Re: Thoughts on hitch?
I would get the Reese before getting the one you asked about. I would also reccomend the Equal-i-zer over any other WD hitch, including the Reese.
These units with chains really require a tool every single time, and the equalizer is so easy that more than half the time I don't need to use the tool at all.
Some of these are only WD hitches, meaning you also need to buy anti-sway separately. With the equalizer, you get both in one unit ... its low tech, but good low tech ... and easy to use.
I found a used equalizer hitch on craigslist -- best price in tow, and heck, its a hitch ... used is no issue at all.
