Re: "Rear/Front" Sway Bar Recommendation - Actual User
i have looked at both stillen and hellwig and i think i will order the stillen. i don't know about the way the hellwig mounts rear facing. i had a hellwig kit on a chevy truck and when i installed it had a issue with there hardware,actually broke a j-bolt that was used to hold the a clamp for the end link when i installed it. the u bolts and nuts seemed cheap, when i torqued the u bolts the washers bent a little, as if they were a lower grade steel.i called stillen and spoke to kyle there and he said you can use there rear kit with the titan stock front bar no prblem. hope this helps
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
HELLWIG REAR SWAY BAR
LED TAILLAMPS
RANCHO RS 9000 SHOCKS
