$2400.00 Spare Tire.... - Nissan Titan Forum
post #1 of 14 (permalink) Old 06-14-2017, 09:27 AM Thread Starter
iTrader Score: 0 reviews
As I write this post, I’m now home, and my truck is almost 600 miles away in a Nissan dealership….towed there two days ago. There’s a moral to this story...and I’ll give it up front…believe in Murphy’s Law! Also, no matter how much you think you know….you don’t know what you don’t know!
Here’s the deal….My spare tire caught fire! Now, I’m 68 years old and never in my life had I ever heard of a spare tire stowed away in it’s spot catch fire. No one I've talked to since has ever heard of it. I’m not a fan of under-body spare mounts for all the reasons of failed hanging systems, corrosion etc. that everyone is familiar with, but now I will forever be wrapping the exhaust pipe where it humps over the axle….and that’s if I ever carry a spare there again...I am seriously considering a roof mounted carrier just for the spare.
The wife, dog and I were returning to Ohio from Cape May pulling the 30ft. TT and dealing with all the PA road delays, unmarked detours, single track work zones etc. when we were in a single track on I-80 doing the crawl when I noticed a waft of what looked like exhaust smoke in my rear view….I thought it exhaust, which I never have seen before, but still, that was what first came to mind. Now, it was 97 degrees so the air was pumping cold and windows up….so we didn’t smell anything. As soon as we exited the single track I pulled over and the smoke was full boat and the tire was burning where it was closest to the pipe...about 4 inches is the distance for the stock tire size. Had the wife and dog get away while I pulled the fire extinguisher out and it was pure luck that it did the trick and put the fire out. I shot right in through the rear passenger wheel well. Anyone who’s been around burning tires knows they don’t extinguish easily. I dropped the tire and pulled it away from the truck….just in case. I’ll post a pic when I get the truck back.
So...how did I get to 2400.00? After we calmed down and got ourselves put back together and ready to roll on….the truck wouldn’t start. All was normal looking both under the truck bed (other than all the fire extinguisher dust), the dash lit up normal, lights all worked etc. etc.,no CEL, but the engine wouldn’t catch….like a failed fuel pump. Maybe the black and yellow wire was fire damaged..... Called AAA…..and they won’t touch a TT, so that was a separate tow to the dealership, and not for free.
As of right now, the dealership is replacing the entire wire loom between the firewall and the rear bumper. They found 9 fuses blown...so far. Clearly the heat melted the wires and made for shorts that were disastrous. The wire harness was cross shipped, which added a day to the wait….hotel room..with surcharge for having a dog.
Since I have a fairly good background in repair, I worked with the Service Manager to get a plan of repair that was based more on diagnostic repair rather than all on guessing by the tech, since, like I said, I have a decent repair background. Before anyone even had the truck in the bay they were guessing that 1. the battery was dead (yes, after 5 hours of flashers and failed starts, you can kill a battery to the point of needing a charge), 2. the exhaust must have a big rust hole in it, you will need a new exhaust system (no, the exhaust is one year old, installed by me and was coated with corrosion inhibitor and high temp paint by me prior to install).. 3. the rear diff is failing and it got so hot it started the tire on fire ( I have no response to the stupidity of that). When I showed up to get some things from the truck, the windows were down, doors unlocked and the tail gate was closed improperly and was crushing the gasket for the bed tarp and not the right way….and it was sitting in a spot that wasn’t visible from anywhere in the dealership. I wasn’t a happy camper..pun intended.
So, since the gas tank has to be dropped to install the harness, I made sure they would test the fuel pump before rehanging the tank. That way they wouldn’t go bat crazy trying to diagnose between a failed relay vs failed fuel pump blowing a fuse. They also were absolutely certain that the ECU is cooked. I told them to bring in a reman, but I didn’t authorize a blanket install without testing post harness installation. I’m convinced that if an ECU is cooked, you don’t get a normal boot which is evident at the dash when turning the key to ACC, then ON, then Start. You also get a CEL 90% of the time. So, if they don’t have to replace the ECU, subtract about 800.00. But they still have to check the IPDM to diagnose it's condition.
All in all, dealer charges, rental car, hotel, food, new spare tire (and maybe rim!), towing charges, damage to bed liner and effect on resale, days of inconvenience and so on…...It’s a lot cheaper to buy $45 worth of dynawrap and avoid what may be a once in a lifetime problem that only happens to me, or not. Oh, and I had to pull a listing for a rental property until I get the truck back because the keys and garage door openers are in the truck….That’s another $1350 lost for a month of rent. So it' really is a lot more than $2400!
