Old 06-20-2006, 06:47 PM   #1 (permalink)
Questions on new Travel Trailer
I have an 05 titan (XE) that I tow a 24' 6" tt. I am looking at buying a new tt that is 28' 6" that weights about 700 lbs more. The tt has an 5500 gvwr. Just wondering if this is to long for the Titan. The truck tows my existing camper very well. I do use an equalizer hitch. I also wonder why there is a 1000lb difference between the (xe) and (se) tow ratings. I have also upgraded my shocks and tires. Any info would be helpful.
Ramon is offline   Reply With Quote
Old 06-20-2006, 07:31 PM   #2 (permalink)
CoachBoone's Avatar
Re: Questions on new Travel Trailer
I tow a 32' Jayco with my crew cab. Loaded she weighs about 7k, no problems at all. The titan has all the power to tow, my issue is towing something that long like a sail, I sway like a b**ch when it's windy, but keeping the speed down helps a lot. You won't have any problems.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 06-21-2006, 06:32 AM   #3 (permalink)
QWIKWHIP's Avatar
I woudl say you will be fine. I think the only difference between the SE and XE that could effect the tow ratings is the tires. But I'm not even convinced of that. I think it's mainly just a marketing ploy. They want you to buy the more expensive model to get a higher tow rating.
Old 06-21-2006, 06:57 AM   #4 (permalink)
keane's Avatar
I also pull a 32 1/2' jayco, but it weighs closer to 8000lbs. The truck has no problem power wise pulling this load. The only problem I encounter is the height and length of the trailer causes the problem the coach mentions. At over 11' tall, the wind sure likes to push the trailer around. A good sway control hitch helps and if you keep your speed in check, you should have no problems.
Titan CC LE 4x4 Sparkle Red Bug Guard and every option except off-road, DVD, Sunroof & Nav.
Add ons: Sliding bed extender, Leer 180 cap, BFG KO's
Just passed the 57,000km mark!
Born on 03/04
Now it is up for sale - or at least the BFGs and the Cap!
2008 Suburban 2500 LS
keane is offline   Reply With Quote
Old 06-24-2006, 08:12 PM   #5 (permalink)
Thank you all for your imput. I picked the camper up today, tows very well. It is a Surveyor by Forest River.
Model# sv264 (4040 tdw) (5500 gvw) (28'6") I towed around 65mph with no problems at all. It was very hot today and the truck ran normal temps. We towed about 50 miles back to my house. It sure seems longer compared to my other camper (24' 6"). But overall, I was very pleased with my Titan.
Old 06-24-2006, 08:38 PM   #6 (permalink)
dawgs77's Avatar
I say your fine also......I think the difference comes in the tires...the XE has different tires then the rest. Maybe there not rated as high?????
But I don't think there are any other structural differences........
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
dawgs77 is offline   Reply With Quote
Buying a Travel Trailer Newb Questions BlackBart Titan Towing & Hauling 26 05-01-2006 12:55 PM
Travel Trailer Questions Smoke05 Titan Towing & Hauling 7 11-04-2005 05:36 AM
Travel Trailer question pyromedic Titan Towing & Hauling 38 01-08-2005 09:32 AM
Travel Trailer towing + ? Tom-ADC Titan Towing & Hauling 21 08-20-2004 11:02 PM
Need Travel Trailer Advice.... JetTech Off-Topic Discussion 6 05-23-2004 11:40 PM
