Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Trailer Left Turn Signal/left brake light not working - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-14-2008, 06:35 AM   #31
EZDUZIT
EZDUZIT's Avatar
Re: Trailer Left Turn Signal/left brake light not working
Never Mind! I finally found it after I started taking off the electrical tape! Mine was completely covered so I couldn't find it! Way to go dealership!
The only thing my father gave me was a hard time
EZDUZIT is offline   Reply With Quote
Old 03-15-2008, 08:41 AM   #32
young dank
Originally Posted by EZDUZIT
Hey guys I still need someone to tell me exactly where the fuses under the dash are located. I looked for about thirty minutes and still cant see them. I checked with myy dealer and they said all of the recalls and updates where done. Can someone please help me out. I am pulling a 24' car hauler with my brothers Z to a Z car shootout this weekend. Thanks Josh
try running the ground wire<all the way to the trailer lights, behind the bolts and nut thats holding the lights on the trailer. thats the best ground for a titan towing a trailer.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
Old 03-16-2008, 02:03 PM   #33
mytitan
ok ive tried running the ground wire all the way to the lt rear trailer, and no results. ive also check all my fuses and relays and i have all of them working properly. i still have no lt and lt break light. im leaving tomorrow on a camping trip. what i can do temporarily to get left lt and brake lts.
please help.
mytitan is offline   Reply With Quote
Old 03-16-2008, 07:29 PM   #34
young dank
you might be missing a relay, who installed your hitch and put in the relays? and also, take a light of your trail and put the yellow wire to the positive side of your battery and make a wire connection from the bolt that makes secures the light to the trailer and put it on the negative post of the battery. if that light comes on, you either missing a relay or not grounding out properly. if you got lights on one side of the trailer but none on the other side, you missing a relay or that side relay is bad, or you have a ground. wish I was there to help you in person.
Old 03-16-2008, 08:14 PM   #35
mytitan
i only have 1 blue relay, the rest are all brown. tow#1 has a blue relay and tow #2 has a brown relay. my bro's armada has the same thing.
Old 03-16-2008, 09:17 PM   #36
loufish
loufish's Avatar
You need to check the tow harness coming out of the BCM whick provides both turn signal and brake lights for the trailer.
It seems during a recall for a BCM harness issue, there was a small sub harness replaced for the tow package, and it just might now include a fuse for each turn signal(remember it's also the brake) side.
The trucks turn/brake functions are controlled and wired different then the trailer harness.
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 03-16-2008, 09:18 PM   #37
young dank
oh MYTITAN, you have an '05, you only have 1 blue relay. its your trailer dawg. test your pins, but I think its your trailer. cause one relay controls both lights. you might need to rewire the left side due too a short. or ground it better. the frame might be rusted. what kind of trailer is it?
Old 03-16-2008, 09:27 PM   #38
young dank
http://www.titantalk.com/forums/874389-post8.html
thats an 06 and better
Old 03-16-2008, 09:34 PM   #39
loufish
loufish's Avatar
It's moot...Brake/Turn is controlled by the BCM, there are no relays involved for those 2 actions...
Old 03-17-2008, 05:58 PM   #40
young dank
yeah but the relays brings fire to those lights, no relay no lights.
Old 03-17-2008, 06:56 PM   #41
loufish
loufish's Avatar
Negitive....The BCM is responsible for the trailer connectors L/R turn AND Brake signals.
Relays are for the running lights and 12V to the connector.
See enclosed wiring diagram...Circuts #51 & #52 come straight out of the BCM and go straight to the Trailer Connector...
Old 03-17-2008, 07:16 PM   #42
Derwud
Derwud's Avatar
After the campaign, they would have fuses in line, correct? So first check at fr the fuses and then check at the Trucks Trailer connector. then let us know what you find...
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 03-17-2008, 08:21 PM   #43
loufish
loufish's Avatar
I believe you are correct, but still no relays...I should see if I can add a couple of fuse symbols to the Wiring PDF
Done...Fuse info added to diagram
Old 03-18-2008, 03:50 AM   #44
Derwud
Derwud's Avatar
Right idea, wrong wires...
Old 03-18-2008, 04:11 AM   #45
loufish
loufish's Avatar
you're making me laugh...Thanks!
I'll "fix" it one more time...
Once again Done!
User Name
Password
Turn signal stalk with fog light switch GKreamer Buy/Sell 5 03-09-2006 10:44 PM
Need a Left Tail Light.....Any ideas... titannh Titan Parts & Accessories 2 06-14-2005 08:13 AM
Squeaky steering wheel on a left turn?? nursecrickett Titan General Discussion 3 06-05-2005 10:05 PM
groaning sound when making a left turn,help please! dragonhead08 Titan Problems & Dealer Service 4 03-09-2005 08:12 PM
WTB or Trade: non-Fog Light Turn Signal Stalk Gator Buy/Sell 2 10-18-2004 08:52 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