Nick Name is offline
Advertisement
post #2 of 14 (permalink) Old 06-14-2017, 11:22 AM
FishnAlaska's Avatar
Garage
iTrader Score: 3 reviews
Re: $2400.00 Spare Tire....
Sounds to me like the exhaust pipe rusted out, hot exhaust gasses started melting either the harness or the tire and something caught on fire. How old is the truck? Many have had the exhaust rust through where it jumps over the rear axle, right where your fire started it seems. Sorry about the crappy luck, but glad your safe and got the fire out before the truck burnt to the ground.
2010 Titan 4x4 CC SE Majestic Blue
Uprev tuned by Seymore, JBA Evol catback, Cajun catless B pipes, Airaid MXP 4" CAI
8" Boston acoustic's sub in Tech12volts ported box w 1000 w renegade amp
Autostart remote start, bedlined OEM wheels, bumpers, and grill. Go Rhino D2 steps.
Pyramid Automotive Retro fit headlights with Xenonvision H1 Hid's and super bright LED reverse lights, blue interior LED's, and white exterior LED's.
Smoke hood shield and in channel window deflectors, Custom grounding kit by FAK.
Pro4X skid plate, 20" double row Cree light bar, rear bumper flushmount Cree LED's
Leer 100R Topper, Goodyear Duratracs 275/70/18,
Dirt King UCA's, Bilstein 5100's mid setting and 1.5" spacer, 1.5" rear block w/Bilstein 5125's.
FishnAlaska is offline
post #3 of 14 (permalink) Old 06-14-2017, 11:33 AM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
Sorry my state killed your Titan.
Oddly I was under my truck doing shocks and remembered I hadn't dropped my spare, ever. Last weekend I finally did it and to my surprise she dropped right down without any fuss after 12 years stowed. Sure the spare only had 10 psi in it so I filled her back up and re-stowed the spare.
Fishin' is right about the harness in the area of the axle and wire loom. The did pick a few spots on the Titan that shouldn't have electronics and that is one. the other is the BCM module right behinds the fender liner on the passenger's side. Still, I haven't had any issues in my ownership going all the way back to '04.
Good luck getting it sorted out. You just reminded me that I need to put a FE in my bed for such incidents. Cheap insurance
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a
Enclosure
PA Chapter Director
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #4 of 14 (permalink) Old 06-14-2017, 11:36 AM
iTrader Score: 1 reviews
Holy Crap - What a story! Sorry to hear about your bad luck!!! I was extremely close to having a similar situation... But my was Negligence in that my tail pipe section of exhaust had rusted off and I didn't fix it for a while. I had melted the plastic shock guard and started to melt into wires... I must of caught it just in time... I re-wrapped the wires in electrical tape and did a full exhaust - headers back from Cajun... Hopefully your insurance will eat some of this cost - if not, might be time to start shopping around
Rage232 is offline
post #5 of 14 (permalink) Old 06-14-2017, 12:20 PM Thread Starter
Fish'n.....As I said....brand new pipe with corrosion coating and high temp paint applied, by me, one year and 3000 miles ago.... and I'm sure I'd notice a big old rust hole in a truck that doesn't see winter weather.
I did google and found two other reports of spare tire fires.....on tow vehicles. When pulling, the radiator does its job so the gauge barely moves, the trans cooler does its job so the gauge barely moves. What happens is an increase in exhaust gas temperature due to the amount of fuel per stroke of the engine when pulling...especially pulling up hill and the infra red heat emitted from the exhaust pipe is pretty high up in the Farenheits with a tire just 4 inches away from the pipe. Sort of like holding your hand over the charcoal grill.
There's no exhaust gas temperature sensor installed in any gas engine tow vehicle I know of, but monitoring exhaust temp is almost always a system used in current diesel engine designs...up at the head, not at the tail pipe. It's also used in race applications of gas/ethanol/methane designs, but not in the average everyday half ton truck. It's easier for me to put heat shield wrap around that location on the pipe and forget about future problems with wires or anything else.
post #6 of 14 (permalink) Old 06-14-2017, 12:58 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
For what it's worth, I have towing insurance from Good Sam Club. It covers both the trailer and the tow vehicle. I haven't had to use it yet so I don't know how well they'll come through but I've heard good things about their service.
Is it possible that your aftermarket exhaust moved the pipe closer to the tire than the OEM system?
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #7 of 14 (permalink) Old 06-14-2017, 03:23 PM
danman's Avatar
I've heard of something similar to this before...
. You mentioned you had the OE exhaust, maybe something similar to this? That does suck big ones.
