Old 07-11-2006, 10:40 AM   #1 (permalink)
BKY
Trans Temp gauge
This might have been asked before but I couldn't find it. I want to add a trans temp gauge to my truck is this some thing I can do my self and what gauge should I use. Also spoke to the dealership where I bought my truck and was told to put synthetic in the rears??? should I also put it in the trans
also.
Thanks
BKY is offline   Reply With Quote
Old 07-12-2006, 03:54 PM   #2 (permalink)
blueskys's Avatar
Re: Trans Temp gauge
also.
Thanks
I built a tread on this some time ago. Put in my name in the search engine and you should be able to find it.
What model truck do you have?
blueskys is offline   Reply With Quote
Old 07-12-2006, 03:57 PM   #3 (permalink)
blueskys's Avatar
also.
Thanks
Yes, you should upgrade your differential fluid to full synthetic if you don't have it already. What year truck do you have?
Old 07-13-2006, 02:13 AM   #4 (permalink)
BKY
I have A 05 king cab se perf package utilty bed. what about changing the Trans fluid to synthetic?
Thanks
Old 07-16-2006, 02:10 PM   #5 (permalink)
blueskys's Avatar
Thanks
Nissan put thier own brand of fluid in that is called J-matic. DO NOt replace this with any other fluid while you are under warranty. There is a lot of fluid in the sytem because you have a tranny cooler. I would wait until about 50,000 miles and then find a dealer that can purge the OEM fluid with J-matic. It is exspensive. But I feel this is the best option.
Old 07-17-2006, 02:07 AM   #6 (permalink)
BKY
OK Thanks. I read in the owners manual that the rear has synthetic
oil in it but not the front????????
Also is it possible to swap gears from a non big tow to a big tow set so I can gain the extra pulling weight?
Old 07-18-2006, 06:58 PM   #7 (permalink)
blueskys's Avatar
I would swap the entire axle. But I have heard the computer is programed for the installed axle. So maybe swapping gears is not a good idea.
I own an XE without big tow. I have not experience anything I could tow yet.
Old 07-19-2006, 08:40 AM   #8 (permalink)
BKY
The book says I can tow 7300 I was worried about being over weight.
Thanks for the Info.
Old 07-19-2006, 06:08 PM   #9 (permalink)
blueskys's Avatar
How many axles does your trailer have?
Do you plan on pulling up steep mountain grades?
Does your trailer have electric brakes?
I would be more concerned with the stopping power. My Titan seems to be able to pull just about anything I throw at it.
Old 07-19-2006, 07:49 PM   #10 (permalink)
BKY
2 axles with brakes I thin it will be around the 5000 lb dry weight so I should be ok from what I have been reading.
Old 07-21-2006, 06:05 PM   #11 (permalink)
blueskys's Avatar
If you have electric brakes, it looks like you are set.
Add Trans. Temp Gauge? SmokeyStog Titan Engine, Transmission & Drivetrain 27 01-25-2008 07:17 AM
Outside temp gauge 1blackx Titan General Discussion 11 05-13-2006 07:05 PM
B&M Transmission temp gauge pod.... johnny_munyak Titan Interior Discussion 0 04-12-2006 02:42 PM
Big Tow Tranny Temp Gauge Marc Titan Engine, Transmission & Drivetrain 2 11-05-2005 12:59 PM
Trans Temp Gauge Question roadie Titan General Discussion 5 02-09-2005 05:36 PM
