Re: Towing Jayco Eagle 314bhds Travel Trailer Safely
I pull the Jayco Eagle 322FKS with front kitchen and two slides. Weight about the same. I use weight dist hitch with sway bar. The trailer pulls fine and the sway is no more than normal. I pull my trailer around 55-60 mph. The Titan pulls it very well. Just make your setup is good on your hitch. Watch your added weight . Of course, a big 250 diesel would be a better tow rig but the Titan will pull it ok. Just stay to low speeds and you will be good. I think the front kitchens pull better than most. Good luck.
Robert Louis Stevenson