Mods - PRG Lowering shackles, JBA LT's, UpRev, some exhaust work, PRG heimed RC traction bars, Hellwig Rear Sway bar, Weathertech floor mats, Carhartt Seat Covers, Debadged, Tow Mirrors, Axle vent mod, Bilsteins
Wish List - Spray in bed liner, EBC brakes that aren't warped
danman is offline
post #8 of 14 (permalink) Old 06-14-2017, 05:02 PM
dam Nick, that suck, glad all of you are ok...
Pale Rider is offline
post #9 of 14 (permalink) Old 06-15-2017, 11:54 AM
first off, i'm glad everyone was ok, that was crazy what happened. With a newer exhaust like you say i'm not sure what would of caused the fire.
in my case last summer my exhaust did rust at the flange and melted the wire harness back there. whatever wires got melted did fry my computer and i was dead stick at 60mph with a travel trailer behind me. not a fun feeling. I did have a Christmas tree of lights on the dash though.
i'll be interested in what the root cause ends up being. good luck, glad you all are ok.
jeerme is offline
post #10 of 14 (permalink) Old 06-16-2017, 08:01 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
There obviously was a leak in the exhaust.
I wouldn't of fixed it, I would of just traded it in, especially because you probably could us a larger TV like a XD.
Having the proper breakdown insurance comes in handy.
Sorry for your troubles & glad you guys are ok.
* Edited*
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
2016 XD Pro4X Gasser
AZPRO4X is offline
post #11 of 14 (permalink) Old 06-16-2017, 09:07 AM
GalaxyPro4X11's Avatar
Originally Posted by AZPRO4X View Post
There obviously was a hole in the exhaust & you got major rust issues.
I'd be pretty shocked if he had a hole or major rust issues on a year old tailpipe. They salt the hell out of my area in the winter plus I live on the coast an I don't see that kind of issues in a year.
Performance mods:
UPREV tuned by RB's Titan, MXP CAI, JBA 304SS headers ceramic coated jet black 2000 degree coating, 2.5 Resonated Cajun B-Pipes an catback with Borla 18" XR1
Suspension mods:
6inch stage 2 procomp, extended travel bracket lifted Radflo Coilovers with PRG top hat, PRG UCA's, PRG Off-road trac bars, Deaver C-30's with 2" block an PRG adjustable shackles with bilsteins in the rear.
315-60R20 Toyo mud terrains with 20x10 -18 matte black fuel Vapors
Future Mods:
Level 10 trans when warranty runs out
Remote res rear shocks
Install my grizzly locker
GalaxyPro4X11 is offline
The Following User Says Thank You to GalaxyPro4X11 For This Useful Post:
Nick Name (06-17-2017)
post #12 of 14 (permalink) Old 06-17-2017, 12:39 PM Thread Starter
The tire......the pipe. AZ....as you will notice, no hole, no rust, no BS.
00.00 Spare Tire....-trog20170615_01.jpg   00.00 Spare Tire....-trog20170615_02.jpg
post #13 of 14 (permalink) Old 06-18-2017, 05:52 AM
danman's Avatar
Hey Nick, i am not a fan of the looks on that aftermarket tailpipe. I have never seen a Titan tailpipe with bends like that in it. I am wondering that the bends maybe off a touch and could be a little too close to the spare. I know the OE pipes are close, but maybe this one was too close. have you ever towed long distance with your T and TT since the exhaust install? I am wondering if the combination of new exhaust, taxing of the powertrain causing excess heat of the exhaust, and high temperatures would have caused the tire to catch. I am assuming that the exhaust pipe and spare were very close.
danman is offline
post #14 of 14 (permalink) Old 06-18-2017, 06:51 AM
AZPRO4X's Avatar
Looks like monkey put that pipe together. Also, I wouldn't even think about hooking up a trailer to that rusty mess, everything looks compromised.
AZPRO4X is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
WTB Tire Gate Spare Tire Carrier ForgedSpartan7 Want To Buy 0 02-02-2016 01:47 PM
WTB: spare wheel/tire and lift for said spare Jaredhhhh Buy/Sell 1 12-19-2013 07:30 AM
WTT my BFG 315/70/17 spare tire for your stock spare thebassn8tr Buy/Sell 4 10-13-2013 11:34 PM
OEM spare tire for sale new BF Goodrich p275/70r18 spare rim chozn1 Buy/Sell 0 08-16-2011 11:05 AM
Tire Jack & Spare Tire Crank djzetter Titan Parts & Accessories 5 12-03-2009 04:52 AM
You may post new threads
You may post replies
