
2007 White with Charcoal/Titanium interior SE CC 4x4 with off road, tow, SE popular with bench, and utility bed package with sliding bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 325/65/18 Kuhmo Road Venture All terrains, 18x9 Moto Metal 954s, Stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, Rubber bed mat, T Rex Full face grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Infinity Reference 6 1/2's in rear and 6x9's in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 01-07-2007, 02:21 PM   #18 (permalink)
Try Pullrite for their SuperGlide 12K slider hitch made for a short box . It's fully automatic so may save a crunch with the short box trucks.
A caution here though, the Titan payload/rear axle rating limts the 5W pinweight to about 1200# or less depending on what you are carrying in the truck in the way of people and cargo. Allow increasing brochure pinweight about 50%.
You are far better off with a ball hitch travel trailer and a weight distributing hitch. Put a cap/canopy/topper on the Titan and it holds more than the pass-through storage on a light 5W. The lower profile also makes it an easier pull = better mpg.
We bought the Titan specifically as a tow vehicle. All lubes are Mobil 1 except tranny. Brakes were upgraded at first service per pre-arrangement with the selling dealer.
To date we have towed about 10K miles with a 28' TT, total load about 8500# wet, and no problems. AB-CA-AZ-CA-AB last winter and AB-IN-FL so far this winter.
A lot of mountain towing, always with CC set at 55mph and with OD and Tow/Haul engaged. Climbs most grades without dropping to 4th and only occassionally to 3rd and sometimes 2nd on steep grades of 6%+. Has never been unable to maintain set 55mph. I manualy downshift the tranny to slow on steep downhills to save brakes. We have averaged 11.5mpg with a high of 13.0 mpg and low of 9.5 mpg. (Not much better solo around town sorry to say) Have never had high temp engine or tranny.
Hope this helps.
Titan4RV is offline   Reply With Quote
Old 01-12-2007, 08:25 AM   #19 (permalink)
I have a 2005 kingcab w/tow package. Am pulling a Flagstaff 30' 5th wheel with a loaded weight of about 8K lbs. I have a Husky 16K Easy Roller hitch which is a sliding type for short beds. I installed a Gibson Catback exhaust and Roadmaster active suspension on the rear axle. So far, has worked out very well. Be sure when towing, to use the "tow mode" switch and 4th gear.
JAM21
JAM21 is offline   Reply With Quote
Old 04-24-2007, 06:58 PM   #20 (permalink)
Looking at a 04 Titan with towing mirrors and a hitch. How can I read the VIN no. to tell what gear ratios and other towing info this truck may have?
flicka5 is offline   Reply With Quote
Old 04-24-2007, 07:40 PM   #21 (permalink)
loufish's Avatar
Check for the factory trans temp gauge in the dash...If it's there, it has the factory tow package...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-24-2007, 10:58 PM   #22 (permalink)
Sammy Sandbag's Avatar
Correct me if I'm wrong, but there should also be a little tag on the rear axle stamped with the ratio.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 05-01-2007, 11:47 AM   #23 (permalink)
So I just installed air bags on my 06 Titan. Pretty cooll! I wanted to share what my step-son came up with. He was lloking for a place to run the intake valve for the bags. He had the idea to put a compression "T" so as to connect the two bags and fill them simultaneously. Better yet, he decided to run the intake valve through one of the screw holes for the license plate and ran it through there. You can barely notice it is there and all I have to do now is unscrew the cap and fill the bags through the valve in the license plate. I thought it was pretty ingenious.
Titan_Love is offline   Reply With Quote
Old 06-24-2007, 11:39 PM   #24 (permalink)
DigitalMat's Avatar
Question Re: Welcome to the New Towing and Hauling Forum!
Greetings! New to the forum. Just bought a 2006 Titan yesterday. We plan to tow a 24 foot 5th wheel that grosses 6000 pds. We got the hitch in the trade, but need to find the rail mounting kit. Will these kits fit all the hitches, or are they proprietary?
We have the King Cab with 6 1/2 foot bed. Any input appreciated. I've towed a popup camper with a minivan, but this is new to me. Studying... Thanks!
DigitalMat is offline   Reply With Quote
Old 06-25-2007, 01:55 AM   #25 (permalink)
Fox Delta's Avatar
Do the bags have a one-way valve on them?? That way when you corner and compress one side the air doesn't flow to the other side (back and forth like on a raft)?? I thought they were always seperated to prevent that unless part of the "nicer" kit. Sorry, I don't have a better understanding of the airbags - it just seems that if the manufacturer intended for the air lines to be connected it would be part of the setup from the beginning. Plus it would stink to lose the air pressure when needed the most.
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 11-04-2007, 08:16 PM   #26 (permalink)
I really need help figuring out the wiring on the towing package for the 2005 Nisson Titan. I took it to the dealer and paid 300.00 and assuming they knew what they were doing, it was a while until I hooked up to a trailer that I knew was working on other vehicles. All I get are tail lights. does anyone know the color sequence of what the wiring is? I really appreciate your help< as you can imagine this is getting frustrating. You can contact me at werhotcpl@yahoo.com
And again thanks to anyone who can help me on this.
Terry is offline   Reply With Quote
Old 11-24-2007, 03:41 PM   #27 (permalink)
hello 2004 titan here
jeff2004 is offline   Reply With Quote
Old 11-24-2007, 05:33 PM   #28 (permalink)
BuckyBadger's Avatar
Welcome to the forums, Have a great stay
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06
FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
BuckyBadger is offline   Reply With Quote
Old 11-24-2007, 11:31 PM   #29 (permalink)
loufish's Avatar
See if any of this helps...The wire color might be different on the Titan, but the way it's wired won't:
welcome-new-towing-hauling-forum-7pole.jpg  welcome-new-towing-hauling-forum-7-way-tow-vehicle-connector.gif  welcome-new-towing-hauling-forum-7way-travel-trailer-connector.gif
Born 9/2004
2002 Honda XR650R
Old 12-30-2007, 06:56 PM   #30 (permalink)
DrPlay's Avatar
Hello everyone:
I'm a 2 day owner of a new 2008 Titan Crew Cab 4x4 SE with tow package. I own a 2006 25'Airstream International travel trailer. Airstream is 5600lbs dry and 7300lbs fully loaded (in reality should be about 6300lbs loaded). With passengers, tongue weight and cargo the Titan should be loaded with about 1500lbs -- Titan rated at 1650lbs). Titan can pull 9300lbs. I have Prodigy brake control and Reese weight distributing/sway control hitch. Did I rush into this truck? Can it handle the job? Should I have gotten a 3/4 ton? Hope not I LOVE this truck.
DrPlay is offline   Reply With Quote
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 07:48 AM
New to forum, have questions about towing Heem Titan Towing & Hauling 14 02-17-2006 04:06 PM
hauling a board jkiller5150 Titan General Discussion 4 02-10-2005 10:01 PM
Hauling the '56er Reignsone Titan Pictures & Media Post 3 09-10-2004 10:13 AM
